jbbugs Samba Member
Joined: September 16, 2002 Posts: 1709 Location: Behind the wheel
Posted: Tue Dec 06, 2011 7:58 am Post subject: Serious Top end speed needed! |
Check out the track layout for the 14-Hour ChumpCar roadrace coming up on May 27th!
We're currently running a Stock-geared 3.88 IRS trans in my 73' Super Beatle, and are topping out around 105mph. I'll be stepping up to a .82 4th gear, but it will obviously not be enough on a track this Big.
Should be a blast anyway!
www.chumpcar.com _________________ Drag bus! http://www.youtube.com/watch?v=s2MOVmKdhX4
58' double-door panel
57'tubeframe dragbug
73' Super Beetle CrapCan roadracer
and an 04'F150 to tow them with
Contrary to popular Samba Folklore, the 010 is Not the sliced bread of VW distributors
www.jbbugs.com |
mcmscott Samba Member
Joined: March 12, 2010 Posts: 1256 Location: sanger ca
Posted: Tue Dec 06, 2011 8:08 am Post subject: |
| Run a 3.44 r/p with a .82 fourth, you just better have enough grunt to pull it! |
Eaallred Samba Member
Joined: May 18, 2003 Posts: 5218 Location: West Valley City, Utah
Posted: Tue Dec 06, 2011 8:16 am Post subject: |
What rpm are you hitting at 105mph? Are you limited by engine rpm limits, or is that where it runs out of power? If the engine is just out of power at that point, gearing taller will probably just slow you down. _________________ Eric Allred
10.29 @ 131mph
Utah's fastest and quickest VW.
Aircooled.Net
Blackline Racing (Formerly ACE) |
Posted: Tue Dec 06, 2011 8:17 am Post subject: |
| ^^^^ Agreed |
Posted: Tue Dec 06, 2011 8:19 am Post subject: |
Reason im saying, is I hit just over 130mph in a stock geared trans with a 4:12 ring and pinion. Was doing about 6200rpm on a 26" tire.
I don't see 6200rpm as being too high of an rpm to hit at the track, just wondering if the car is only pulling up to 105. If so, you just need more power, I think you have the gearing to do it (3.88 ring and pinion in there already,right?). That track is not all high speed, there's some 'slow' turns in there as well. _________________ Eric Allred
10.29 @ 131mph
Aircooled.Net
Posted: Tue Dec 06, 2011 8:26 am Post subject: |
| A "stock" 3.88 trans has the same final drive as a 4.12, r/p times fourth gear, due to the .94 fourth verses the .89, you still should be able to hit higher top speeds tho |
markhuebbe Samba Member
Joined: March 08, 2006 Posts: 368 Location: St. Louis, USA
Posted: Tue Dec 06, 2011 9:29 am Post subject: Re: Serious Top end speed needed! |
| jbbugs wrote: | | ...We're currently running a Stock-geared 3.88 IRS trans in my 73' Super Beatle, and are topping out around 105mph. ... |
What is your tire diameter? What's your HP? 100? 150? _________________ 1970 Beetle - Rally car
http://www.Rally-America.com
http://www.HuebbeRally.com |
jbbugs Samba Member
Posted: Tue Dec 06, 2011 9:35 am Post subject: |
I'm currently running a 14" Falken Azenis 615K tire with a diameter of 22.75". It's the only size 14" tire they offer. We LOVE the tires, as they stick like glue, and have held up fine during 24, and 14-hour races.
I'm sure a taller tire would help a bunch, but for now I'm stuck with the 14" wheels.(I have a number of them for spares). I've dynoed the motor at 110hp at the wheels running 91 octane w/8.0CR. To keep the fuel costs down, we're having to stay with pump gas, as we burned 130+ gallons during the 24-hour race.....Fuel ain't cheap!
