my 1973 standard beetle build
Goto page Previous  1, 2, 3, 4
MrVWGuy
MrVWGuy is offline
PostPosted: Sat Sep 10, 2011 3:06 pm    Post subject: Heater channels- repair them or replace them? Reply with quote
I wanted this post to be a poll, but I would have to start a new thread, so I guess I'll just ask for some feedback. Today I cleaned some undercoating & seam sealer off in order to better asses the current state of my heater channels. I was planning on replacing them until the reproduction heater channels I bought arrived at my house. I was pretty disgusted with the quality. I realize there are only one or two suppliers in the world who even make them, so I guess I should be happy I don't have to fabricate some new ones from scratch Rolling Eyes . After watching the bug me videos a couple of times, including recently, I'm well aware that replacing them is a lot of work. And that's before you take into consideration that the replacement heater channels will need to be "worked over" in order to make them work. Then there's the fact that every time I open the door, I'll look down on the crappy looking door sills. Looking at my current heater channels, I've certainly seen worse. They do need some repair. Which means cutting, fabricating, welding, grinding, etc. But I won't have to deal cross bracing the doors & door fitment. That's a plus.
The other thing to consider is the original heater channels' metal thickness is .045", while the reproduction heater channels are only .035" thick, pretty significant difference in my book considering these are structural pieces of the car.
Anyway, please take a look at the pics below & let me know what you would suggest I do- repair or replace. Thanks for looking!
Now here are the replacement aftermarket channels:
'73 Beetle (under construction)
'68 Kombi
jeff plock
jeff plock is offline
PostPosted: Sun Sep 11, 2011 6:19 am    Post subject: Reply with quote
well chris your never going to get all the rust thats hideing in the little cracks and its just gonna come back to haunt you once again. So that being said cut the damn things out your new channels look fine whats the issue your having with the new parts? as long as you make door opening supports and have them at the correct opening( put them in before you cut your channels out) its pretty easy to do grind and cut as you go and youll be able to dial it right in} . The issue you were having with the pan holes lineing up with your new heater channels is normal but they should be pretty close if you have to oblong the floor pan so what the washers they give you are huge and they will cover it up
GO FOR IT
love doing fab work have anyquestions send me an e mail maybe i can help
jeff plock
PostPosted: Sun Sep 11, 2011 6:30 am    Post subject: Reply with quote
DONT MAKE ME FLY OUT THERE AND CUT THOSE NASTY THINGS OUT MYSELF .
look at how beautifu lyour pan turned the .010 in mat thickness is nothing compared to what is already gone in yours cut them out youll be glad you did
MrVWGuy
MrVWGuy is offline
PostPosted: Sun Sep 11, 2011 6:40 am    Post subject: Reply with quote
The floor pans are og, the repop channels don't line up enough to get more than two bolts in them!
'68 Kombi
jeff plock
PostPosted: Sun Sep 11, 2011 7:12 am    Post subject: Reply with quote
you have to ask yourself what the car means to you if its just gonna be a beeeter than fixing is probally the way to go. If its gonna be more than that well you should do it the right way your call keep me posted jeff
conrad1468
conrad1468 is offline
PostPosted: Tue Sep 13, 2011 4:39 am    Post subject: Reply with quote
When i replaced my passenger side heater channel. The bottom of the channel completely fell off. I left my doors on and i put a support piece of angle iron across the door opening. I cut out the old channel with a dremel to help preserve as much good metal i could.
Once the old channel was out I slide in the new channel, lowered the body onto the pan with with the loose channel alined my pan to channel bolt holes the best i could in both channels and started welding in the channel. then took the body back off. I would do 1 side at a time.
Just like the in the bug me videos i built some saw horses to hold the body and i could roll the pan under the body. i have a tiny little 1 car garage.
It does look like your new heater channel is bent. I don't think you want to start with a bent channel. The pan bolts are hard enough to get lined up let alone using a bent heater channel.
I bought mine at CIP1. Like what you said.. The quality just isn't there for body panels.
That's my 2 cents... good luck and get that darn rust out of there!!!
Fresh Air VW Car Club
New Pittsburgh, PA Car Club. 100% free!!!
club website link
http://groups.yahoo.com/group/FreshAirVWCarClub
thesamba link
http://www.thesamba.com/vw/forum/viewtopic.php?t=363031
Look us up on Facebook, too
View user's profile Send private message Send e-mail Visit poster's website Yahoo Messenger Gallery Classifieds Feedback
63Ragtop NZ
63Ragtop NZ is offline
PostPosted: Thu Sep 15, 2011 6:39 pm    Post subject: Reply with quote
I'm with conrad, something don't look right with that repop.
