Type 3 engine Megasquirts-2 Conversion Project
Goto page Previous  1, 2, 3, 4, 5, 6, 7, 8, 9, 10  Next
dragsters for life
dragsters for life is offline
PostPosted: Wed Dec 07, 2011 1:03 am    Post subject: Reply with quote
nice work will
first time i have looked into this thread and very impressed
for t shirts and hoodies contact [email protected]
send them an email and they will take it from there
Willo357
Willo357 is offline
PostPosted: Tue Dec 27, 2011 4:29 pm    Post subject: Reply with quote
Got a bit more engine building done. hopefully more soon
the COP's looking good
more soon....! Razz
supersuk
supersuk is offline
PostPosted: Tue Dec 27, 2011 6:35 pm    Post subject: Reply with quote
what intake manifold are you going to be using? I had a hard time fitting some spark plug wires and a cb performance shorty manifold for weber 40/44idf type throttle bodies. Bought some spark plug wires with 45 degree ends and cut them to length. Thats the only way I could make it fit properly.
68 Fastback Build: http://www.thesamba.com/vw/forum/viewtopic.php?p=5396323#5396323
Type 3 MegaSquirt Trigger Wheel: http://www.thesamba.com/vw/forum/viewtopic.php?p=5502150#5502150
View user's profile Send private message AIM Address MSN Messenger Classifieds Feedback
Willo357
Willo357 is offline
PostPosted: Tue Dec 27, 2011 10:15 pm    Post subject: Reply with quote
Im starting out with the stock dual carbs, then later a stock FI intake runner.
I havnt checked but i think there will be plenty of room for the coils.
dragsters for life
PostPosted: Tue Dec 27, 2011 11:49 pm    Post subject: Reply with quote
into it will
supersuk
supersuk is offline
PostPosted: Wed Dec 28, 2011 5:04 pm    Post subject: Reply with quote
Ahhh, Ok. Those should fit no problem.
Willo357
Willo357 is offline
PostPosted: Sat Jan 07, 2012 9:24 pm    Post subject: Reply with quote
So i have been very busy the past week getting and have achieved a few things on the project. Most importantly getting the trigger wheel locked and loaded....
here is my VR sensor bracket, i know others have done it different but i think it will work ok
Willo357
Willo357 is offline
PostPosted: Sat Jan 07, 2012 9:27 pm    Post subject: Reply with quote
I dusted off my original fan housing which had a strange cut through it ???? any ideas how this happened???
I thought this would be a good opportunity to practice some welding... because i need all the practice i can get ...Right?
Willo357
Willo357 is offline
PostPosted: Sat Jan 07, 2012 9:43 pm    Post subject: Reply with quote
Then full of confidence i proceded to "Fix" my old stock exhaust....
The connecting pipes to the HEX had rusted through and the tail pipe had gone in both bends....+ my EMPI exhaust had blown up!!!! Confused what a POS
i got some scrap exhaust pipe that was about the right diameter from the local mechanic (for the best price)
Then used the tailpipe off my EMPI exhaust because it was actually quite thick pipe and welded it in
looks pretty neat i think .....? i drove about 200km yesterday with no problems, (even when the cop pulled me over for a bretho and walked around my car he didnt complain)
not sure how it will hold up in the long run because im not very experienced with a welder but i added in metal to try and reinforce my shoddy welds. hopefully it will hold together.
I must say that the stock exhaust is very quiet.... it is amazing. i think it might be worth getting a radio now....
dragsters for life
PostPosted: Sun Jan 08, 2012 1:10 am    Post subject: Reply with quote
im fitting a stock set up tomorrow will, ditchin the empi set up i have now
Corysvdub
Corysvdub is offline
PostPosted: Wed Feb 01, 2012 3:03 pm    Post subject: ms Reply with quote
So your running it with the cops right now?
Willo357
Willo357 is offline
PostPosted: Sat Feb 25, 2012 8:16 pm    Post subject: Re: ms Reply with quote
No not yet.... I have hooked up the trigger wheel and im getting the tach readout on Tunerstudio.... Im feeling this is a pretty big milestone. I made a vid but havnt uploaded it yet.
http://www.thesamba.com/vw/forum/viewtopic.php?t=4...highlight=
Willo357
Willo357 is offline
PostPosted: Sat Feb 25, 2012 8:25 pm    Post subject: Reply with quote
Im really struggling with the COP circuit ..... Brick wall
Here is where im at.
ignitors
pin 1 are wired to r26 or r29
pin 2 To the coil (IB pin - pin 3)
pin3 to Earth (ground)
my coils have 3 pins ....
pin 1 is G - (where does this go??? to ground or ecu (pin 36))
pin 2 is 12+ ( To 12v i.e battery)
pin 3 is IB - to ignitor (pin 2)
im really hopping someone can help me out, The G pin on the coilpacks are doing my head in.... i need to get some pigtails first but then im just going to wire this up and see if it works because im sick of information overload. Twisted Evil
Corysvdub
PostPosted: Sat Feb 25, 2012 10:14 pm    Post subject: cop circuit Reply with quote
Did you check the megamanual? If you can't find it there I'm sure piledriver or supaninja can help you in the STF.[/quote]
66 sqaure squirted
supaninja
supaninja is offline
PostPosted: Sun Feb 26, 2012 1:54 am    Post subject: Reply with quote
I'm running 2 wire coils but I think the only difference is the 3 wires have an extra gnd. Looks right to me, if I have a chance tomorrow i'll look at how I wired my setup up. Don't worry, it kicked my butt too Wink .
http://i5.photobucket.com/albums/y163/chucky1974/ninja.gif
Nick
Megasquirted Type 4 powered Notch http://www.thesamba.com/vw/forum/viewtopic.php?t=427890&postdays=0&postorder=asc&start=0
Blog of Doom http://supaninjanick.wordpress.com/
View user's profile Send private message Send e-mail Yahoo Messenger Facebook Classifieds Feedback
Willo357
Willo357 is offline
PostPosted: Sun Feb 26, 2012 4:56 am    Post subject: Reply with quote
Thanks mate ..... that would be a super help (pun very much intended)
vdubin
vdubin is offline
PostPosted: Sun Feb 26, 2012 5:18 am    Post subject: Reply with quote
The 12v is an ignition hot 12v from the battery. The G is a ground to the engine or the body very near by. The shorter the grounds are the better. The third is your trigger from megasquirt. If you are using wasted spark tie the two cylinders together that are at TDC at the same time. Its been a while, but i think its 1-3 , 2-4 as the firing order is 1432.
Willo357
Willo357 is offline
PostPosted: Tue Feb 28, 2012 10:41 pm    Post subject: Reply with quote
so i wired it up like this today ..... nothing... no beans Sad
im starting to think that the ground on the coil should go to pin 36 for spark A and 31 for spark B,
supaninja
PostPosted: Wed Feb 29, 2012 12:32 am    Post subject: Reply with quote
damnit, i forgot to check my wiring.
Your using ms extra right?
I found this: http://msextra.com/doc/ms1extra/MS_Extra_Ignition_Hardware_Manual.htm#2coils
Nick
Willo357
Willo357 is offline
PostPosted: Wed Feb 29, 2012 2:14 am    Post subject: Reply with quote
yeh i think that wiring is correct .... my setup was pretty getto Embarassed
Im headding to my workshop this weekend so i can set up camp and sort things through logically and not on the footpath... I had my desktop set up in the car.
I have been getting a delay in my tach signal (and the led flashing) in any transition ... high to low .... low to high rpm ect.
It could be just because i only have the tach pluged in and the ecu dosent understand the sudden change in rpm... ( no map or tps )
Page 2 of 10
