79 Sage Green Westy Restoration Lots of PICTURES
Goto page Previous  1, 2, 3 ... 18, 19, 20 ... 41, 42, 43  Next
curtis4085
curtis4085 is offline
PostPosted: Wed Feb 29, 2012 8:02 pm    Post subject: Reply with quote
So what did you end up doing for the seat stand and surround mats?
I trimmed the top seat stand mat to fit on passenger side pedistal then installed the side seat stand mat. I purchased a piece of trim from Bustedbus.com to bridge the two mats. I have coming and extra set of top and side mats to cut them up to use for top section of rear side. $100 fix. Mad
I am not done yet but i can send you SGKent picture of the fix he sent me, its more detailed. and when i get done i will post more pictures. One thing is dry install the mats, make all your cuts then glue in place. Make sure you have it lined up right and have a heat gun to help losen the rubber. doing it in the cold will not work.
Special Thanks to:
Headflow Masters - Vista, CA
www.headflowmasters.com
71 Pastel White Panel Van current restoration
73 Westfalia (sold)
73 Westfalia (accident)
73 Kombi (Sold)
75 Panel Van
79 Sage Green Westfalia fully restored
http://www.thesamba.com/vw/forum/viewtopic.php?t=479199&postdays=0&postorder=asc&start=0
curtis4085
PostPosted: Wed Feb 29, 2012 8:13 pm    Post subject: Reply with quote
Westfabulous wrote:
You go girl! This has been quite the Epic journey Matt. Keep up the good work. Looking forward to getting my engine back in and cleaning up the grossness in my garage.
Yes yes. my 3 car garage has been home to nothing but piles for nearly 5 plus months and now i am just getting space back. I look forward to picture of what you have to come.
Special Thanks to:
73 Westfalia (sold)
73 Kombi (Sold)
75 Panel Van
VWGirl
VWGirl is offline
PostPosted: Wed Feb 29, 2012 8:48 pm    Post subject: Reply with quote
Yeah if you could send the details he sent you and what and where you ordered would be great. All I keep being told is that stuff won't for Sad you'd think there was enough demand to make the right stuff
Without love in the dream it will never come true
curtis4085
PostPosted: Wed Feb 29, 2012 9:17 pm    Post subject: Reply with quote
that is the info he sent me.... I bought both top and side mats again and plan to do what in the picture. I got my mats at Wolfsburg West. They fit nice when warm. THe top ones you have to be very careful to line up everything just right before you push it on the glue as once its down you can get it back up but it rips the foam. SO place it ounce. I did mine alone but could have used extra set of hands to help hold the mat off the glue till lined up. On the sides and top you can almost fold the mat in half set that section and unfold and set that section. Make sure you line up right or you will have hard time getting the rubber flap in the slot. Heat gun helps here. If you take your time to make all the right cuts and do a dry run so you know what it gonna take and where it all needs to line up. The mats have hole markers so it is pretty easy to figure out. With the heat gun, patience, and a little muscel you will be fine. Do it on a warm day.
Special Thanks to:
73 Westfalia (sold)
73 Kombi (Sold)
75 Panel Van
curtis4085
PostPosted: Wed Feb 29, 2012 9:23 pm    Post subject: Reply with quote
here is my bus right now. You can see the top edge of seat stand covered by piece of trim, i got that from busdepot. the little corner piece i had. THose trims will hide the top cuts to the scabbed on piece of mat for side of seat stand. Pictured in first post on this page is how SGkent did it. It appears he use the bottom portion of the driverside side mat to cover the top of the passenger side side of seat stand. Hope it helps a bit. Again i will pull my seat and take a picture but if you dry fit and use a razor slowly you can use the old glue line and the contour of the bus to trim the mat up just fine.
Special Thanks to:
73 Westfalia (sold)
73 Kombi (Sold)
75 Panel Van
VWGirl
VWGirl is offline
PostPosted: Wed Feb 29, 2012 9:50 pm    Post subject: Reply with quote
Wasn't their just a small cap that went at the end of the edge trim on the westies? i have that corner trim from a passenger bus cause I was going to do something else.. But I like the rubber better
curtis4085
PostPosted: Wed Feb 29, 2012 9:54 pm    Post subject: Reply with quote
I used both as mine 79 came with the corner piece an the OG mat had a built in piece to cover the edge. I got the earlier bay trim piece to replicate this look. Chris at bustedbus.com trim went all the way from B pillar to around inner corner. So you do not need the plastic trim corner. I cut the trim piece from bustedbus to suit my needs.