It also has to LAST for 14-24 hours w/o damaging itself....Keep in mind, this IS Endurance racing
We tend to top out around 5,700 rpm's in 4th gear. We're getting killed on the long straights, but can hold our own against most of the field in the shorter, third gear turns. I expect some of the faster cars to see 140-150mph at Daytona. I'm sure we can't get up to those speeds. We'll have to stay low on the inside and point them by for sure.
I'm considering a 3.44 R&P, but I'm worried it might hurt us in the shorter turns. Anybody got a cheap 3.44? _________________ Drag bus! http://www.youtube.com/watch?v=s2MOVmKdhX4
www.jbbugs.com |
wompninja Samba Member
Joined: July 06, 2008 Posts: 1970 Location: Salt Lake City
Jake Raby Samba Member
Joined: August 23, 2003 Posts: 6923 Location: Aircooled Heaven USA
Posted: Tue Dec 06, 2011 12:12 pm Post subject: |
Despite gearing you'll need power to overcome the aero wall... _________________ Jake Raby
Raby Engine Development
www.rabyenginedevelopment.com
"I've never given anyone Hell, I just told them the truth and they thought it was Hell" |
jbbugs Samba Member
Posted: Tue Dec 06, 2011 1:12 pm Post subject: |
| Jake Raby wrote: | | Despite gearing you'll need power to overcome the aero wall... |
I was thinking that. We were running a smaller motor at Roebling road, and we had installed some silly looking wing on the back of the roof.........It killed almost 300 rpm's on the top end.
The wing was removed after a few laps.  _________________ Drag bus! http://www.youtube.com/watch?v=s2MOVmKdhX4
www.jbbugs.com |
Posted: Tue Dec 06, 2011 1:37 pm Post subject: |
| jbbugs wrote: | | ...I've dynoed the motor at 110hp at the wheels running 91 octane w/8.0CR. ...I expect some of the faster cars to see 140-150mph at Daytona. I'm sure we can't get up to those speeds. We'll have to stay low on the inside and point them by for sure.... |
Then with 110 HP you're going to stay down on the inside. Gearing won't help.
Theoretical top speed given:
110 HP
70 deg. OAT
29.96 in. HG
Coeff. Drag 0.48
Frontal Area 19.37 ft^2
Top Speed = 121 MPH
That's assuming you're putting out peak HP at your max speed. (Think salt flats where the gearing is optimized for top speed & max HP)
That speed doesn't include friction losses between the tires & the road or any power used to build momentum in any moving parts.
So I really doubt you're going to reach more than maybe 110 mph in that long 0.8 mile section before the chicane at the back stretch. _________________ 1970 Beetle - Rally car
modok Samba Member
Joined: October 30, 2009 Posts: 8618 Location: Colorado Springs
Posted: Tue Dec 06, 2011 2:01 pm Post subject: |
It's not real scientific, but my general belief is it takes at least 120 crank HP to go 120 mph.
The bus forth should work, maybe the 3.44 with a .89?....... any higher and it might be overkill
Is it against the rules for your fenders to "fall off"?
 _________________ Glen Urban |
Bill271 Samba Member
Posted: Tue Dec 06, 2011 7:22 pm Post subject: |
| Freakin put a bigger arm in it and piss everybody off! |
Lo Cash John Samba Member
Joined: February 06, 2004 Posts: 1384 Location: Jacksonville, FL
Posted: Tue Dec 06, 2011 8:49 pm Post subject: |
You need to do less work or make more power or both.
Can you clean up the aerodynamics? Shave the drip rails and door hinges? Flush mount lexan windows? Loose the bumpers if you have any? Maybe a mild chop top if you have time?
If you try and make more power, how would you cool it? Maybe a ram air tube from the front end straight into the fan intake? Water cooled heads? Run it on alky maybe? Costs more, but to exploit that advantage you could just up the compression a lot and not spend another penny on parts. That helps offset the higher fuel cost. Just throwing some dumb ideas at ya'. _________________ www.LoCashRacing.org
More brains than bucks...Believe it or not!!
