How to Temp Patch a Hole in the Exaust
Forum Index -> Vanagon/Eurovan Share: Facebook Twitter
leadbettr
leadbettr is offline
PostPosted: Sun Jan 22, 2012 5:52 pm    Post subject: How to Temp Patch a Hole in the Exaust Reply with quote
My van happens to have the EGR system removed right now.
So there's a hole in the exhaust system just before the catalytic converter and it's creating quite a bit of racket.
Until I get the EGR system back in order I'd like to put a temporary plug or cover on the hole to limit the noise.
Anyone have any thoughts?
I thought I'd ask for ideas before trying to tackle it myself.
I know it gets quite hot down there so that limits my options.
Thanks!
danfromsyr
danfromsyr is offline
PostPosted: Sun Jan 22, 2012 6:01 pm    Post subject: Reply with quote
band clamp small piece of metal and some high temp gasket material.
VW Club of Central New York SPRING VW GTG
Upstate NY 2013 VWCCNY events
NY State VW Camping 2013 season events
seanjenn
seanjenn is offline
PostPosted: Sun Jan 22, 2012 6:08 pm    Post subject: Reply with quote
Hah! Damn. Beat me to it.
Great VW minds clearly think alike Cool
1984 Westy 2 Dubya D
1.9L 4spd
God thinks he's Eddy Merckx
leadbettr
PostPosted: Sun Jan 22, 2012 7:55 pm    Post subject: Reply with quote
Thanks!
May I ask what a Band Clamp is?
82WestyMan
82WestyMan is offline
PostPosted: Sun Jan 22, 2012 8:00 pm    Post subject: Reply with quote
leadbettr wrote:
Thanks!
a large radiator hose clamp will work, just something to keep the piece of metal in place
"The floggings will continue until morale improves"
"I never did give anybody hell. I just told the truth and they thought it was hell" - Harry S. Truman
82 Westfalia - w/ a Raby 'Camper Special' engine
Terry Kay
Terry Kay is offline
PostPosted: Sun Jan 22, 2012 9:44 pm    Post subject: Reply with quote
Clamp.
T.K.
http://community.webtv.net/VanStuff/VanagonWestfalia
http://community.webtv.net/VanagonUsedParts/VanagonParts
"Ingorance Is A Powerful Tool If applied at The Right Time, Even Usually Surpassing Knowledge"
(E.J. Potter)
leadbettr
PostPosted: Sun Jan 22, 2012 11:35 pm    Post subject: Reply with quote
I can't see your picture in your post
Love My Westy
Love My Westy is offline
PostPosted: Sun Jan 22, 2012 11:51 pm    Post subject: Reply with quote
Whatever you do, don't use that epoxy stuff you can buy at you flaps to repair exhaust leaks. I tried it and it almost killed me with the smell. It also cracked and fell off.
reluctantartist
reluctantartist is offline
PostPosted: Mon Jan 23, 2012 12:30 am    Post subject: Reply with quote
I made a block off plate and used the existing bolts and gasket. Are the bolts still attached to the heat exchanger?
1982 Westy, 1974 412 Variant... Yes, Aircooled's are great! Oh and I do have modern computer controlled vehicles too, but I just don't care about them.
gary1998
gary1998 is offline
PostPosted: Mon Jan 23, 2012 1:18 am    Post subject: Reply with quote
http://www.windsorchair.co.uk/vwpictures/AEFEngine/2010_0422blankoilfiller.JPG
loud pipes save lives
leadbettr
PostPosted: Mon Jan 23, 2012 6:22 am    Post subject: Reply with quote
Nah, it seems the system broke off and the whole interface down there is all rusted over.
reluctantartist
PostPosted: Mon Jan 23, 2012 7:25 am    Post subject: Reply with quote
You might get away with using permatex copper silicone in place of the gasket and then make a bracket.
leadbettr
PostPosted: Tue Jan 24, 2012 2:58 am    Post subject: Reply with quote
So you'd need a seal in addition to the metal?
reluctantartist
PostPosted: Tue Jan 24, 2012 7:31 am    Post subject: Reply with quote
If you don't then you will likely have an exhaust leak. Are you in a location where you will be smogged? Are you sure that the EGR valve is sealed at the air distributor, this will cause a vacuum leak of it is not. If you don't need the EGR it would be better to block off the place on the exhaust and make a plate for where the EGR attaches to the air distributor.
leadbettr
PostPosted: Sat Mar 10, 2012 3:27 pm    Post subject: Reply with quote
Yep It's blocked off a the air dist. It's blocked by the valve that seems to be frozen in place, both the valve itself and the hex screws holding it in place. I'm hoping I won't need to remove it anytime soon.
As for the exhaust end I used a clamp and just some aluminum foil to cover the hole.
It defiantly has reduced the noise.
1981 Aircooled Stock Country Homes Camper Vanagon w/Oil radiator, Oil Temp and Bentley manual
I'm a owner with pretty good mechanical skills and not the greatest diagnostic skills.
"Do what you can, with what you've got, where you are." -TR
70coupyel
70coupyel is offline
PostPosted: Sat Mar 10, 2012 7:58 pm    Post subject: Reply with quote
Dude if you post some pictures that would help a lot. Smile
TheAndante wrote:
Saying that specs are different than dimensions doesn't make sense. Porsche specs/VW specs/engineering specs are nothing but a series of dimensions,sizes,percentages,measurements, etc.
70 KG Coup
83 Westy Waterboxer
Tishamingo
Tishamingo is offline
PostPosted: Mon Mar 12, 2012 6:19 pm    Post subject: gonna watch this thread Reply with quote
my van became really loud today on the way to work, almost as if someone took the cat off my westy Sad Have meetings tonight and hope to pull it in a dry greenhouse at work tomm to take a look at it. So yeah, might need some expertise on the situation.
BTW I have seen a few links to exploded diagrams of the systems on the Vans. Does anyone have a handy link to a 1986 Watercooled exhaust system? The Haynes didn't have much and the Bentley is not with me right now.
Thanks guys
Ahwahnee
Ahwahnee is online now
PostPosted: Mon Mar 12, 2012 6:37 pm    Post subject: Re: gonna watch this thread Reply with quote
Tishamingo wrote:
...BTW I have seen a few links to exploded diagrams of the systems on the Vans. Does anyone have a handy link to a 1986 Watercooled exhaust system?
Try the Bus Boys site, crude but effective:
http://www.bus-boys.com/
You'll need to scroll down the left hand menu.
Reply to topic    Forum Index -> Vanagon/Eurovan All times are Mountain Standard Time/Pacific Daylight Savings Time