Special Thanks to:
73 Westfalia (sold)
73 Kombi (Sold)
75 Panel Van
VWGirl
VWGirl is offline
PostPosted: Wed Feb 29, 2012 10:49 pm    Post subject: Reply with quote
Maybe 79 is different than 78, it is in many ways, but the 78 had just a piece of channel rubber that went over the edge of the rubber and there was a very small cap at the end. The flat corner piece that you showed in the pic from sgkent is the piece that would have gone on a passenger bus
Westfabulous
Location: The tropic of Canada, dodging the giant flying moose of Surrey!
Westfabulous is offline
PostPosted: Wed Feb 29, 2012 10:51 pm    Post subject: Reply with quote
VWGirl wrote:
Maybe 79 is different than 78, it is in many ways, but the 78 had just a piece of channel rubber that Kent over the edge of the rubber and there was a very small cap at the end. The flat corner piece that you showed in the pic from sgkent is the piece that would have gone on a passenger bus that did not have that channel rubber over the edge like the westy. I'm curious to see how you fit the two together.
78 and 79 were the same.
"I will gladly pay you Tuesday for a hamburger today."
curtis4085
PostPosted: Wed Feb 29, 2012 10:54 pm    Post subject: Reply with quote
here is mine.
the trims fit fine once trimmed
Special Thanks to:
73 Westfalia (sold)
73 Kombi (Sold)
75 Panel Van
Westfabulous
PostPosted: Wed Feb 29, 2012 10:58 pm    Post subject: Reply with quote
The only picture that I have of my original mats:
curtis4085
PostPosted: Wed Feb 29, 2012 11:00 pm    Post subject: Reply with quote
and if i recall that flap of rubber/ or channel as your calling it was apart of the top pedistal mat;
Special Thanks to:
73 Westfalia (sold)
73 Kombi (Sold)
75 Panel Van
Westfabulous
PostPosted: Wed Feb 29, 2012 11:02 pm    Post subject: Reply with quote
Correct.
curtis4085
PostPosted: Wed Feb 29, 2012 11:04 pm    Post subject: Reply with quote
Dan, how come i do not have those tie downs on the side of my seat stands for the stool?
Special Thanks to:
73 Westfalia (sold)
73 Kombi (Sold)
75 Panel Van
curtis4085
PostPosted: Wed Feb 29, 2012 11:05 pm    Post subject: Reply with quote
I just notice yours
Special Thanks to:
73 Westfalia (sold)
73 Kombi (Sold)
75 Panel Van
Stuartzickefoose
Samba Post Whore
Stuartzickefoose is offline
PostPosted: Wed Feb 29, 2012 11:10 pm    Post subject: Reply with quote
curtis4085 wrote:
I just notice yours
first the bucket, now a tie down strap.... Rolling Eyes whats next? a cool bolt on his engine thats a 14mm instead of a 13mm? Laughing jk.
i have a hell of a bucket story for you two....with video footage...i gotta figure out how to upload it....but watch for it...you will be able to make fun of me so much... Laughing Cool Embarassed
MINE - 1978 Westfalia ~ Maisy ~ FI, Hydraulic Valves, Electronic Points, 2.0 (NEED A SET OF HEADS, PM ME IF YOU HAVE A SET)
DAD's - 1972 Westfalia ~ Sticky ~ 1.7(?) 914 motor, allison electronic ignition, electric fuel pump, dual webers w/o choke.
“Don't cry because it's over, smile because it happened.”
“Those who mind don't matter, and those who matter don't mind.”
Westfabulous
curtis4085 wrote:
I just notice yours
Yours is a P22 and not a P27. In other words, mine is a deluxe with fridge, stove, front dash table, and camping stool. Those tie downs are to secure the camping stool in place. See the picture (ignore the bucket - old shot):
Stuartzickefoose
Samba Post Whore
....again....with the bucket...lol
Westfabulous
PostPosted: Wed Feb 29, 2012 11:12 pm    Post subject: Reply with quote
Stuartzickefoose wrote:
curtis4085 wrote:
I just notice yours
When you have spent as much time and money as Matt has in the pursuit of a perfect restoration, you will understand. Meanwhile, you'll have to settle for having a green nose on the inside of your bus. Wink
But you do have a good steering wheel wrap that is the envy of many.
curtis4085
PostPosted: Wed Feb 29, 2012 11:14 pm    Post subject: Reply with quote
ok. its becoming clearer. So mine never had a stool? buT MY DUMD ASS bought one anyway. Real smart move On my part. Who wants a yellow bucket with stool? Mad
Special Thanks to:
73 Westfalia (sold)
73 Kombi (Sold)
75 Panel Van
Page 19 of 43
