75 westy deluxe rebirth
Goto page Previous  1, 2, 3, 4, 5, 6, 7, 8  Next
bugger101
bugger101 is offline
PostPosted: Sat Apr 30, 2011 7:04 am    Post subject: Reply with quote
well guys the machine shop i went to said the engine case has a crack on the the oil breather,then it just broke off when my brother poked it ](*,)but they couldn't even get it apart only cracked Crying or Very sad
so now i need another engine Evil or Very Mad
so i moved on to taking the interior out for now
75 west deluxe http://www.thesamba.com/vw/forum/viewtopic.php?p=5270450#5270450
2010 ford focus
1949 ford f-1
2006 Lincoln navigator
automotive student
ford line tech
notchboy
notchboy is offline
PostPosted: Sat Apr 30, 2011 8:17 am    Post subject: Reply with quote
Pics of the inside gut please! Sorry the motor is kaput.
Jason "notchboy" Weigel
1964 T34 S Convertible
1974 Westfalia Hardtop Campmobile
1977 Westfalia Camper pop-top
the1500club.com TS Logo
TOOB Member #5
guanella74
guanella74 is offline
PostPosted: Sat Apr 30, 2011 9:39 am    Post subject: Reply with quote
Yeah, bummer on the motor.
- Travis & Laura
1974 Volkswagen Campmobile Westy
2000cc, stock AMC heads, solid lifters, engine completely rebuilt ~17K ago (as of July 2011).
Dual Weber IDF 40 Carbs: Currently jetted at 120 mains, 50 idles, 200 air, F11 tubes.
EMPI Extractor Exhaust, stock heat shield in place.
JFUD 021 905 205P SVDA Distributor w/Petronix
MGL Avionics All-in-One Gauge (CHTs, etc)
Orange Plaid, baby!
bugger101
PostPosted: Sat Apr 30, 2011 10:07 pm    Post subject: Reply with quote
ok so today i cleaned out the interior and found some rust under the carpet Shocked then i cleaned the pop top and painted it (didn't have time to paint the luggage rack). the engine is sitting in idle i got it cracked but it wont budge on the bottom of the engine. so here are so pictures of all the rust and the poptop
Image may have been reduced in size. Click image to view fullscreen. sliding door track
2010 ford focus
1949 ford f-1
automotive student
ford line tech
bugger101
PostPosted: Tue May 03, 2011 8:45 am    Post subject: Reply with quote
ok guys i am at a crossroad with the engine do i sell it and get a type 1?
will it fit a 3 rib trans? without mod fictions to the input shaft? and would i need a different starter. i know that i would need the creative car craft tin
what would i need for clutch Question
i know that if i put a type 1 in there i will be running but for how long would a 1600 last if i put a oil cooler and fan on it. i know that i will go slow and get terrible gas mpg but i just want to be up and running and go camping.
i really need your input guys
2010 ford focus
1949 ford f-1
automotive student
ford line tech
Westfabulous
Location: The tropic of Canada, dodging the giant flying moose of Surrey!
Westfabulous is offline
PostPosted: Tue May 03, 2011 9:07 am    Post subject: Reply with quote
No offense intended, but I think the question you need to ask is whether this bus is the one you want to save. With a shot engine, and the body not far behind, you are going to be into this for a lot of money if you do it right. For my dollar, I'd consider looking for something that is in better shape and running. It's all about value for money, but then again, I'm probably not as talented as you when it comes to the hands on stuff. Sometimes it seems to me that fixing a rough bus is false economy compared to spending a little more and getting a running, decent bus. Think it through; you'll come to the best answer for your needs. Best of luck whatever you choose to do.
"I will gladly pay you Tuesday for a hamburger today."
bugger101
PostPosted: Tue May 03, 2011 10:15 am    Post subject: Reply with quote
the point of this project was to save a bus that most people would have turned into a parts car,i am good at metal work so there is no problem there. i just want to get it running while i do the metal work
2010 ford focus
1949 ford f-1
automotive student
ford line tech
Bleyseng
Bleyseng is offline
PostPosted: Tue May 03, 2011 11:07 am    Post subject: Reply with quote
find a used engine that runs as they are around and stick it in. The case tower broke cuz someone was hitting it..... the case will come apart if ALL the bolts are removed first
70 Ghia Black convert-stock w/122k 1600 SP-barn find
77 SageGreen Westy Deluxe
Stock w/ 134K 2.0L w/Ljet, Camper Special engine-95hp and with LSD!
