brianbernal71 Samba Member
Joined: January 10, 2010 Posts: 41 Location: Spokane WA
Posted: Mon Feb 27, 2012 5:59 pm Post subject: angled fuel pump on generator motor? |
hey all, i have been reading in the archives, but have not found an answer to my question. so sorry if its a rookie type of question. i have a new angled fuel pump intended for an alternator motor. can i install it on a motor that has a generator? which length rod would i use if so? thanks...brian _________________ Brian
72 Standard Beetle
70 Deluxe Bus
83.5 Westy |
Glenn  Mr. 010
Joined: December 25, 2001 Posts: 55846 Location: Long Island, New York, USA
Posted: Mon Feb 27, 2012 6:05 pm Post subject: |
Yes you can and you use 113 127 307 A pushrod (108mm). _________________ Glenn
HBB/RW
www.DasVolks.com
Long Island's Aircooled Club
poisonbeetleman Samba Member
Joined: February 25, 2012 Posts: 104 Location: FT.Bragg NC
| when i installed my new altenator. with the new stand. i used the new angled pump but the old rod. ran fine. unless someone knows . something else. but this worked fine for me. hardest part for me was the rewire of the regulator. so no wires would ever touch metal. heat shirnked all of them. nvr had a problem. |
Posted: Mon Feb 27, 2012 6:14 pm Post subject: |
so what would happen? what actually does the length of the rod do to the pump? if its longer does it pump more fuel? _________________ Brian
72 Standard Beetle
70 Deluxe Bus
83.5 Westy |
Posted: Mon Feb 27, 2012 6:19 pm Post subject: |
| ok if the rod is longer then the travel of the pump would increase, meaning more suction = more fuel= more fuel pressure= bad things to carb. most bugs from what i have read . run 2-3 pounds of fuel pressure. more fuel and more pressure = to much gas for little bug. |
Joel Samba Member
Joined: September 04, 2006 Posts: 8106 Location: NSW Australia
Posted: Mon Feb 27, 2012 6:43 pm Post subject: |
The rocker arm inside the base of the pump is just mounted lower on alternator pumps so they need a shorter rod.
If you use a short alt rod with a gen pump it's not gonna reach so pump wont work
If you use a long gen rod with a alt pump its gonna be too long and break shit if you can actually get it to bolt down ( the rod holds the pump up to high)
It's easy to tell which pump is what as some aftermarket ones dont lean over but use the short rod.
pumps that use the shorter 100mm rod have the rocker arm hanging out the bottom, pumps that need the longer 108mm rod have the rocker arm up inside the base of the pump like so:
ashman40 Samba Member
Joined: February 16, 2007 Posts: 5787 Location: (West) Tokyo, Japan
Posted: Mon Feb 27, 2012 7:35 pm Post subject: |
| poisonbeetleman wrote: |
| when i installed my new altenator. with the new stand. i used the new angled pump but the old rod. ran fine. |
I have seen for sale an angled generator pump that outwardly appears to be an alternator pump. It uses the longer pushrod.
Don't just go by whether it is angled or not. Look at the pump foot like the above pic. Make sure to match the pump and push rod. _________________ AshMan40
'75 Beetle 1200LS (RHD)
"stock" 1600 w/ 34 PICT-3 carb & S/A tranny |
mrbigmax Samba Member
Joined: September 10, 2011 Posts: 1100 Location: Modesto, CA
Posted: Mon Feb 27, 2012 8:37 pm Post subject: |
| For goodness sake, we are talking about a $5 part here. Get the right part and don't worry about excessive fuel pressure or worn out pumps or worn out pushrods... |
Chris Vellat Samba Member
Joined: April 09, 2004 Posts: 1569 Location: Seattle, WA
Posted: Mon Feb 27, 2012 9:41 pm Post subject: |
An alternator pump pushrod can always be made into a generator one with a couple minutes and a grinder...Also note a common problem with reproduction fuel pumps is the lack of retaining hardware on the pivot pin - letting the pin fall-out and the engine left to run-out of gas. _________________ (3) '69's
'67 Baja
'74 Super
'73 Bay
(2) '77's |
Greezy Joe Samba Member
Joined: April 12, 2010 Posts: 1201 Location: Crawfordville, Fl
Posted: Tue Feb 28, 2012 5:54 am Post subject: |
| Chris Vellat wrote: |
| An alternator pump pushrod can always be made FROM a generator one with a couple minutes and a grinder...Also note a common problem with reproduction fuel pumps is the lack of retaining hardware on the pivot pin - letting the pin fall-out and the engine left to run-out of gas. |
I fixed it for you  _________________ Current:74 Ghia Coupe w/ 2276
71 Ghia Vert w/ 1835
07 GMC Truck
04 Chrysler Crossfire
73 Harley FLH 93 cid
89 Harley 883 Sportster (1200)
Owned before: 58, 69 Ghia Coupes, 64 Canvas Sunroof, 68, 72, 73, & 74 Bugs, 63 Single Cab, 65 Bus, 66 & 70 Camper
"You have to be smarter than what you're working on" |
