My little go-go Class 11
Goto page Previous  1, 2, 3 ... , 10, 11, 12  Next
DocWible
DocWible is offline
PostPosted: Mon Feb 20, 2012 11:26 am    Post subject: Reply with quote
Just a curiosity question, how much extra weight do you think the bed liner paint added to the car? It would seem to me that the bed liner would be heavier than regular paint, but mayben its not... Question
biblethumpncop
biblethumpncop is offline
PostPosted: Mon Feb 20, 2012 12:13 pm    Post subject: Reply with quote
The whole kit probably weighed about 25 lbs in kit form.
If you blame others when you fail, give them credit when you succeed!
1973 Bugeye Baja
My current project with my teenage son, Ryan.
http://www.thesamba.com/vw/forum/viewtopic.php?t=537929
Copernicus
Copernicus is offline
PostPosted: Mon Feb 20, 2012 12:38 pm    Post subject: Reply with quote
I used herculiner. Probably weighed about the same. Most things you here about it adding a lot if weight is untrue
1970 standard baja, roller.
1970 standard baja, 1915cc
DocWible
DocWible is offline
PostPosted: Mon Feb 20, 2012 12:51 pm    Post subject: Reply with quote
Interesting, I guess in the ends its still just paint. Thanks for the info.
biblethumpncop
PostPosted: Mon Feb 20, 2012 10:02 pm    Post subject: Reply with quote
Its getting closer...
1973 Bugeye Baja
vwboat
vwboat is offline
PostPosted: Tue Feb 21, 2012 8:01 am    Post subject: engine endplay Reply with quote
BTC,
I think you are going to have your engine back in before me. I have mine back togather and was checking endplay while getting ready to put in main seal and found that my endplay was way way off. Think I need to tear it back down and split case and do a total rebuild. Didn't check endplay before I did the heads and p@c, my bad.
case may need machine work or may be junk, I will know when I get it apart.
Dirtjunkie, know a good machine shop?
John
Dirt Junkie
Dirt Junkie is offline
PostPosted: Tue Feb 21, 2012 9:37 am    Post subject: Reply with quote
European Machine is the best in town.
Club AZ Baja President!
or as my boys call me "El Presidente"
Now Celebrating my 27th year of being Addicted to VWs.
vwboat
vwboat is offline
PostPosted: Tue Feb 21, 2012 8:00 pm    Post subject: endplay Reply with quote
Thanks Dirt Junkie for the info. I will tear my engine down and see what's inside and go from there.
John
biblethumpncop
PostPosted: Tue Feb 28, 2012 9:10 pm    Post subject: Reply with quote
Looking good Eric!
1973 Bugeye Baja
pafree
pafree is offline
PostPosted: Tue Feb 28, 2012 9:22 pm    Post subject: Reply with quote
that engine is going to look and sound good in your car.
1972 vw hunting truggy
sand it, fill it, paint it, throw some mud on it and then baja it.
auslander
auslander is offline
PostPosted: Wed Feb 29, 2012 8:50 am    Post subject: Reply with quote
Coming along nicely Very Happy Very Happy Very Happy
Wandering
66 POS Bus
69 Class 11 Beetle
!!! F**k Cancer !!!
Time's Tide will Smother You
"You can't throw a rock in Long Beach without hitting a tweaker" Steve Tucci
biblethumpncop
PostPosted: Sun Mar 11, 2012 9:55 am    Post subject: Reply with quote
There were a few set backs, but I hope it will be back on yhe road today. I picked up some KYB shocks for the front as my last outing blew the front shocks and ripped the ball joint boots. I'll need to do something aboit those later.
I have been contemplating how to seal the engine since I have a 3" body lift. I saw Earthquake cut his metal seal groove off and welded on a 3" extension. I wonder if I could find 3" of rubber and somehow affix it to the factory style seal? Maybe a roll of 3" flexible fender flare that I attach to the tin, upwards and run the engine seal from the body to meet it? I like this idea but wonder how they would withstand heat from the engine compartment. http://www.jcwhitney.com/rubber-fender-extensions-fender-flares/p2008750.jcwx?filterid=j1
Another thought I have is forgoing the seal and looking for another method of preventing heat from building in my engine. Perhaps keeping the decklid off? Using decklid standoffs? Modifying my stock decklid so that much of the sheet metal is replaced with expanded metal like my running boards?