My boss told me I need to work on my mutli-tasking. So now when I use the bathroom at work I surf The Samba on my iPhone. |
mark tucker Samba Member
Joined: April 08, 2009 Posts: 8496 Location: SHALIMAR ,FLORIDA
Posted: Tue Dec 06, 2011 10:16 pm Post subject: |
| I would bump the cr up to atleast 9. with .040" piston to head clearance. I my self would have at least 9.5,I run 10.5 on the street everyday, no problems.how are your heads? is there room for improvement there?what size motor?carbs?exhaust? and higher cr uses less fuel. |
jbbugs Samba Member
Posted: Wed Dec 07, 2011 6:47 am Post subject: |
| mark tucker wrote: | | I would bump the cr up to atleast 9. with .040" piston to head clearance. I my self would have at least 9.5,I run 10.5 on the street everyday, no problems.how are your heads? is there room for improvement there?what size motor?carbs?exhaust? and higher cr uses less fuel. |
The current motor is a 2332, 8.0 CR ,CB 2288 cam, straight cut gears, CB CNC Ultramag 42X37 heads, 1-5/8' exhaust, Single 44-IDF carb. YES, I said SINGLE carb. I know, I know..... We went with it because it has been completely trouble free. I'm trying to avoid linkage issues that dual carbs bring with them.
I might try a pair of 48 IDF's, but I'm not sure if they would hurt our fuel miliege or not. We cannot increase our fuel cell size. Right now,We can do around 1hour, 45 minutes before a fuel stop. Possibly a bit more. ChumpCar has mandetory 2-hour driver changes to keep people fresh, and NOT run Giant fueltanks for safety reasons. _________________ Drag bus! http://www.youtube.com/watch?v=s2MOVmKdhX4
www.jbbugs.com
ralf Samba Member
Posted: Wed Dec 07, 2011 7:14 am Post subject: |
i think ud gain top end by turning the exhaust down to 37 vs 73mm
hahaha kidding!!!
that track looks like its killer....
wish u guys all the top end luck and hit us back with updates on the game plan and result _________________ Flow Through a Curved Conduit |
Buellistic Samba Member
Joined: February 04, 2011 Posts: 334 Location: Albuquerque, New Mexico
Posted: Wed Dec 07, 2011 7:17 am Post subject: |
| jbbugs wrote: |
I might try a pair of 48 IDF's, but I'm not sure if they would hurt our fuel miliege or not. We cannot increase our fuel cell size. Right now,We can do around 1hour, 45 minutes before a fuel stop. Possibly a bit more. ChumpCar has mandetory 2-hour driver changes to keep people fresh, and NOT run Giant fueltanks for safety reasons. |
I'm running dual Kadrons with a dual heim joint linkage which is supposed to be problematic once the engine is warmed (because it expands slightly). It's been problem free entirely.
Also, with the ability to tune the intake for each individual cylinder, you SHOULD get the best mileage of any carb. And that's just logical.
I would wait for someone who knows more about cam duration vs compression, but my 1776cc daily driver is currently running the CB 2235 cam and 9.24:1 CR on 91 octane. I think you can get away with more than 8. |
slalombuggy Samba Member
Joined: July 17, 2010 Posts: 3717 Location: Canada 306
Posted: Wed Dec 07, 2011 7:33 am Post subject: |
I tried a 388/.82 combo in my buggy. The RPM drop from 3 to 4 it STEEP alround 1500 rpm. You'll need more than 110 hp to pull that gear combo. I would look at a 3.44 R/P, I borrowed a tranny with that gear from Team Blackline last year at Bonneville and absolutely loved it. Every gear was noticably longer and with your short tires I think would help a lot. My autocross slicks are 22 inches tall and I'm running a stock box, that combo sucks.
brad _________________ BB Buggy 121.253mph @ Bonneville 2012
http://www.youtube.com/watch?v=57hMyJmIU10
Raisin cookies that look like chocolate chip cookies are the main reason I have trust issues |