76 Porsche 914 2.1L L20c, 120hp Djet
CamperSpecial Club Member
bugger101
PostPosted: Tue May 03, 2011 8:01 pm    Post subject: Reply with quote
so can anyone tell me if the type 1 engine would work on my bus?
2010 ford focus
1949 ford f-1
automotive student
ford line tech
bugger101
PostPosted: Wed May 04, 2011 3:11 pm    Post subject: Reply with quote
bump does anyone know if it will work do i need to get this http://www.creativecarcraft.com/notforbug.htm
as i cant find a type 4 around here i just want to get it running
what kind of mods do i need to do to the trans?
2010 ford focus
1949 ford f-1
automotive student
ford line tech
notchboy
notchboy is offline
PostPosted: Wed May 04, 2011 9:14 pm    Post subject: Reply with quote
Yes, start with this
http://www.thesamba.com/vw/forum/viewtopic.php?t=307829&highlight=early+motor
What you want to do was done by VW in other markets outside the US. You could say get a 1600cc T2 motor like found in a 71 and older bus in a say 77 if you wanted. Its fairly common in the UK and Europe to see a later bus with an early engine from the factory.
And there are several more threads than the one I listed-its a question that gets asked twice-three times a month.
TOOB Member #5
bugger101
PostPosted: Sat May 28, 2011 8:03 pm    Post subject: Reply with quote
so i just got this type 4
all i know about this engine is that it turns over, should i try and start it? or should i tear it down?
any one need some FI parts
2010 ford focus
1949 ford f-1
automotive student
ford line tech
fsf1o1
fsf1o1 is offline
PostPosted: Wed Sep 21, 2011 11:48 am    Post subject: Reply with quote
I cant Wait Till this is done and where camping
Kirk Premium Member
Kirk is offline
PostPosted: Wed Sep 21, 2011 12:00 pm    Post subject: Reply with quote
Im always looking for spare FI parts. Shoot me a PM.
I tend to agree with Westfabulous tho. You sure this is the one you wanna save?
Oppenhiem
Zed
Bear
Deluxe
bugger101
PostPosted: Mon Sep 26, 2011 6:57 am    Post subject: Reply with quote
Trust me even though it is a big project, I am very confidant that it is in capable hands. just waiting on my friends welder Cool Just took out the trans today. It's going to take time but it will be worth it in the end, I fell in love with this bus, And i don't want to see it near a junkyard. Right now I took out the interior, sandblasted the rust area's then 2k primer, and taking the brakes off so i can roll it around. I have a bunch of parts on order so it's coming along Very Happy . nothing major yet Sad . The old 49 ford has been getting in the way Cool
Yea me too, I see other bus's as a inspiration,but I am takeing my time and doing it right. hopefully it will be drivable by spring Very Happy
2010 ford focus
1949 ford f-1
automotive student
ford line tech
airkooledchris
airkooledchris is offline
PostPosted: Wed Nov 09, 2011 11:09 am    Post subject: Reply with quote
so what happened with this engine? did you end up firing it up and getting it installed into the bus so you can move it around while doing your metal work?
Join the IAC Facebook group here!
bugger101
PostPosted: Sun Feb 12, 2012 8:20 pm    Post subject: Reply with quote
I got it back together and now it runs Very Happy
2010 ford focus
1949 ford f-1
automotive student
ford line tech
bugger101
PostPosted: Sun Feb 12, 2012 8:28 pm    Post subject: Reply with quote
today I made some progress fixed a small rust spot(one of many), removed all of the a/c lines and the torn up wiring harness and started undercoating the underside. Anyone know some some good threads of replacing the rear corners and battery trays?
2010 ford focus
1949 ford f-1
automotive student
ford line tech
bugger101
PostPosted: Thu Feb 23, 2012 9:06 pm    Post subject: Reply with quote
Was looking through some paperwork and found another title and I see the another owner's name and address looked it up on Google and found that there is a company operating out of the home so I will give him a call tomorrow hope it turns up some pictures or something. Anyone live in or near Quitman, GA.
2010 ford focus
1949 ford f-1
automotive student
ford line tech
bugger101
PostPosted: Fri Feb 24, 2012 1:57 pm    Post subject: Reply with quote
Talked to the owner today and he had some great stories about the van. And how he went cross country in it. He has the rear table for the back Very Happy Very Happy . He said to say Hi for him to the bus.
2010 ford focus
1949 ford f-1
automotive student
ford line tech
Page 2 of 8
