Top speed of a 86 Vw Gti? Stock!
Forum Index -> Water-cooled VW Share: Facebook Twitter
vdub86
vdub86 is offline
PostPosted: Thu Feb 09, 2012 10:31 pm    Post subject: Top speed of a 86 Vw Gti? Stock! Reply with quote
Does any one k ow what should be the top speed of a 1986 Vw Golf Gti? My car pretty much won't go above 65mph. 70mph is pretty much pushing it. I was wondering if that's normal speed or if there might be a problem with the tranny or clutch?? Help! Any one? Crying or Very sad
PostPosted: Thu Feb 09, 2012 10:55 pm    Post subject: Reply with quote
I don't know what's wrong but that doesn't sound right.
Are you using 4th and 5th gears? Smile
How to: Post Photos | Search
Everett Barnes - [email protected] | My VWs | My wanted ads
vdub86
vdub86 is offline
PostPosted: Fri Feb 10, 2012 5:41 am    Post subject: Yes! Reply with quote
Its a manual transaxle! Tried adjusting clutch cable to see if it was that but no luck!!
Derek Cobb
Annoying
Derek Cobb is offline
PostPosted: Fri Feb 10, 2012 6:18 am    Post subject: Reply with quote
Yeah, somethings not right. I had mine over 110 mph on a few occasions.
vdub86
vdub86 is offline
PostPosted: Fri Feb 10, 2012 7:14 am    Post subject: Reply with quote
I know. Its weird. It goes up to 70mph max at 3100 rpm. Weird cuz it sounds like it's asking for another gear. I barely got this car not to long ago. Wanted to check the tranny fluid. Any idea where to check that?
vdub86
vdub86 is offline
PostPosted: Fri Feb 10, 2012 7:18 am    Post subject: Reply with quote
I could step on the gas more but feels and sounds like if rpm are too high and need to change gear. I think normal would be 80-90 mph w/0 struggle!
zuhaelter_82
zuhaelter_82 is offline
PostPosted: Fri Feb 10, 2012 12:00 pm    Post subject: Reply with quote
It is a 5 speed correct? You should be able to hit 60 mph in third gear. If you are in fifth and it won't go past 70, your timing may be off. If it's a non interference motor, the timing belt could be off a tooth or the distributor could be off.
Pull the timing cover off the head, roll it to TDC and look in the hole in the transmission. The hole may have a green plug in it that needs to be removed. All of your timing marks should line up.
Also, there is this...
http://forums.vwvortex.com/showthread.php?2690954-Won-t-rev-past-3500&highlight=won%27t+past+70
59 Single Cab, 64 Type II, A3 GLX, A4 GLS, B5 GLS
vdub86
vdub86 is offline
PostPosted: Sat Feb 11, 2012 11:40 am    Post subject: :( Reply with quote
@ zuhaelter_82
I tried doing what you send me on the link. Does have a flap that you can raise/push up but comes back down. wont stay open. Is that suppose to happen or should it stay up?Crying or Very sad Getting ready to try the timing on it. Gonna check to see if all the timing mark are all on point. Lets see how that goes!!
flemcadiddlehopper
flemcadiddlehopper is offline
PostPosted: Sat Feb 11, 2012 2:06 pm    Post subject: Reply with quote
I am confused by your question. Is it that your car just can't pull hard enough to go that fast or, is it wound right out and you've run out of legs to go any faster (gearing).
My 1984 GTI (all stock except exhaust) winds right out at 150-160 km/hr, that's right around 100mph....that's it.
Reply to topic    Forum Index -> Water-cooled VW All times are Mountain Standard Time/Pacific Daylight Savings Time
