Paul Windisch Samba Member
Joined: September 02, 2009 Posts: 2257 Location: Fraser, Michigan
Posted: Tue Feb 28, 2012 9:15 am Post subject: 1998 Golf self adjusting clutch cable |
Hey guys, I spend most of my time in the air cooled forums, but a friend of mine just finished installing a new clutch in a 1998 Golf and now he says the cable is out of adjustment and the clutch doesn't work properly. From what he has described, it is a self adjusting cable. What is the procedure for resetting the cable?
Thanks,
Paul _________________ *ASE Recertified Master Automotive Tech*
1984 Mexican Beetle
2013 Chevrolet Volt DD
2005 Pontiac Montana SV6 (the loser cruiser)
Heidebreicht Chevrolet
http://www.heidebreicht.com/HomePage |
po7g Samba Member
Joined: June 15, 2004 Posts: 454 Location: Schererville, Indiana
Posted: Tue Feb 28, 2012 2:44 pm Post subject: |
if the self adjusting cable is not adjusting anymore. it needs replacing, most people replace them with the manual adjusting cable which cost about the same or less then the self adjusting cables. here are some links you can check out
www.Brokevw.com
Replacing Clutch Cable |
Posted: Sat Mar 03, 2012 7:26 am Post subject: |
Thanks! _________________ *ASE Recertified Master Automotive Tech*
1984 Mexican Beetle
