a1fa Samba Member
Joined: September 25, 2011 Posts: 251 Location: Central Arkansas, United States
Posted: Mon Oct 03, 2011 2:42 pm Post subject: SpeedVagon.. NOT |
I am new to 1981 VW Vanagon. If you recall my previous post I had some issues with pushrod seals, and also oil pressure sensor... $330 later, and 1 gallon of gas lost due to over-fill she is running again....
My first road trip, a 60 mile round trip, 1 mile up a steep hill, and I felt like something is holding me back.
Is the 2.0 so gutless, even on the straights, and even up small hills. Once I get moving over a certain distance and get to the 4th gear the engine runs fine and smooth, and I can maintain good speed.. getting there is a major pain in the butt.. i expected a bit more "life" out of a 2 liter..
I've experienced similar performance on my 50cc 2-stroke scooter after the exhaust got clogged up... could it be that my cat is clogged up, and this thing is not breathing ok?
I feel like I have an exhaust leak too, before the cat, a small tube rotted out.. possibly the EGR... so the question is, could this be holding me back?
r39o Samba Polizei
Posted: Mon Oct 03, 2011 3:04 pm Post subject: |
Pushing around a 5000+ pound aerodynamic brick with a wheezing 68 hp may have something to do with it......
With 135 hp I can just keep my own with traffic. Much better at speed on the freeway, like you.
I am dreaming of that 165+ hp 2.5 with high compression hybrid Suby engine..... _________________ "Use the SEARCH, Luke" But first visit the Vanagon FAQ!
1990 Multivan EJ 22 running well...
scottf3334 Samba Member
Joined: May 26, 2006 Posts: 202 Location: Davenport, FL
Posted: Mon Oct 03, 2011 3:35 pm Post subject: |
Vanagons are a big brick, but it sounds as if you may be having some problems. They are not ridiculously slow, unless you are talking about the diesel
Hills are not your friend, but keep in mind people have been driving these around since the early eighties. Just keep the revs up.
Make sure you are firing on all four cylinders and that your engine is timed right. Sounds as if that may be your problem.
Also, fix the exhaust leak. If it is the egr tube, you can block it off. Post up some pictures of your new ride. _________________ 84 Westy
78 Super vert
87 Westy Zetec |
Timwhy Samba Member
reluctantartist Samba Member
Joined: August 13, 2006 Posts: 1744 Location: Bloomington, IN
Posted: Mon Oct 03, 2011 4:26 pm Post subject: |
You should not have trouble getting to 4th on the straight away. If you are struggling, something is amiss. Maybe a clogged or melted CAT or dragging brakes. On a level surface or even a slight incline I easily get up to 70. Now if you expect to get to 70 as fast as my wife's volvo s60 t5 then yes it is a slug. If you do not have a Bently, get one in the mean time down load the Bosch AFC manual http://www.thesamba.com/vw/archives/manuals/afc_fi_training_troubleshooting_manual.php
and follow the troubleshooting section. _________________ 1982 Westy, 1974 412 Variant... Yes, Aircooled's are great! Oh and I do have modern computer controlled vehicles too, but I just don't care about them. |
a1fa Samba Member
Posted: Mon Oct 03, 2011 5:32 pm Post subject: |
I did some basic maintenance tonight. Changed the oil to 10W30 with Lucas oil treatment. I noticed there is a hissing sound coming from somewhere. I thought it was from the airbox, but I found one vacuum leak. There has to be another one. The rubber on these is just not holding up after 30 years. All kidding aside.
Is there an easy way to check the timing, or do I need to get a mechanic with a timing light? Also, a mechanic friend of mine pointed out that he is hearing a knock.. I couldn't hear it, until the oil change... Denial i guess.... I'm still thinking its the airbox flappin around.. Should be posted shortly. He thinks its a rod knock. |
Antron Samba Member
Joined: July 13, 2004 Posts: 279 Location: Greenville Mi
Posted: Mon Oct 03, 2011 5:45 pm Post subject: |
knocking after the oil change ? I'd try 20/50
Bob
87 syncro westfakia |
a1fa Samba Member
Posted: Mon Oct 03, 2011 5:47 pm Post subject: |
| ok.. my cellphone's microphone pretty much eliminated all the engine noise and all i got was white noise... but the knock is only on acceleration, and can only be heard when you are standing on top of the engine.. not literally you silly.. i blip the throttle and you can hear clonk.... but if you go steady on the throttle it does not do it... |
vanagonjr Samba Member
Joined: October 07, 2010 Posts: 910 Location: Dartmouth, Mass.
Posted: Mon Oct 03, 2011 5:49 pm Post subject: |
I think it is hard to define if you are having a problem based on slow acceleration from a posting - since "slow" is a not a definable quantity.
