vwbug14 Samba Member
Posted: Sun Jan 08, 2012 12:28 pm Post subject: Gas keeps flowing into Caen when I turn off engine |
Well I guess the subject says it all.
1600 DP. Single carb 34 3 pict. Just rebuilt and put on today. Started fine, ran fine and warmed up. Stalled when it got warmed up and I shut it off and I could hear gurgling coming from the carb. I popped off the air filter and the gas was still flowing into carb. Mechanical stock feul pump.
Before I pull it off Any thoughts??
I was thinking cut off valve stuck. How do I check it??
Mike |
buguy Samba Member
Joined: November 17, 2003 Posts: 4915 Location: Port Orange, FL
Posted: Sun Jan 08, 2012 12:33 pm Post subject: |
What is a Caen? |
Posted: Sun Jan 08, 2012 12:41 pm Post subject: |
Oops. Carb. |
Eric&Barb Samba Member
Joined: September 19, 2004 Posts: 24736 Location: Olympia Wash Rinse & Repeat
Posted: Sun Jan 08, 2012 1:28 pm Post subject: |
Probably too heavy or cracked float or sticking float shut off valve in the carb.
Could be too much fuel pressure from the fuel pump, but that should stop pretty quickly after shutting off the engine. _________________ In Stereo, Where Available! |
Nwilgus Samba Member
Joined: May 18, 2011 Posts: 124 Location: Arkansas, USA
Posted: Sun Jan 08, 2012 7:01 pm Post subject: |
buguy wrote: |
What is a Caen? |
Caen is a town on the north coast of France, but that's irrelevant.
As to the OPs question, a cracked float sounds right.
might check out this site, its a great resource: http://www.vw-resource.com/index.html |
Michael Fischer Samba Member
Joined: April 20, 2004 Posts: 1585 Location: Salem, OR
Posted: Sun Jan 08, 2012 7:41 pm Post subject: |
Bad float or bad needle and seat. |
buguy Samba Member
Posted: Sun Jan 08, 2012 10:41 pm Post subject: |
Not necessarily bad needle and seat....could just be trash in it. First thing I would do is pull it apart and inspect everything and clean it reeeeeally well. Then again....if its apart...a needle and seat cant be expensive to simply replace. I hate doing shit twice. |
Posted: Sun Jan 08, 2012 10:49 pm Post subject: |
Have been a lot of reports that the new shut off valves are junk. So best to keep old shut off valve just in case..... _________________ In Stereo, Where Available! |