1973 Bugeye Baja
dirtkeeper
dirtkeeper is offline
PostPosted: Sun Mar 11, 2012 11:17 am    Post subject: Reply with quote
currently on mine i did cut out the ledge and lip and lowered the stock seal. this is nice because it also helps in that the spark plug access isnt blocked by that sheet metal in the stock location with the 3 " lift. tedious little job but worth it. Originally what i had for many years was i attached a piece of metal on the edges of the tin at the outer edge on the sides that came up and met the engine rubber seal, around the front i had a piece of some 1/2 " by 2" or so rubber that stood vertical and flexed around the curved front of the compartment. Not sure where i got that rubber but it came off a tire ??maybe or something else i found lying around at the time. This set up sealed well but i am happy that i lowered the whole seal location for the spark plug access. Another method may be to use the stock seal on the compartment and then screw an additional stock seal onto the engine tin, but the seals do get dried out and deformed and may not seal permanently.
As far as cooling you should be ok . I have a larger engine and i have over heat issues only hot days because i need to get an engine lid that has the vent s in it or use standoffs. This would help with your cooling too if you need it. I have also considered doing screened hole behind the license plate. I really like the looks of the non vented hood.
biblethumpncop
PostPosted: Tue Mar 13, 2012 7:46 am    Post subject: Reply with quote
Thanks Earthquake.
She's alive! Smooth and 50% more power than the little 1385. What a difference in power. Imagine addind 15-20 hp on your engine. Thats what I did by switching engines. The Tri Mill muffler has a deep, throaty sound.
1973 Bugeye Baja
AZ-BUG
AZ-BUG is offline
PostPosted: Wed Mar 14, 2012 7:17 pm    Post subject: Reply with quote
Sweet! Sounds like someone is enjoying his "new" ride!
vwboat
vwboat is offline
PostPosted: Fri Mar 16, 2012 8:06 am    Post subject: tight rod journal Reply with quote
BTC,
All parts back from shop. Starting to set up crank. all new bearings(rod and main and cam) everything is standard size. One of the rods doesn't seem right on the crank. The rod seems to tight on any journal, all other rods fit good on any journal.Checked rod bearings and they are standard size and the rod checks out ok as far as being round. put rod on journal and torked it to spec and it seems better but still really tight on journal. Have to think about this for awhile. Crank was polished while in the shop.
Good to hear your engine is running GREAT, hope mine will be OK.
John
biblethumpncop
PostPosted: Sat Mar 17, 2012 1:36 pm    Post subject: Reply with quote
I hooked up the fresh air hoses and heater tubes, then miunted the front KYB shocks. I filled up with 87 octane, which is cool because I had to run 91 octane with the 1385cc engine. I am trying to put some miles on it this weekend so I can break it in and drain oil/adjust valves.
The carb's choke isn't working right, so that will get worked on this week.
1973 Bugeye Baja
biblethumpncop
PostPosted: Sun Mar 18, 2012 10:21 am    Post subject: Reply with quote
Changed the oil and adjusted valves. I'm fabricating an engine seal extension using a firehose. I have a 3" gap because of the body lift. I figure the firehose should withstand the engine compartment temps, and be flexible enough to allow some room to change the spark plugs.
1973 Bugeye Baja
dirtkeeper
PostPosted: Sun Mar 18, 2012 11:10 am    Post subject: Reply with quote
good idea Idea
biblethumpncop
PostPosted: Sun Mar 18, 2012 5:45 pm    Post subject: Reply with quote
good idea Idea
Yep, the firehose worked. I used a nut/bolt every 4" to hold the firehose to the rubber seal. Then I drilled holes in my tin and mounted the firehose to it. I may look for an adhesive/contact cement that will seal the two rubber items together in the spaces between each bolt.
1973 Bugeye Baja
Page 11 of 12
