Desertbusman Samba Member
Posted: Fri Feb 10, 2012 1:26 am Post subject: |
Whoa
I see you edited your first post. And you engine is off to the builder. But you don't even know what you want yet. So was the plan that he was going to rebuild your engine or just take it in as a core trade in?
His add looked good. The conversion to a doghouse shroud and cooler is excellent and about the best thing you could do. That was only stock on a '71.
Now you're considering a dual port. Here's the deal- Evidently you didn't study the Wilson book to understand all the different changes on these engines. A dual port was first on a '71 and takes different cylinder heads, different cylinder tins, different intake manifold, and a different single stock carburator. And it was built on a '71 dual relief case. It develops more power. You don't just slap on a dual port.
Suggest you get quickly knowledgable and then talk with the builder before he starts doing anything.
Also here would be my suggestion for what kind of a basic engine you should have him build.
-1600 dual port, doghouse, on a dual relief, bus case (with the bus mounting holes).
-Highly preferable if he uses a later than '71 case with 8 mm head studs and case savers. Versus the earlier 10 mm studs. (less problems later)
-Have him machine the fullflow port per the normal standards.
-Have him plug the new pump and put on the fullflow pump cover. (Berg cover with it's supplied fitting probably will be your easiest and best.)
-For the engine to be smoother and last longer it wants to be balanced. Dynamic balance on the rotating group and weight balanced on the rods and pistons.
-Have him put on an aftermarket degree pulley right at the beginning instead of a stock pulley. It will save you and your engine much grief when you tune your engine. Cheap EMPI is fine, around $25.
Optional:
-Have him build it with a header instead of the stock muffler. Then once you install it put on a single quiet pack. Engine will breathe a lot healthier and probably not any more expensive than a stock muffler.
-Consider a mild bus cam versus stock. He's going to put in a new cam and lifters anyway so an upgrade to something like an Engle W-100 is a small deal.
Forget about filter adapter, fittings, hoses, etc. at this point. You do that when you install the engine. Your question about a $3 Ace hardware 45 degree fitting is the very least of any of your concerns for a long time.
Hope that helps get you on course. Once you work out all the specific details with the builder you can let us know. get the Tom Wilson book now, not later.  _________________ The best thing that anyone can do for their Bay is get the Volkswagen of America Official Service Manual published by Robert Bentley. Without it the bus is pretty much doomed.
| 73kombi wrote: | | when that red light goes on, you have to make a choice. | | Amskeptic wrote: | I am not answering that.
Respectfully,
GoBuyABentley |
71 Superbug
71 Westy |
ccpalmer  Samba Member
Joined: September 17, 2006 Posts: 3518 Location: Ann Arbor, Michigan
Posted: Fri Feb 10, 2012 8:33 am Post subject: |
All excellent advice there. Get your engine basics worked out before getting into details. My recommendation would be to either stay stock or do a lot of reading and decide whether you want to kick up up a notch.
Not much difference between a single and dual port engine; I wouldn't worry too much about it if you stay stock. But if you want to kick things up a dual port would be a better base; just my 2 cents though. Many opinions.
But even on a stock motor make sure things get balanced and follow DBM's other basic advice about studs, bus case, full flow, camshafts. These things can only be done in the build-up. Pulleys, exhaust can be changed later.
And the filter location is very low on your to-do list - but having ducks in a row is a good thing. Here's how I did mine - just took a simple piece of aluminum stock and some drill bits and it mounts into stock threaded holes in the frame, no drilling/tapping needed on your vehicle.
 _________________ '71 Westy
'77 Bay/rusty shed on wheels
Chris Palmer
Cocobolo Co., LLC
ccpalmer.com |
Kursive Samba Member
Joined: January 08, 2009 Posts: 101 Location: Top to Bottom, CA
Posted: Sat Feb 11, 2012 3:01 am Post subject: |
I spoke with him today; he will be starting work on the engine sometime next week, I will get back to him on Monday with the parts I decide to order myself for installation.
So for the Full Flow, either the Geneburg Full Flow Kit, or I recently saw this one on ebay from SSS, with special steel oil pump cover and other high quality parts. Worth the extra $20? Billy still says the whole Full Flow is near useless, says the filter is useless on stock and doesn't see the need.
