Tin under cylinders??? Picture of all tin?
Goto page Previous  1, 2
Forum Index -> Performance - Engines/Transmissions Share: Facebook Twitter
yamaducci
yamaducci is offline
PostPosted: Mon Feb 27, 2012 1:21 pm    Post subject: Reply with quote
I believe you are looking for Awesome Powdercoats Pics.
He is also an advertiser and contributor on here.
http://awesomepowdercoat.com/Original_German_Engine_Tin.html
-John Cox
My 2498 Turbo Re-Build Thread: http://www.thesamba.com/vw/forum/viewtopic.php?p=5578697#5578697
Cox Racing Engines
Class 5-1600's; Stock 1600 to 2498cc Type 1's. Custom Built for you in Maryland
busmania
busmania is offline
PostPosted: Mon Feb 27, 2012 2:26 pm    Post subject: Reply with quote
Wow, yes. That is exactly what I needed. Great source. Im suprised there is not a sticky regarding tin....unless Im missing something.
Max Welton
Max Welton is offline
PostPosted: Mon Feb 27, 2012 3:22 pm    Post subject: Reply with quote
To answer your question, those little air dams go on the underside of the heads. Those little tabs just get pushed between the fins to hold it in.
Just like in BWD's picture.
Max
The only thing more expensive than cheap parts is mixing cheap parts with stupidity.
JustBuggy
JustBuggy is offline
PostPosted: Fri Mar 09, 2012 8:43 am    Post subject: Reply with quote
On a T4 engine, will ALL of the 1800 tins fit a 1700 T4?
Considering they are both NOT upright engines.
busmania
busmania is offline
PostPosted: Fri Mar 09, 2012 9:02 am    Post subject: Reply with quote
Ha! This is one I think i can actually answer. for once (i think). Yes, all of the tin is the same from a 17-1800 type IV. I know way more about the type IV than I do the type I's. If I am wrong, someone will chime in but the ONLY difference in the 17 vs 1800 is the size of the pistons.
spectre6000
spectre6000 is offline
PostPosted: Fri Mar 09, 2012 9:15 am    Post subject: Reply with quote
For the missing cylinder head tiny-tins (off strumming their ukeleles and singing in falsetto), it really is a very simple one to make IF you have a pattern of some sort. It might be commercially viable to sell little cardstock templates for something on the order of $1. Just about anyone can churn out more than their wage in an hour, and thus make a profit (not considering overhead). A product testing phase (put it up to see how it sells) wouldn't cost much either. It would just cost a piece of card stock and an hour or so to churn out a hundred of them and shove them in a folder. $1 is a reasonable price for something like that (especially if you need it), and it would be doing the air cooled world a favor. It is the sort of thing that would require someone with a known and trusted presence (like ACN) to be able to get them out there in any volume. In other words, if I were to make them and throw them up on the Classifieds, no one would take notice. If John were to do so, it would lend credibility to the product from the start (a lot of people don't even know they're missing) and simultaneously serve as a sounding board to build awareness that the need for the product exists.
That's my entrepreneurial $0.02.
-'74 Toyota FJ40 (DD)
-'58 German Market Deluxe Beetle (in progress)
-'57 German Market Karmann Ghia (DD to be)
"Buy the best, cry once." -Gene Berg
"A cheap man will always buy the cheapest thing available, and then buys another one hoping for a better result, and then spends the rest of his life in misery complaining about it. A thrifty man will buy a good part once and never think about it again." -RockCrusher
AlteWagen
Troll
AlteWagen is offline
PostPosted: Fri Mar 09, 2012 2:14 pm    Post subject: Reply with quote
this thread had a ton of good pics. This is why you should NOT use photoshare sites for threads
http://www.shoptalkforums.com/viewtopic.php?f=34&t=113660
Here is a shroud thread
http://www.thesamba.com/vw/forum/viewtopic.php?t=492074
and a few more
http://www.thesamba.com/vw/forum/viewtopic.php?t=401943
http://www.thesamba.com/vw/forum/viewtopic.php?t=416096
http://www.thesamba.com/vw/forum/viewtopic.php?t=471358
kme9418
kme9418 is offline
PostPosted: Fri Mar 09, 2012 10:02 pm    Post subject: Reply with quote
BWD wrote:
What does this little piece do and do I need to fabricate one if I don't have it?
KME9418
1969 VW Beetle
kme9418
kme9418 is offline
PostPosted: Sat Mar 10, 2012 6:53 am    Post subject: Reply with quote
kme9418 wrote:
Who can dig in their scrap pile and send me a couple of those? I will send you $10 PayPal.
KME9418
1969 VW Beetle
busmania
busmania is offline
PostPosted: Sat Mar 10, 2012 7:06 am    Post subject: Reply with quote
and a few more
So much great info, thank you! Anyone have a pic of 8b? I cant seem to figure out what that piece is.
bsairhead
bsairhead is offline
PostPosted: Sat Mar 10, 2012 7:11 am    Post subject: Reply with quote
and a few more
8a and 8b are industrial sled tins, for use without heater boxes.
JustBuggy
PostPosted: Sat Mar 10, 2012 7:46 am    Post subject: Reply with quote
derluftwagen wrote:
Great exploded view!
Have to got an exploded view that you can share like this for a 1700 T4?
flemcadiddlehopper
flemcadiddlehopper is offline
PostPosted: Sat Mar 10, 2012 11:28 am    Post subject: Reply with quote
Are you going for a historically correct engine tin engine,like concours stuff? Just wondering why no one has posted super cool tin (type 3) cylinder tin?
Image may have been reduced in size. Click image to view fullscreen..
This has always been recommended to me with any build.
Gordo.
chrisflstf
chrisflstf is offline
PostPosted: Sat Mar 10, 2012 11:55 am    Post subject: Reply with quote
Type III tin is for Type III, not Type I, even though it will fit. Its not better for a Type I
AlteWagen
Troll
PostPosted: Sat Mar 10, 2012 4:06 pm    Post subject: Reply with quote
The above threads were there to read.
Below is a pic of the tin and a drawing with dimensions so you can make your own.
Dimensions:
Right
Left
Sorry nothing for type 4
Gordo.
Bob Hoover would disagree.
In a situation where no sleds can be used (merged header/baja) modified "cool tin" is worth it. If sleds can be used stick with the stock square deflector tin and the industrial tin or heater box.
Before/After:
Luis ''Diablo'' Gutierrez
Luis ''Diablo'' Gutierrez is offline
PostPosted: Sat Mar 10, 2012 8:54 pm    Post subject: Reply with quote
I just want to share that in 4 bugs i had in the past always that little piece been missing Shocked
66 Shorty wrote:
mexikanischen-deutsch
67'
68'
69' bugs
Reply to topic    Forum Index -> Performance - Engines/Transmissions All times are Mountain Standard Time/Pacific Daylight Savings Time
Page 2 of 2
