turbomicrowaves Samba Member
Posted: Fri Feb 03, 2012 12:37 pm Post subject: Turning a '68 US spec square into an N model |
So, I'm thinking about taking my squareback and making it an N model squareback. Here's a list of what I know has to change:
Body:
remove side trim/fill holes
remove hood trim/fill holes
remove passenger door mirror/fill hole
remove pop out windows
paint vent window frames
paint reflector housings
install flat taillight lenses
install sidemarkers (optional)
remove bumper guards
remove rear emblems/install vw1600 and variant emblems
Interior:
remove clock/install clock delete
remove passenger sunvisor
Anything else that I'm forgetting? Are there any '68 specific changes that I should be aware of? _________________ '68 Sunroof Squareback
"There are no pieces"
OCT3 - Orange County Type 3's |
supaninja Samba Member
Posted: Fri Feb 03, 2012 1:05 pm Post subject: |
| supaninja wrote: |
| Aren't the door panels different too? |
I know they are on earlier cars. '64 through '67 have bug door pulls instead of the Z armrests. I probably wont stick to the N model interior. _________________ '68 Sunroof Squareback
Posted: Fri Feb 03, 2012 1:06 pm Post subject: |
Also, I know about the engine being a single side draft. _________________ '68 Sunroof Squareback
notchboy Samba Member
Joined: April 27, 2002 Posts: 11440 Location: Seattle WA
Posted: Fri Feb 03, 2012 1:12 pm Post subject: |
Do you want it to be a 68 standard or an ealier version?
You can keep the pass mirror-squareback Ns that Ive seen have the mirror or a block off plug. _________________ Jason "notchboy" Weigel
1964 T34 S Convertible
1974 Westfalia Hardtop Campmobile
1977 Westfalia Camper pop-top
the1500club.com
TOOB Member #5 |
Posted: Fri Feb 03, 2012 1:13 pm Post subject: |
| notchboy wrote: |
You can keep the pass mirror-squareback Ns that Ive seen have the mirror or a block off plug. |
'68 standard. I've seen the door plugs, but don't have one. What about the passenger door lock? _________________ '68 Sunroof Squareback
Bobnotch Samba Member
Joined: July 06, 2003 Posts: 10695 Location: Kimball, Mi
Posted: Fri Feb 03, 2012 1:53 pm Post subject: |
| turbomicrowaves wrote: |
| notchboy wrote: |
'68 standard. I've seen the door plugs, but don't have one. What about the passenger door lock? |
Isn't it built into the door handle?
So you're actually trying to make an "A"? Just asking, because there are no "N"'s after 65. An "A" would be a standard stripped down model like the "N" was, complete with rubber floor mats in place of carpets. Also, an "N" would have a prop rod for the front trunk (in a Square), but after 64, the prop rod was discontinued (at both ends), so it must have just gotten cheaper to make them standard WITH springs.  _________________ Bob 65 Notch S with Sunroof
71 Notch ...aka Krunchy; build pics here; http://www.thesamba.com/vw/forum/viewtopic.php?t=240540 -tear down
64 T-34 Ghia...aka Wolfie, under construction... http://www.thesamba.com/vw/forum/viewtopic.php?t=412120 |
Posted: Fri Feb 03, 2012 2:00 pm Post subject: |
| Bobnotch wrote: |
| notchboy wrote: |
So you're actually trying to make an "A"? Just asking, because there are no "N"'s after 65. An "A" would be a standard stripped down model like the "N" was, complete with rubber floor mats in place of carpets. Also, an "N" would have a prop rod for the front trunk (in a Square), but after 64, the prop rod was discontinued (at both ends), so it must have just gotten cheaper to make them standard WITH springs.  |
I guess an A model then. And yes, the lock is built into the handle that's why I was asking about them. _________________ '68 Sunroof Squareback
OhHerrooo Samba Member
Joined: September 12, 2010 Posts: 1016 Location: Costa Mesa, CA
Posted: Fri Feb 03, 2012 2:09 pm Post subject: |
Later types standards end up having more in common with regulars. Like chrome wing windows and rear reflectors. No pass arm rest, clock block, no side pad in the trunks.
We need to look over the manuals. _________________ Jason "notchboy" Weigel
the1500club.com
TOOB Member #5 |
Posted: Fri Feb 03, 2012 2:10 pm Post subject: |
| notchboy wrote: |
We need to look over the manuals. |
The only brochure I have is for '64. _________________ '68 Sunroof Squareback
Posted: Fri Feb 03, 2012 2:15 pm Post subject: |
The later stuff was more about motors than trim. I had a 71 standard fasty. It only had the clock block, no pass arm rest, no pass visor and some plugs in the dash for the cig lighter and what not. The rest was same as a reg T3.
There is a 67 many here on the samba but its not much help. _________________ Jason "notchboy" Weigel
the1500club.com
TOOB Member #5 |
Posted: Fri Feb 03, 2012 2:17 pm Post subject: |
So, the "N" model option was only available until '65? _________________ '68 Sunroof Squareback
Posted: Fri Feb 03, 2012 2:23 pm Post subject: |
| So, the "N" model option was only available until '65? |
Yeah, after that, they became "A' or standard models. Those were mainly built for the "home" market, as they were entry level t-3s. However, countries like England got them too, due the the higher tax rate of the more equipped cars. You might want to contact Dave Hall thru the UK type3 and 4 club, as I'm sure he could give you more info on them.
Edit; here's a link to the UK version of the Samba.
http://www.vwtype3and4club.org.uk/forum/ Dave's the administrator.  _________________ Bob 65 Notch S with Sunroof
vwfye Samba Member
Joined: April 15, 2000 Posts: 5504 Location: Where it all began
Posted: Fri Feb 03, 2012 2:31 pm Post subject: |
| Bobnotch wrote: |
| vwfye wrote: |
| did the A version have non-chrome window vent wings, the side markers in a different location, non chrome window trim like the N model did? |
I believe so. I think they also had cloth seats, as they were cheaper to do than vinyl. Either that, or they used a smooth type of vinyl for the seats. Remember they were the stripper or entry level T-3, so where ever they could shave on cost, they did. |
What's weird is that you could still get a base model with a sunroof. _________________ '68 Sunroof Squareback
Posted: Fri Feb 03, 2012 2:34 pm Post subject: |
| Bobnotch wrote: |
| vwfye wrote: |
What's weird is that you could still get a base model with a sunroof. |
Yup, and you could get an "N" with a sunroof too.  _________________ Bob 65 Notch S with Sunroof
Posted: Fri Feb 03, 2012 2:35 pm Post subject: |
| Bobnotch wrote: |
| Bobnotch wrote: |
| vwfye wrote: |
Yup, and you could get an "N" with a sunroof too.  |
I have a sunroof. I'd still like an n model. _________________ '68 Sunroof Squareback
69SquareGuy Samba Member
Joined: August 23, 2004 Posts: 2169 Location: Orange, CA
Posted: Fri Feb 03, 2012 6:56 pm Post subject: |
If you're sticking with Diamond Blue, I would leave the vent windows chrome but I would still paint the rear reflectors. _________________ '65 Squareback - Sally
'68 Beetle - My daily driver
'70 Deluxe Baywindow - Work in progress.
OCT3 - Orange County Type 3s
WCB - West Coast Bays
http://www.facebook.com/OrangeCountyType3s |
