rodpoa Samba Member
Joined: September 17, 2008 Posts: 4 Location: Porto Alegre-Rio Grande do Sul, Brazil.
Posted: Wed Sep 17, 2008 1:32 pm Post subject: 78' GTS Puma owner from Brazil |
Hello all,
I'm a Puma enthusiat from Brazil. I'd just like to know that if you need any information regarding Puma you can count on me. If you are searching for the original standards in order to restore an old Puma I can help.
Fiber Hugs from Brazil,
Rodrigo Almeida |
Heffy Samba Member
Joined: August 26, 2008 Posts: 4 Location: San Diego, CA
Posted: Wed Apr 15, 2009 11:54 am Post subject: Puma GTC |
Rodrigo
I just purchased a PUMA GTC. It is being delivered shortly. I appreciate your contact.
Jeff |
rodpoa Samba Member
Posted: Wed Apr 15, 2009 11:56 am Post subject: |
Hi Heffy,
I'm following up this topic. You can leave a reply anytime and I'll get in touch as soon as I can. |
miragtop62 Banned
Joined: April 25, 2009 Posts: 35 Location: South America
Posted: Sun Apr 26, 2009 3:04 pm Post subject: Re: Puma GTC |
| Heffy wrote: | Rodrigo
Jeff |
Congratulations!
Its a good car! |
Fusca65 Samba Member
Posted: Sun Apr 26, 2009 8:13 pm Post subject: |
| good buy, friend, and good look with the Puma ! Here in my city, Brasilia, capital of the Brasil, have a Club of Puma, with various cars. |
RZAR Samba Member
Posted: Mon May 25, 2009 3:28 am Post subject: |
| Where can i buy a Puma? |
Heffy Samba Member
Posted: Mon May 25, 2009 8:38 am Post subject: 80's Puma |
I have the GTC and the wiring is a mess. Does anyone have a wiring diagram for the 1980 version?
Thanks for the help to all my new friends!
Jeff |
Heffy Samba Member
Posted: Sun May 31, 2009 8:47 am Post subject: 80 Puma GtC |
Rodrigo
Do you know who made the rocker switches (3) on the lower left panel of the steering column? I have front lights running lights but no rears and the switch is missing. Interior lights come on with running lights.
Thanks for any information you can supply!
Jeff [email protected][/img] |
timskintight Samba Member
Joined: November 10, 2009 Posts: 1 Location: newcastle UK
Posted: Wed Nov 11, 2009 6:34 am Post subject: Re: 78' GTS Puma owner from Brazil |
| Hi, I'm a Datsun 240,260z fan from UK. Hoping to own a PUMA very soon!! Glad to find a site with like-minded enthusiasts. Keep the info coming! |
carlos_magnum Samba Member
Posted: Thu Dec 10, 2009 2:22 am Post subject: |
| I remember that my old friend had a VW-engined Puma. |
rodpoa Samba Member
Posted: Wed May 19, 2010 11:50 am Post subject: Re: 80 Puma GtC |
sorry for the very late reply.
It's VWs. Mine came from VW Brasilia which should be the very same used in Beetle.
If you have an earlier version, it came from Karmann Ghia. |
jimmydnet Samba Member
Posted: Thu May 20, 2010 5:31 pm Post subject: Full flow oil filter on my 83 Puma GTC? |
Hi Rodrigo,
I know I have a lot of questions and am thankful for any you can answer.
I have a yellow 1983 GTC. It is in good shape and I believe that everything is stock.
Do you know if I can add this full flow oil pump on this page?
http://www.thesamba.com/vw/classifieds/detail.php?id=84077
The alt stand from this page
http://www.thesamba.com/vw/classifieds/detail.php?id=519841
I really want to add the Mexican EFI with the electronic distributor, coil, idle valve etc. Do you know anyone who has done this?
Thank you |
rodpoa Samba Member
Posted: Thu Jun 23, 2011 2:07 pm Post subject: |
Hi Jimmy,
I'm really sorry for the very long delay. Did you already figure this out or still need help?
Sorry again and thanks! |
dancinbare1 Samba Member
Joined: January 16, 2005 Posts: 177 Location: San Bernardino SoCalif
Posted: Sat Nov 12, 2011 1:29 pm Post subject: |
Hello, where can I get the brake and clutch pedal pads? the pedals have a smaller surface so bug pads are very loose and slip off.
Thanks Scott _________________ Nothing Exceeds Like Excess!!!
www.pedalwerks.com
07' Rabbit
59' Single Cab
57' Oval Baja Ragtop (To save )
57' Oval hard top
55' Oval hard top |
Root_Werks Samba Member
Joined: December 31, 2007 Posts: 328 Location: Seattle-ish
Posted: Thu Dec 22, 2011 9:25 am Post subject: |
| dancinbare1 wrote: | Hello, where can I get the brake and clutch pedal pads? the pedals have a smaller surface so bug pads are very loose and slip off.
Thanks Scott |
Rabbit ones work great. _________________ When I set my timing, why do I flush, then take a pee? |
Posted: Thu Dec 22, 2011 9:27 am Post subject: |
Since we are sharing, here is my 85' GTI with a 2275cc, 42 DCNF's, full flow, big heads, etc, etc and 3.88 R&P so 200kph comes very quick.
Posted: Thu Dec 22, 2011 9:46 am Post subject: |
Thanks, for the Info, and very nice Puma, Scott
www.pedalwerks.com
07' Rabbit
59' Single Cab
57' Oval hard top
55' Oval hard top |
Posted: Thu Dec 22, 2011 10:43 am Post subject: |
Nice clutch update. I wondered if I should have done that to mine. I just replaced the clutch and accel cables the other week because the PO had stock T-1 cables cut and clamped. Nice to have proper length Puma cables back in. I probably should have upgraded the clutch arm at that time.
Interesting on your cluster it looks all metal. Mine is cast alum with only metal arms/pedals. _________________ When I set my timing, why do I flush, then take a pee? |
Posted: Thu Dec 22, 2011 8:32 pm Post subject: |
| Root_Werks wrote: | Nice clutch update. I wondered if I should have done that to mine. I just replaced the clutch and accel cables the other week because the PO had stock T-1 cables cut and clamped. Nice to have proper length Puma cables back in. I probably should have upgraded the clutch arm at that time.
Interesting on your cluster it looks all metal. Mine is cast alum with only metal arms/pedals. |
It is an Orignal Puma set I was sent to restore, It has had my "Bulletproofing" done to it like box in the clutch pedal Etc.,
the Gas Pedal Is a Fast Fab billet replacement, and the Clutch hook is a CMA-VW.com stainless steel Heim set up, cables are availiable in any length, and are good up to 3000#.
the arms are steel and the base is Magnesium,
www.pedalwerks.com
07' Rabbit
59' Single Cab
57' Oval hard top
55' Oval hard top |
VWporscheGT3 Samba Member
Joined: September 01, 2006 Posts: 910 Location: Gardnerville, NV
Posted: Tue Jan 10, 2012 3:38 pm Post subject: |
My Friend Eric is the Owner Of CMA-VW, Ive seen these in person , their beautiful and i cant wait to update the 71 Beetle with one of his setups. Eric knows his stuff and what he sells was well thought out... i guess thats as far as i will go. Nice PUMA by the way _________________ 69 Fasty
71 Beetle
you wanna save something truly special... Restore a Fastback! |
