chthemonkey Samba Member
Joined: July 30, 2008 Posts: 56 Location: united kingdom
Posted: Tue Mar 06, 2012 11:53 am Post subject: Dating of a engine |
i have a engine with a date stamp of 1-0334378 (august 1951) with a A on the end and KD on another side of the stand which i think means its factory rebuilt the casting numbers are
generator side= 4 8 10 on the gen stand and 01 02 4 on the base of the
engine. side of the oil pan
near the fuel
pump = 3 8 10 near the fuel pump and 01 01 4 on the base of the
any help with finding the original date
thanks
chris |
nlorntson Crazy VW Lady
Joined: March 13, 2004 Posts: 1266 Location: Twin Cities, MN
Posted: Tue Mar 06, 2012 3:34 pm Post subject: |
| Pictures of each of these areas would be helpful. |
Posted: Wed Mar 07, 2012 12:46 am Post subject: |
| i'll get some up tonight |
volksfahrer Samba Member
Posted: Wed Mar 07, 2012 3:17 am Post subject: |
A means Austausch (exchange/change/ rebuilt)
KD means Kundendienst...a Volkswagen-rebuilt engine |
Posted: Wed Mar 07, 2012 11:48 am Post subject: |
Posted: Wed Mar 07, 2012 11:56 am Post subject: |
Based on this casting date,
4 08 10
August 4, 1950 first shift. the number behind the pulley should be identical or within a day. You say it is a 3 so it is
the numbers on the oil sump sides are not date numbers
The stamped in number is probalby the exchange serial number
The number in the typical location on the rear of the generator stand could have been the original engine number of the case that was later rebuilt. |
Posted: Thu Mar 08, 2012 1:00 am Post subject: |
thanks
what do you think i should do i'm rebuilding it but should i rebuild it and sell it and find another one near aug/sept 51 or run it. the beetle has a 74 engine and trans in at the mo and i've got a 49 deluxe trans go on the engine when rebuilt
chris |
beetleseb Samba Member
Joined: November 09, 2006 Posts: 321 Location: Cheltenham UK
Posted: Thu Mar 08, 2012 2:45 am Post subject: |
Its always worth looking for a later case. Especially if you can find someone to swap with. Its always worth a hour or two ringing the usual suspects in the UK! Then you rebuild with that case with all the other parts off yours
I have a early 52 block (need to double check the date) that I would swap for something nearer my june 50, still a little way off but closer. _________________ Wanted - OG 50 split bug door panels, brown mats and old running boards |
Posted: Thu Mar 08, 2012 3:43 am Post subject: |
I was miles off as my case is dec 1950!! So no real improvement for you!
Still worth a ring around a few of the vintage guys and dealers tho _________________ Wanted - OG 50 split bug door panels, brown mats and old running boards |
Posted: Thu Mar 08, 2012 8:37 am Post subject: |
| chthemonkey wrote: |
chris |
What's a 49 deluxe trans? |
Posted: Thu Mar 08, 2012 10:34 am Post subject: |
What's a 49 deluxe trans?[/quote]
i'm not quite sure its got the area to attach the starter motor which i thought standards dident have |
Posted: Thu Mar 08, 2012 10:39 am Post subject: |
I've decided to rebuild it anyway as I've already started taking the case apart. has anyone got any ideas on how to get the last cylinder head stud off as there's not allot of space left for the allenkey/socket its like the rod is abit longer than the rest  |
Posted: Thu Mar 08, 2012 12:05 pm Post subject: |
I welded a nut to a bolt with the right sized head and used that. Worked a treat
Seb _________________ Wanted - OG 50 split bug door panels, brown mats and old running boards |
johnshenry Samba Member
Joined: September 21, 2001 Posts: 8509 Location: Dunstable, MA USA
Posted: Thu Mar 08, 2012 12:21 pm Post subject: |
| nlorntson wrote: |
chris |
Its got a gold plated throwout bearing fork and pleated leather panels Along the sides with ivory piping. _________________ John Henry
'57 Deluxe
'51 11E Standard Sunroof (PhotoBucket resto pics) |
Posted: Thu Mar 08, 2012 12:32 pm Post subject: |
| johnshenry wrote: |
| nlorntson wrote: |
chris |
Its got a gold plated throwout bearing fork and pleated leather panels Along the sides with ivory piping. |
LOL
I guess I have some more parts to find for my 49 deluxe. |
vwclap Samba Member
Joined: April 21, 2004 Posts: 443 Location: Qc, Canada
Posted: Sun Aug 19, 2012 6:43 pm Post subject: |
[img]
I found and old block with these 01.01.4 number, and appears date oct 53...I have another block that at the same place has 111 xxx xxx number.
Is the multiple number appears after the 01 01 4 number. What means that number
regards
Claude _________________ Claude
cox 1956, 1962 et 1975
Split panel 1963
Samba 21 fenetres 1966
Ghia 1968
Sport Ghia 73
West 1970
Jetta 1992
Jetta tdi 2002
Jetta TDI 2006
West Multivan 2002
2 x Golf city 2007 |
vwclap Samba Member
Posted: Tue Aug 21, 2012 1:35 am Post subject: |
I found the answer in that post
http://www.thesamba.com/vw/forum/viewtopic.php?t=376019 _________________ Claude
Split panel 1963
Ghia 1968
Sport Ghia 73
West 1970
Jetta 1992
Jetta tdi 2002
Jetta TDI 2006
West Multivan 2002
