1973 Campmobile
Goto page 1, 2  Next
Donegood
Donegood is offline
PostPosted: Sun Feb 12, 2012 7:11 pm    Post subject: 1973 Campmobile Reply with quote
I just got a 1973 VW Campmobile with an automatic transmission. When in park if I step on the brake the idle drops to almost a stall and struggles to recover and then back down to almost stalling again. But when I lift off of the brake the idle returns to normal. Would this have anything to do with it being an automatic and its vacuum hoses? Vacuum advance on the distributer? Maybe electrical? If anyone has experienced this before I could use the help.
Thanks! Donegood
crushie
crushie is offline
PostPosted: Sun Feb 12, 2012 7:17 pm    Post subject: Reply with quote
What is the idle rpm in park? Is it at spec?
Donegood
Donegood is offline
PostPosted: Sun Feb 12, 2012 10:47 pm    Post subject: 1973 campmobile Reply with quote
I dont have a tach I just go off of sound but it happens at what ever idle I set it on. Only when I step on the brakes does the idle go down and want to stall.
Desertbusman
Desertbusman is offline
PostPosted: Sun Feb 12, 2012 10:59 pm    Post subject: Reply with quote
Your brake booster is shot! Time to have it rebuilt.
The best thing that anyone can do for their Bay is get the Volkswagen of America Official Service Manual published by Robert Bentley. Without it the bus is pretty much doomed.
73kombi wrote:
when that red light goes on, you have to make a choice.
Amskeptic wrote:
I am not answering that.
Respectfully,
GoBuyABentley
71 Superbug
71 Westy
Kirk Premium Member
Kirk is offline
PostPosted: Mon Feb 13, 2012 6:07 am    Post subject: Reply with quote
x2
Oppenhiem
Bear
Deluxe
Donegood
Donegood is offline
PostPosted: Mon Feb 13, 2012 8:50 pm    Post subject: Reply with quote
It was the brake booster air connector is broken. I'll never find one of those. I'll have to make my own. Any Idea's?
Wildthings
Wildthings is offline
PostPosted: Mon Feb 13, 2012 11:40 pm    Post subject: Reply with quote
What is an air connector? A better description or a picture would help.
busdaddy
busdaddy is offline
PostPosted: Tue Feb 14, 2012 7:42 am    Post subject: Reply with quote
Now what makes you say that?, lets see some pictures.
How to post photos.
Wanted, 68-73 westy OG plaid curtains, singles OK.
Donegood
Donegood is offline
PostPosted: Tue Feb 14, 2012 1:51 pm    Post subject: 1973 Campmobile Reply with quote
I am trying to figure out how to post photo's but I did get one on my photo's.[img]http://www.thesamba.com/vw/forum/album_search.php?search_author=Donegood
[/img]
busdaddy
busdaddy is offline
PostPosted: Tue Feb 14, 2012 1:55 pm    Post subject: Reply with quote
Even at full magnification I can't make it out, is that in the line beside the transmission by any chance?
Donegood
Donegood is offline
PostPosted: Wed Feb 15, 2012 10:29 am    Post subject: 1973 Campmobile Reply with quote
How did you put the picture in the reply? anyways I took a picture of the brake booster and I would like to find the little piece that the pushrod goes through but I dont want to buy a new brake booster if mine is working ok.
Kirk Premium Member
Kirk is offline
PostPosted: Wed Feb 15, 2012 10:34 am    Post subject: Reply with quote
If you can provide a better picture, we can tell you if someone has it or knows where to get the part.
Oppenhiem
Bear
Deluxe
busdaddy
busdaddy is offline
PostPosted: Wed Feb 15, 2012 11:03 am    Post subject: Reply with quote
Is that the fitting on the accordian boot on the front of the brake booster? Not too hard to find used or even manufacture from tubing and JB weld if necessary if it is the atmosphere connection.
To post the photo copy the forum address that shows above it when you open the picture. (it begins and ends with img)
Desertbusman
PostPosted: Wed Feb 15, 2012 11:33 am    Post subject: Reply with quote
If it was just the plastic vent hose connection that wouldn't cause his problems, would it? But if that valve affair is busted up it is a problem.
Respectfully,
GoBuyABentley
71 Superbug
71 Westy
busdaddy
busdaddy is offline
PostPosted: Wed Feb 15, 2012 1:28 pm    Post subject: Reply with quote
No, by itself it wouldn't, but if it was broken for years and allowed the booster to ingest all sorts of water and crap it could be blamed for it in a roundabout way.
Donegood
Donegood is offline
PostPosted: Wed Feb 15, 2012 1:41 pm    Post subject: Reply with quote
ok that cant be it. I followed the hose to a side panel and it just ends everything else on the brake booster looks ok but it still wants to stall when I step on the brake.
busdaddy
busdaddy is offline
PostPosted: Wed Feb 15, 2012 1:44 pm    Post subject: Reply with quote
The next step is disconnect the hose to the booster at the front of the engine (cap off the port on the balance tube) and see if it still quits when you step on the brake. Caution!: no power brakes during this test, braking will require more effort!
Donegood
Donegood is offline
PostPosted: Sat Feb 18, 2012 9:43 am    Post subject: Reply with quote
Got it! Thanks for the help everyone!
Amskeptic
Amskeptic is offline
PostPosted: Sat Feb 18, 2012 9:50 am    Post subject: Reply with quote
But ... what did you get?
Colin
www.itinerant-air-cooled.com
Helping You Keep It Alive For Ten Years Now
greenbus pilot
greenbus pilot is offline
PostPosted: Sat Feb 18, 2012 10:02 pm    Post subject: Reply with quote
Colin
Moral support. Dancing
greenbus pilot out. Arrow
Sent from a white van down the street.
Goto page 1, 2  Next