I had an air cooled Vanagon Westfalia - which despite a re-built engine and pronounced as "having plenty of power" from well-respected VW shop that set it up after my re-build. I found it OK on flat ground, but any hill at all was a challenge. An up-hill on ramp was down right dangerous. Hence I now own a water cooled Westfalia "Weekender" (pop-top, no kitchen, propane - i.e. - lighter) and I find the motor essentially adequate.
And yet, plenty of water cooled convert for more power (in addition to reliability). A modern mini-van has over 250hp, (over 3.5 x 68HP) so even after an engine conversion, the power in a Vanagon will generally pale to a modern vehicle.
You really need someone local with an air-cooled Vanagon Westfalia to drive your van and/or vice-versa to determine if your van lass less than 68HP.
John |
Andrew A. Libby Samba Member
Joined: February 22, 2006 Posts: 3496 Location: Flagstaff, AZ
Posted: Mon Oct 03, 2011 5:51 pm Post subject: |
| There are dyno aps for the iPhone. 68hp at the crank is approx 58 hp at the wheels. |
a1fa Samba Member
Posted: Mon Oct 03, 2011 6:06 pm Post subject: |
Tomorrow I am lubricating shifter linkage. It just feels dry, and its making squeeky noises.... but I may dump this oil and go 20W50 with Lucas additive, but winter is coming, and it will be a bitch to turn. Is there a documented EGR removal process, or is disconnecting linkage enough?
My rig:
Bus parking only approved!
Original miles.. is it normal to start knocking?
Popsvan Samba Member
Joined: May 10, 2010 Posts: 69 Location: Washington, PA
Posted: Mon Oct 03, 2011 6:19 pm Post subject: |
Nice ride!
I have an 82 Auto westy and it is slow! ' ' 70? thats retirement age not a speed right? ' ' _________________ Rory
Washington PA
82 Westy Automatic |
a1fa Samba Member
Posted: Mon Oct 03, 2011 6:21 pm Post subject: |
Thank you.. so far I am loving it....
If you had to predict, not knowing how long did previous owner drove it with a knock, how long it would last....
The question is, is it better to go ahead and split it now, and rebuild or wait for the inevitable? |
dobryan Samba Member
Joined: March 24, 2006 Posts: 2059 Location: Brookeville, MD
Posted: Mon Oct 03, 2011 6:25 pm Post subject: |
Where are you located? If you put in more info than 'US' someone in your area will likely volunteer to let you drive theirs to see if there is a difference. Nice ride, looks great.  _________________ Dave O
'87 Westy w/ 2002 Subaru EJ25 w/ TBD and Locker
"To travel hopefully is a better thing than to arrive." Robert Louis Stephenson |
BillWYellowstone Samba Member
Joined: July 16, 2011 Posts: 636 Location: Yellowstone NP
Posted: Mon Oct 03, 2011 6:32 pm Post subject: |
55 is retirement age. Well from one career to another, then again later, 70 as a limit is not a limit but a goal.
Mine will cruise at 75, right at about 4k on the tach. _________________ Live Fulltime in motorhome
Have 86 Westy Camper 2.1 rebuilt
Work in Yellowstone NP year round. |
a1fa Samba Member
Posted: Mon Oct 03, 2011 6:37 pm Post subject: |
| dobryan wrote: | Where are you located? If you put in more info than 'US' someone in your area will likely volunteer to let you drive theirs to see if there is a difference. Nice ride, looks great.  |
Thanks.. Central Arkansas. |
Ahwahnee Samba Member
Joined: June 05, 2010 Posts: 3065 Location: Mt Lemmon, AZ
Posted: Mon Oct 03, 2011 6:44 pm Post subject: |
| Looks a bit like Queen Wilhelmina State Park (one of the most scenic spots in Arkansas). |
a1fa Samba Member
Posted: Mon Oct 03, 2011 6:53 pm Post subject: |
| Ahwahnee wrote: | | Looks a bit like Queen Wilhelmina State Park (one of the most scenic spots in Arkansas). |
Petit Jean Mountain Let me tell you, it was a chore to get up to 1000 feet.. hahaha.. anyway, lets get back to the knock... what do you fellows/ladies think? |
RCB Samba Member
Joined: September 05, 2005 Posts: 3522 Location: San Francisco-Bay Area
Posted: Mon Oct 03, 2011 7:31 pm Post subject: |
| Howz a bout checking out Roadhause for a mechanic in your immediate area. Nice to see another air cooled on the road. Good luck |
a1fa Samba Member
Posted: Mon Oct 03, 2011 8:04 pm Post subject: |
| Who do you guys recommend for drop-in air-cooled replacement? |
