Bobnotch Samba Member
Joined: July 06, 2003 Posts: 10616 Location: Kimball, Mi
70 140 Samba Member
Joined: September 22, 2002 Posts: 8399 Location: Ontario, Canada
Posted: Thu Mar 01, 2012 6:29 pm Post subject: |
| Trying to add discs to the rear won't be as easy as you think, especially on a drum brake ABS car. My guess is that the proportioning is done in the M/C and you would probably need to replace that as well. |
Busryder Samba SuperHero
Joined: September 17, 2007 Posts: 1709 Location: In Your Face...
Posted: Thu Mar 01, 2012 8:22 pm Post subject: |
| 70 140 wrote: | | Trying to add discs to the rear won't be as easy as you think, especially on a drum brake ABS car. My guess is that the proportioning is done in the M/C and you would probably need to replace that as well. |
Hello,
That is probably the most detailed answer yet... would this stuff be on a donor vehicle of the same year, but in six cyls? It seems that that is where I have found them on the same year Camry's in the yard I was in.
And out of pure ignorance: Are rear disc brakes not ABS?
I only ask because I really do "have no clue".
Anyway.... I found a pdf wire/rely/connector/etc manual recently, and it is 350+ pages long! Just the wire diagram alone.
So I am beginning to understand what you mean by being 'not as easy as you think'... someone, please, convince me that this is impossibly difficult.
Thank's for the answer 70 140, really... _________________
| Lind wrote: | | Apparently I was just the lucky asshole that showed up at the right time. |
I am a Dick, hear me roar-
Me, an OVP Lifer... |
bugger101 Samba Member
Joined: September 04, 2010 Posts: 1442 Location: orlando
Posted: Mon Mar 05, 2012 9:17 pm Post subject: |
no rear disc can have wheel speed sensors but they might be different And the abs module would be different also(programmed for a heavier car). Other than that I have no idea there might be Proportioning Valve along the line somewhere. if you can get all the parts for cheap I would go for it and try it. _________________ 75 west deluxe http://www.thesamba.com/vw/forum/viewtopic.php?p=5270450#5270450
2010 ford focus
1949 ford f-1
2006 Lincoln navigator
automotive student
ford line tech |
