Spring plate bolt questions
Goto page 1, 2  Next
iamdonquixote
iamdonquixote is offline
PostPosted: Tue Aug 04, 2009 5:45 am    Post subject: Spring plate bolt questions Reply with quote
Needed to remove my transmission.
Did many searches
One bolt hole was stripped. Couldn't get a timesert so used helicoil, yuk, seemed to work though.
Questions:
1) can I replace the helicoil with a timesert later on?
2) what washers are used for bolts, I noticed a lock plate in a pic? where can they be found?
3) what is the torque spec? ( don't have a Bentley handy right now )
thanks
hazetguy
hazetguy is offline
PostPosted: Tue Aug 04, 2009 5:49 am    Post subject: Re: spring plate bolt questions Reply with quote
Did many searches
Questions:
thanks
1) i have not tried to replace a helicoil with a timesert. i guess it could be done. a helicoil is a coil and could probably be "uncoiled", a timesert is a solid insert and they say they can be drilled out if necessary.
2) http://www.thesamba.com/vw/classifieds/detail.php?id=825680
or if you want original style lock plates, WW reproduces them: http://www.wolfsburgwest.com/cart/DetailsList.cfm?ID=211598600
they also sell bolts, but i don't know what grade they are: http://wolfsburgwest.com/cart/DetailsList.cfm?ID=N101191
3) torque spec is 100-120Nm (or 72-86 ft. lbs) and are tightened in this sequence:
Clara Premium Member
Clara is offline
PostPosted: Tue Aug 04, 2009 6:04 am    Post subject: Re: spring plate bolt questions Reply with quote
hazetguy wrote:
The earlier buses came with 17mm heads on the RGB bolts
the later have 19mm.
I believe the change was when they dropped the lock plates in favor of the washers.
Always use a tap to clean out the threads in the RGB, so you can thread them in by hand. Avoid crossthreading.
Campy
Campy is offline
PostPosted: Tue Aug 04, 2009 1:05 pm    Post subject: Reply with quote
The spring plate bolts that I have removed from the big stub axle RGBs have been longer than the earlier ones. Someone said that, because the lock washers were thicker than the lock plates, they used longer bolts. Is that true?
Don't worry; be happy. (Baba)
BarryL Premium Member
BarryL is offline
PostPosted: Tue Aug 04, 2009 6:08 pm    Post subject: Reply with quote
I'm tending to agree with you. I wonder if the parts list shows a difference. I like the longer ones for Bays and then I chase a bottoming tap on down and use the thick ass lock washers when I can find them.
hazetguy
hazetguy is offline
PostPosted: Tue Aug 04, 2009 6:23 pm    Post subject: Reply with quote
the replacement washers are not lock washers, they are spring washers. the spring washers are thinner than a lock washer. the spring washers are about the same thickness as an original lock plate.
the part number, in the parts book, is N 10 199 1 Bolt, hex. head M 12 X 1.5 X 25 - Spring plate mounting from chassis No. 20 117 902
i've taken out plenty of "early" bolts and "late" bolts (whatever), they are 25mm in length.
mr. warehouse Premium Member
mr. warehouse is offline
PostPosted: Tue Aug 04, 2009 6:47 pm    Post subject: Reply with quote
If anyone needs OG bolts in 17mm or 19mm heads, I have literally 10 coffee cans full of them at my shop.
Forums - http://lowbus.com/BB/index.php
Shop - http://www.vintagewarehouse.com/store/index.php
View user's profile Send private message Send e-mail Visit poster's website Facebook Twitter Gallery Classifieds Feedback
BarryL is offline
PostPosted: Wed Aug 05, 2009 7:03 am    Post subject: Reply with quote
Do you have a pic of a Bay one and its washer?
hazetguy
hazetguy is offline
PostPosted: Wed Aug 05, 2009 9:41 am    Post subject: Reply with quote
pics of a bay's what?
BarryL is offline
PostPosted: Wed Aug 05, 2009 7:31 pm    Post subject: Reply with quote
The Bay springplate-to-bearing housing bolt that is similar. I couldn't look it up on the parts website as it only goes to '67. It uses a spring washer but with a thick lock washer it will go all the way into a RGB. Or nevermind as it doesn't actually pertain.
Major Woody
Samba Enigma
Major Woody is offline
PostPosted: Thu Aug 06, 2009 9:49 am    Post subject: Reply with quote
Threads like this remind me of how much the use of anti-seize has changed my life. I should devise a little belt holster to carry it around the shop with me, I use it that much.
sventinker
sventinker is offline
PostPosted: Wed Jan 27, 2010 11:40 pm    Post subject: Reply with quote
the use of anti seize changes torque specs be careful you can easily over tighten a bolt when used I prefer to chase the threads wit a tap and visually inspect or replace the bolts. Once torqued water shouldn't be reaching the threads to cause a problem
April 3rd 62 standard mgr/pw
374 North American equipment
Includes 6 popouts
025 Safety belts
195 Adjustable bench seat/backrest (until 1963)
dawerks wrote:
Perfection only comes with delusion.
http://www.oacdp.org/
j.pickens
j.pickens is offline
PostPosted: Thu Jan 28, 2010 6:33 am    Post subject: Reply with quote
Source for this info, please?
I've been using the copper based anti-seize for thirty years, never a problem, quite the opposite.
BBX and BBXII Long Distance Award Winner
BeaterBarndoor wrote:
BryanM wrote:
The thread is about Badgers now, not snakes, please stay on topic
ToolBox
ToolBox is offline
PostPosted: Thu Jan 28, 2010 9:39 am    Post subject: Reply with quote
MDMetrics wrote:
Antiseize lubricants can reduce torque required by approximately 20%.
j.pickens
PostPosted: Thu Jan 28, 2010 9:52 pm    Post subject: Reply with quote
ToolBox wrote:
Well, I guess I've been "overtorquing" all this time.
I plan to continue to do so.
campingbox Premium Member
campingbox is offline
PostPosted: Thu Jan 28, 2010 10:08 pm    Post subject: Reply with quote
83% or statistics are made up.
sventinker
PostPosted: Thu Jan 28, 2010 11:09 pm    Post subject: Reply with quote
83% of statistics are made up.
that is some funny sh*t
Includes 6 popouts
025 Safety belts
iamdonquixote
PostPosted: Sun Feb 26, 2012 8:15 am    Post subject: Reply with quote
anybody have a source for the proper grade bolts?
I got black ones from the store but they were 8.8 rated. The Kamax bolts are 10. Next grade is a 10.9 I think. I ordered bolts from Wolfsburg West thinking they would be the right grade but they gave me silver 8.8 bolts.
My Kamax bolts were a little to worked over to reuse.
cdennisg
cdennisg is offline
PostPosted: Sun Feb 26, 2012 9:12 pm    Post subject: Reply with quote
McMaster Carr? Fastenal?
Olddog52 wrote:
horn test. one tab to ground, the other to a 12 volt source. Listen intently for a sound.
cdennisg
cdennisg is offline
PostPosted: Sun Feb 26, 2012 9:14 pm    Post subject: Reply with quote
http://www.fastenal.com/web/products/detail.ex?sku=11114130
Here you go.
Or, if you prefer black over Zinc, http://www.fastenal.com/web/products/detail.ex?sku=11113401
Goto page 1, 2  Next
