sDeLuca Samba Member
Posted: Mon Feb 27, 2012 3:24 pm Post subject: New valve or new LP tank |
My wife went to fill up the propane on out van today and the drove home only to have the fire department knock on our door 20 minutes later to inform her that the tank was leaking. Sounds a lot like the story posted on the GW site about the auto stop fill valve. This is in fact is the problem.
My question is should I replace the faulty value and bleeder with the one Terry provides http://www.thesamba.com/vw/classifieds/detail.php?id=426729
should I replace the entire tank, thus replacing the service valve and regulator in the process, as suggested by the aforementioned GW article.
I just wanted people's experiences and suggestions. _________________ 1989 Syncro Westfalia AHU TDI
2005 Golf TDI Biodiesel |
presslab Samba Member
Joined: September 29, 2008 Posts: 1736 Location: Sonoma County
Posted: Mon Feb 27, 2012 3:44 pm Post subject: Re: New valve or new LP tank |
| sDeLuca wrote: |
I just wanted people's experiences and suggestions. |
I guess your neighbors didn't want to tell you directly so they called the fire department instead?
First, where is it leaking on the tank? If the fill monkey overfilled the tank it will leak from the over-pressure valve, the one near the knob. It will reset after the excess is bled off. If it leaks out of where the filler hose goes, then your fill valve is bad.
Is your tank in disrepair? If it's not all rusty, I'd say replace the valves. I bought these two valves for less than $20 and they work great.
http://www.helmarparts.com/product_p/7647sc.htm
http://www.helmarparts.com/product_p/3165c.htm _________________ 1986 Vanagon Westfalia EJ25
1988 Subaru GL-10 EJ20G --- 2000 Honda XR650L
2010 Titus El Guapo --- 2011 On-One 456 Ti |
crazyvwvanman Samba Member
Joined: January 28, 2008 Posts: 3427 Location: Orbiting San Diego
Posted: Mon Feb 27, 2012 4:45 pm Post subject: Re: New valve or new LP tank |
It is easy enough to just replace the valves. I have done it on several tanks to get rid of the 'autoleaker' valves. I bought my valves from RV suppliers and on Ebay.
Mark
| sDeLuca wrote: |
My question is should I replace the faulty value and bleeder with the one Terry provides ......or......should I replace the entire tank, thus replacing the service valve and regulator in the process, as suggested by the aforementioned GW article. |
islandjeeper Samba Member
Joined: May 05, 2008 Posts: 36 Location: Colorado Springs, Colorado
Posted: Mon Feb 27, 2012 5:20 pm Post subject: |
I had the auto stop valve, filled up with 3 gallons or so of fresh propane, only to have the valve leak out one of the vent holes from a bad oring. They would not let me leave and it took hours for it to all bleed out.
I purchased the fill and bleed valves from TK and they work great. Since I have several campers I needed more. I am not sure where you live but I found a local propane service place here in CO and they had the fill valve, bleeder, and regulator, all for good prices. I have also found the same bits at RV dealers and service places.
I almost spent the $300 plus on a new tank and found that if my tank was in good shape and not rusty, the valves were all I needed to make it nice again.
For the record, I have not had a good stock regulator that did not leak. I have been replaceing them with the ones from the RV store that are just like the ones on the new tanks. I was told by these guys that the covers do more harm than good because they make a place for the wasps to build.
So with a non rusty tank, it costs me about $53 to put new valves and regulator on. You will need a tubing cutter and flare tool to put the new regulator on, it is a bit longer. _________________ Stephen Sunkel
1991 White Transporter Tin Top
2012 New New Beetle |
madspaniard Samba Member
Joined: August 18, 2008 Posts: 2810 Location: Alameda, CA
Posted: Mon Feb 27, 2012 5:29 pm Post subject: |
I replaced all the hardware in my tank as well, tank was sandblasted and powdercoated, I also installed a second tank on passenger side with a change-over regulator conecting both tanks _________________ 1991 Westy auto w/ Peloquin TBD
"The only difference between me and a madman is that I'm not mad” - Salvador Dali |
Posted: Mon Feb 27, 2012 9:04 pm Post subject: |
Sounds like new valves and regulator. Thanks everyone. I think I will use this opportunity to add in the extend a stay for external hookup, since I will be re-flaring anyway. _________________ 1989 Syncro Westfalia AHU TDI
