big wavos OCTO
Posted: Tue Mar 06, 2012 10:12 pm Post subject: Starter bushing? |
| Recently installed new motor into my bus, at the time did not replace the starter. Lately I have noticed that the bus will fire right up when cold, but once I have driven it several miles and attempt to re-start I have a terrible time getting it started. The bus is still 6V and is mechanically sound except fot this issue. Any Ideas? Could the bushing be creating my problem and not the starter itself? |
EverettB  Administrator
Joined: April 11, 2000 Posts: 42211 Location: Phoenix, AZ
Posted: Tue Mar 06, 2012 10:28 pm Post subject: |
Meaning what? It won't crank over or it cranks a ton then starts?
If it won't crank over, it could be the bushing.
If it cranks over and over when hot and finally starts, I would check the fuel pump pressure on the new engine to start with. It should be around 3 psi but some of the aftermarket pumps are made wrong and can put out 8-12 psi straight out of the box. _________________ How to: Post Photos | Search
Everett Barnes - [email protected] | My VWs | My wanted ads
big wavos OCTO
Posted: Tue Mar 06, 2012 10:45 pm Post subject: |
Ev,
Fuel pressure has been checked satisfactory, when hot it cranks and cranks, often to the point where it sounds as if the battery will give out before it actually starts, I will be replacing the starter and bushing this weekend. Hopefully it is one of the two at fault. When cold this thing fires right up. |
quartermilecamel  Samba Member
Posted: Wed Mar 07, 2012 12:18 am Post subject: |
Um, that bushing will not prevent the engine from firing. It only prevents cranking. Have fun replacing that bushing. It wont solve your problem. Unless when hot it cranks slloowwwllyyy, then you might even have other issues too. Like an overheated engine? _________________ Looking for the U shaped swing arm for sliding door split. Left hand drive. Baywindow arms are 1/2 inch longer. |
kingodirtp3 Samba Member
Joined: December 07, 2007 Posts: 979 Location: Monterey CA
Posted: Wed Mar 07, 2012 12:42 am Post subject: |
| get a type 3 auto starter, no bushing to worry about. |
norcalmike Samba Member
Joined: May 14, 2005 Posts: 4166 Location: Campbell, CA
Posted: Wed Mar 07, 2012 2:31 am Post subject: |
I would look at a vacuum leak. is your carb new or old? check the throttle shafts. Also, as mentioned before, look at an overheating issue. what is the oil or cyl head temp when it wont start. also, check for fuel output when it wont start. _________________ 73 Thing
61 Double Cab
WANTED: Howe Motors Plate Frames |
Eric&Barb Samba Member
Joined: September 19, 2004 Posts: 9656 Location: Olympia Wash Rinse & Repeat
Posted: Wed Mar 07, 2012 7:19 am Post subject: |
Had same problem and turned out front bushing in the starter itself was too worn. So armature was rubbing inside the field coils and causing it to draw so much electricity that the coil would not fire. The 6 volt starter still turned over great with 12 volts, but it just would not fire...
Or it could be your carb shut off valve is faulty, or the float and allowing fuel to drip down the carb. Had the former leak in hot weather and added a second gasket to solve the problem. _________________ In Stereo, Where Available! |
61TXghia Samba Member
Joined: July 17, 2009 Posts: 907 Location: El Paso, TX
Posted: Wed Mar 07, 2012 8:03 am Post subject: |
Once in a while, the sleeve where the pushrod for the fuel pump sits can swell and bind it. I had a POS Empi product do that to mine. Had to shave some material off of it and it solved that issue. _________________ 61 Ghia
62 Standard Type 2 (Nothing Fancy)
my bus: http://www.thesamba.com/vw/forum/viewtopic.php?t=464719
| bill may wrote: |
| Camping is cheaper than therapy. |
www.swaircooled.com |
Posted: Wed Mar 07, 2012 10:17 am Post subject: |
| quartermilecamel wrote: |
| Um, that bushing will not prevent the engine from firing. It only prevents cranking. Have fun replacing that bushing. It wont solve your problem. Unless when hot it cranks slloowwwllyyy, then you might even have other issues too. Like an overheated engine? |
| Eric&Barb wrote: |
| Had same problem and turned out front bushing in the starter itself was too worn. So armature was rubbing inside the field coils and causing it to draw so much electricity that the coil would not fire. The 6 volt starter still turned over great with 12 volts, but it just would not fire... |
On my old '60 Double Cab, the starter bushing was worn. It would crank fine but wouldn't start... only when hot. Sometimes it would just click though, no cranking at all. It was still 6-volt so I think the same thing happened that E&B describe above. I could tell there was an issue because the battery cables got HOT. Especially the negative cable, I burned my hand on it.
It wasn't consistent though, most of the time it would start and other random times it wouldn't.
If I remember correctly, replacing the bushing fixed it. _________________ How to: Post Photos | Search
"Water is the only drink for a wise man" | "Communication prevents complaints" |
Posted: Wed Mar 07, 2012 1:26 pm Post subject: |
Wow, if thats actually the case then jumpering the coil to battery + would prove the bushing theory, unless its pulling huge amounts of juice, drawing the whole battery load voltage down. _________________ Looking for the U shaped swing arm for sliding door split. Left hand drive. Baywindow arms are 1/2 inch longer. |
big wavos OCTO
Posted: Wed Mar 07, 2012 7:01 pm Post subject: |
| I'll replace the bushing, I've got a newly re conditioned starter that needs to go in as well, Engine does not seem to be getting hot, It is newly rebuilt, and fuel pressure checks out good. I will keep you all posted. |
Posted: Wed Mar 07, 2012 7:13 pm Post subject: |
| big wavos wrote: |
Just remember there are two bushings and both should be checked!! _________________ In Stereo, Where Available! |
mannys66 Samba Member
Joined: November 21, 2001 Posts: 5308 Location: the 108
Posted: Fri Mar 09, 2012 9:10 pm Post subject: |
Interesting, I'm having issues with my pick up as well, it's a 6v starter on a 12v system, it used to spin super fast like any other 6v starter with 12v juice running through it, that motor would start right up, then it went to starting really slow like I had a dead battery, to now not wanting to start at all, tonight I pulled the starter out and the bushing came right out with the starter, all worn out and full of scratches inside and out, the bushings I have in my stash don't look any like what came out of the pick up and they're both 12 and 6v
I'm interested on seeing if your bushing / starter combo would solve your problem, best of luck. _________________ LOOKING FOR VELVET GREEN BUS PARTS
http://the108tradingpost.com/ |
Snoop Bob Samba Member
Posted: Sat Mar 10, 2012 6:44 am Post subject: |
Manny did you mean you have a 12v and a 6v bushing or the 12/6v converison bushing? THere are a few different options, just not sure what you meant. _________________
| BarryL wrote: |
| Put your lips onto the little tit with the hole in it inside and make a good seal. You can suck and blow but with a little resistance. It gets better after it's wet. |
| EverettB wrote: |
| I would be interested in knowing the sizes of the various shafts. |