Degree pulley I believe he said he had one in stock, as well as some headers he pulled recently he would throw on mine. Cam, I'll invest in that a bit later I believe, though soon I'm sure. I would like to be able to notice the improvement before / after.
As for the case, he said it seems to be a dual relief already. I vaguely remember the PO mentioning the rebuild was a later case, but wasn't sure, seems now to be true! Would this also mean it is dual port? _________________ 1969 Westfalia Camper
M-Code |
Posted: Sat Feb 11, 2012 9:14 am Post subject: |
| Kursive wrote: |
As for the case, he said it seems to be a dual relief already. I vaguely remember the PO mentioning the rebuild was a later case, but wasn't sure, seems now to be true! Would this also mean it is dual port? |
No; dual port heads/tins/manifolds can be put on either single or "dual" relief cases. _________________ '71 Westy
Chris Palmer
Cocobolo Co., LLC
ccpalmer.com |
Posted: Sat Feb 11, 2012 9:17 am Post subject: |
| Kursive wrote: |
Cam, I'll invest in that a bit later I believe, though soon I'm sure. I would like to be able to notice the improvement before / after. |
Your cam will have to be chosen before engine build (when you know your heads/carbs/exhaust components), and to change it you would have to split the case again... _________________ '71 Westy
Chris Palmer
Cocobolo Co., LLC
ccpalmer.com |
Posted: Sat Feb 11, 2012 10:41 am Post subject: |
Didn't you already tell us your engine was a single port? And the add you linked is a single port.
With the cam it's basically now or never.
With the FF kit- Like before, NO, not recommended. The Egay cover NO NO. Like before, the Berg cover is the good one for you.
Ask Billy why any other car and every other significant engine everywhere uses a filter.  _________________ The best thing that anyone can do for their Bay is get the Volkswagen of America Official Service Manual published by Robert Bentley. Without it the bus is pretty much doomed.
Respectfully,
GoBuyABentley |
71 Superbug
71 Westy |
Posted: Sat Feb 11, 2012 10:16 pm Post subject: |
Not so sure anymore about the single port, the PO didn't give me much information on the rebuild. I'll try and determine this on Monday.
So I think my final plan, for now, is to do the FF and the Engle W-100 Cam (which he also suggested was useless). If it is, in fact, dual port, would it not be good to get these things set in place in case I decide to go dual carb in the next few years? Besides, seems the FF and Cam are useful regardless.
I think I will stick with the Geneburg FF Kit, as well as the Engle W-100 Cam they offer. _________________ 1969 Westfalia Camper
M-Code
Posted: Sun Feb 12, 2012 6:01 am Post subject: |
| Kursive wrote: | Not so sure anymore about the single port, the PO didn't give me much information on the rebuild. I'll try and determine this on Monday.
I think I will stick with the Geneburg FF Kit, as well as the Engle W-100 Cam they offer. |
Can't go wrong with the Gene Berg and Engle 100. Dual carbs can be added later without much trouble; but you will need to remove your air cleaner stand for dual carbs; easier now than later.. _________________ '71 Westy
Chris Palmer
Cocobolo Co., LLC
ccpalmer.com |
Posted: Sun Feb 12, 2012 7:39 am Post subject: |
With the addition of the Engle W-100 Cam, will any other changes be needed to accommodate? _________________ 1969 Westfalia Camper
M-Code |
Posted: Sun Feb 12, 2012 8:12 am Post subject: |
| Kursive wrote: | | With the addition of the Engle W-100 Cam, will any other changes be needed to accommodate? |
Nope _________________ '71 Westy
Chris Palmer
Cocobolo Co., LLC
ccpalmer.com |
Posted: Mon Feb 13, 2012 5:38 pm Post subject: |
Ok cool
Well I am back home and am going to be working to prepare the engine bay for the rebuilt engine.
So far, I plan to completely clean, replace rubber seals, fuel hoses, heater hoses, and whatever else I hopefully find.
Also, will do some rubber spray insulation? Not sure about that yet, but the builder mentioned a simple spray to assist in noise reduction.
Any other suggestions for the engine bay while it's open and serviceable?  _________________ 1969 Westfalia Camper
M-Code |
Posted: Fri Feb 17, 2012 9:11 pm Post subject: |
A few noob questions if anyone can answer..
