Help! Need 914-6 heat exchangers
Milfordite
Milfordite is offline
PostPosted: Fri Feb 10, 2012 3:36 pm    Post subject: Help! Need 914-6 heat exchangers Reply with quote
I'm resurrecting a 914-6 from a bare shell. Just a little rust and most everything there except heat exchangers. Any help would be appreciated! I've looked at the aftermarket stuff and I'll go that route if I have to, but would like to have the original type if possible.
1990 VW Vanagon westy
Root_Werks
Root_Werks is offline
PostPosted: Fri Feb 17, 2012 3:13 pm    Post subject: Reply with quote
BB and GHL I believe have both stopped making replacement heater boxes. You are stuck either getting a good fab shop to repair what you have or source some good used ones$$.
Even rough 914-6 heater boxes are getting so hard to find, they are commanding very outrageous prices.
When I set my timing, why do I flush, then take a pee?
flatsix
flatsix is offline
PostPosted: Fri Feb 17, 2012 7:51 pm    Post subject: Reply with quote
I think you can still get them from Patrick Motorsports
http://www.patrickmotorsports.com/parts/4/18/11/
Although it might also be possible to have new heater boxes made to fit your pipes.
Root_Werks
PostPosted: Sat Feb 18, 2012 11:34 am    Post subject: Reply with quote
Good call, I missed that one. Those look exactly like the old BB units. I had a set years back. Very good quality, they don't produce much heat. Enough to keep the windows clear and people warm.
Milfordite
PostPosted: Fri Feb 24, 2012 8:31 am    Post subject: Reply with quote
I've checked out those places and also found a shop in England that makes a pretty nice set...I've got time, there is so much else to do right now. We'll see what turns up!
Root_Werks
PostPosted: Fri Feb 24, 2012 1:41 pm    Post subject: Reply with quote
That might not work to your favor (waiting). Back when I bought SS-BB heater boxes, they were $1500 shipped. Good used factory sets would run $1k not really needing any repair work.
Might not be a bad idea to snag a set from someone or some place and just let them sit in the garage until you are ready for them.
Milfordite
PostPosted: Sun Feb 26, 2012 10:39 am    Post subject: Reply with quote
I would buy a used set if I can find them! Not many around these days what with all the 914-4 to 6 conversions.