It's never going to fit the pan like that!
keep up the good work man.
If you can't join them, beat them!
MrVWGuy
MrVWGuy is offline
PostPosted: Sun Sep 18, 2011 7:02 pm    Post subject: Heater channel replacement Reply with quote
Ok, so I decided to proceed with replacing the heater channels with the reproduction (aka repop) channels purchased from Wolfsburg West. Let me just say first of all, pay close attention to when Rick Higgins says "cut INSIDE of the solid welds around the pillars". Like an idiot, I cut outside of the welds. I have no idea what I was thinking. Learn from my mistake!
They will not come out if you cut outside of the solid welds. I went back & cut INSIDE the solid weld.
Then I drilled out the spot welds, front & rear:
Used the spot weld cutter:
Cut the rear solid weld:
Drilled out more spot welds:
Look Ma! Not heater channel! Note the 1"X1" angle iron bracing.
OK! Now we're getting somewhere! Initial channel fitment:
Note the area below that isn't painted. That's where I had to remove the carpet hold-down strip. Not only was it on BACKWARDS, it was over 2" too far back Rolling Eyes . Garbage channels.
See how it disappeared under the B pillar? Garbage. Rolling Eyes
Note the end of the air duct. Yeah, that crap will never fit on the piece it's supposed to go on...
That's as far as I got today. Initial fitment is "poor" at best. As you can see, I have a little bit of fabbing to do, and a lot more rust repair to do Crying or Very sad . Check back for updates. Thanks for looking.
'68 Kombi
TonyPgh
TonyPgh is offline
PostPosted: Mon Sep 19, 2011 5:12 am    Post subject: Reply with quote
Wow!! Your project is coming along with pro results. I didn't get into the body work part of mine yet. I dread that part.
Heater channels are a pain!
Your pan and engine are outstanding! Looks like something out of Hot Vw Magazine. I need to stop by and check out your ride. And your garage!
1972 Standard Beetle.
19-VW-74
19-VW-74 is offline
PostPosted: Sat Dec 03, 2011 6:33 pm    Post subject: Reply with quote
Any more progress? This thread is a good time Cool
MrVWGuy
MrVWGuy is offline
PostPosted: Sun Dec 04, 2011 2:37 pm    Post subject: Reply with quote
Unfortunately life crept up on me, from a number of different angles, and I have not been able to touch my project since September. Sad
But thanks for the kind word, I didn't think anybody was following it anyway! Very Happy
'68 Kombi
74matt
74matt is offline
PostPosted: Sun Mar 04, 2012 12:35 pm    Post subject: Reply with quote
Just wondering if you had a chance to work on the bug again, It's looking great!
MrVWGuy
MrVWGuy is offline
PostPosted: Sun Mar 04, 2012 3:43 pm    Post subject: Reply with quote
Not recently, but one of the things that has put me off was the poor quality of the Klokkerholm heater channels that I got. So I had hoped to find a pair of originals cut out of a car, but couldn't believe the shipping prices I was quoted. So I finally ordered some new heater channels made by Dansk. They'll be there this Thursday. Hopefully they'll be better quality. We shall see.
'68 Kombi
AirDirect
AirDirect is offline
PostPosted: Tue Mar 06, 2012 9:54 am    Post subject: Heater Channels Reply with quote
Nice job cutting them out. Get everything clean and tight before trying to weld. You will be glad you changed them.
Beetlebaum
Beetlebaum is offline
PostPosted: Tue Mar 06, 2012 9:04 pm    Post subject: Reply with quote
Just found this. Nice pan and chassis! I sure wish mine was that good.
1973 Super Beetle from the junkyard--engine waiting for install!
1958 Edsel--front suspension reinstalled! Very Happy
Post your Super here: http://www.thesamba.com/vw/forum/viewtopic.php?t=331999
Beetle Bums VW Club Member
MrVWGuy
MrVWGuy is offline
PostPosted: Wed Mar 07, 2012 7:44 am    Post subject: Reply with quote
Thanks! But at least you can DRIVE yours! I cannot...
'68 Kombi
MrVWGuy
MrVWGuy is offline
PostPosted: Mon Mar 12, 2012 7:11 pm    Post subject: Reply with quote
FYI my heater channel info was moved to the FAQ here:
http://www.thesamba.com/vw/forum/viewtopic.php?t=503306
'68 Kombi
MrVWGuy
MrVWGuy is offline
PostPosted: Sat Apr 28, 2012 8:22 pm    Post subject: Reply with quote
66busman wrote:
So you're up to 3 bugs now? Congrats, you're in the icantstopbuyingvolkswagens club!
Great job on your project.
3 bugs & a bus now Wink
'68 Kombi
Page 4 of 4