I've seen a few mentions of 1.1 or 1.2(5?) rockers needed to get the benefit of the Engle W-100, is this true? If so, all I have been able to find are shims for adjusting
Anyway, seems engine may be a bit longer in the making; seems the man he was helping out originally in my area (when he picked up my motor) needs more work than expected, no worries though, I'm just happy it's finally in the works  _________________ 1969 Westfalia Camper
M-Code |
Posted: Fri Feb 17, 2012 9:40 pm Post subject: |
You can get additional benefit with aftermarket ratio rockers. However I use stock rockers with my W-100 and enjoy that benefit.
And I use swivel ball adjusters and solid rocker arm shafts for a bit more dependability and valve train life.
Even though you have a bus, the engine is actually a bug engine. That means you have an endless list of suppliers of engine components. Such as Chirco, CB Performance, SoCal Imports, etc. _________________ The best thing that anyone can do for their Bay is get the Volkswagen of America Official Service Manual published by Robert Bentley. Without it the bus is pretty much doomed.
Respectfully,
GoBuyABentley |
71 Superbug
71 Westy |
Posted: Mon Feb 20, 2012 3:57 pm Post subject: |
Alright, getting to the cleaning out. Degreaser and old scrub brush and elbow grease..
Here's a few pictures of the engine compartment
[/img] _________________ 1969 Westfalia Camper
M-Code |
Posted: Fri Feb 24, 2012 5:30 am Post subject: |
Finished cleaning the engine compartment, didn't get the firewall removed (pretty stuck on w/o screws, seal glue?), which was okay because I ended up barely having time to finish what I did do.
Flying out early today, will order seals while I'm away and install them before the engine returns. Also need fuel lines.
the tools (minus a toothbrush I utilized near the end)
and after
the worst rust so far, bit of a hole (dark 8 in the shade)
also, just remembered, the top of the compartment has old, dried rubber mats. Awfully stiff, will need to be replaced? Or a substitute; have been hearing about 'rubber spray', think that would substitute the old mats, or just extra measure?
Will have to research a bit of soundproofing further. _________________ 1969 Westfalia Camper
M-Code |
aryue Samba Member
Joined: January 16, 2006 Posts: 690 Location: Austin, TX
Posted: Fri Feb 24, 2012 9:56 am Post subject: |
Yipes - I'll need to spend a day cleaning my engine compartment - the next time I pull the motor. That looks much nicer than mine.
- Andrew in Austin, TX - _________________ OldandSlow - but still chuggin.
http://www.ph.utexas.edu/~yue/VW/VWBus.html |
Posted: Mon Feb 27, 2012 2:55 am Post subject: |
| aryue wrote: | | Yipes - I'll need to spend a day cleaning my engine compartment - the next time I pull the motor. |
It takes some time but it's definitely worth it when you have the chance
I'm trying to figure out exactly what seals I need for the engine compartment to have it completely renewed. I have been looking into it for a while, and am not quite sure about what I need..
So far I have mamotorworks engine to body rear, 2x engine side seals, firewall seal, compartment seal.
Will this cover it / are they the proper seals? If higher quality sources are known, please let me know  _________________ 1969 Westfalia Camper
M-Code |
Posted: Tue Feb 28, 2012 5:00 pm Post subject: |
I'm going to go for it and get those seals, pretty sure they fit, just hope it's all I need.
Now I think I need to get heater hose parts, as well as replace the fuel lines for safety.
There was a fuel filter? in the engine compartment, literally just hanging from the fuel lines, no clamp on either side. Not sure if that is necessary, but surely not safe. _________________ 1969 Westfalia Camper
M-Code |
Posted: Thu Mar 01, 2012 2:15 pm Post subject: |
Now I'm looking more into preparing the bus all around to return to the road.
So far, I have the engine seals (hopefully correct firewall, rear seal (x2?) and compartment hatch seal), 5.5mm x 1m cloth braided fuel line; will have to take a look at the brakes, steering, and electrical asap to see if I need any specific replacement parts. New tires as well!
Will have to do plenty of reading to learn all the steps to get it completely ready and safe for the road. Though I do like the comprehensive nature of the Bentley, it is rather technical and specific; learning how to read it and about my VW simultaneously  _________________ 1969 Westfalia Camper
M-Code |
