no power to front fuel pump
v dub boy
v dub boy is offline
PostPosted: Wed Dec 28, 2011 6:33 pm    Post subject: no power to front fuel pump Reply with quote
its a 1972, 411, fuel injected, automatic,
no power to front fuel pump checked all fueses in mane fuse block.
checked front fuel pump key on test light shows no power (with good ground)
is there any other fueses hiding for the pump?
ran to store parked it went to start it no go.
thanks
(0⎝ i ⎠0)
View user's profile Send private message Facebook Twitter Gallery Classifieds Feedback
A-and-K
A-and-K is offline
PostPosted: Wed Dec 28, 2011 6:55 pm    Post subject: Reply with quote
check the relays. There are two of them. one is located in the engine compartment on the left side. It will be the first one on the left. The second relay is located under the dash. It is right next to the master cylinder
v dub boy
PostPosted: Thu Dec 29, 2011 5:26 pm    Post subject: Reply with quote
thanks for the tip relays good it was a hard broken wire about half way between both pump and the relay
(0⎝ i ⎠0)
