gprudenciop Samba Member
Joined: July 06, 2008 Posts: 606 Location: portland or
66 Shorty Samba Member
Joined: May 10, 2007 Posts: 916 Location: Rhode Island
Posted: Wed Mar 14, 2012 4:05 am Post subject: |
I'm no experrt, but, they don't look like total seals to me either... _________________ ~X-Man~
'60's Spatz Buggy body on '74 Chassis (Budget Build)
'69 Bug (Baja-to-be partial daily)
'10 Silverado (My daily) |
yamaducci Samba Member
Joined: March 30, 2010 Posts: 2335 Location: Mount Airy, Maryland
Posted: Wed Mar 14, 2012 5:32 am Post subject: |
Nope not Total Seals They come separate. Not on the pistons and each ring is a two piece.Usually VWs only use the two piece full circle ring in the second grooveonly. The top and oil are normal. _________________ -John Cox
My 2498 Turbo Re-Build Thread: http://www.thesamba.com/vw/forum/viewtopic.php?p=5578697#5578697
3rd Brake Light Safety Stars- I still have a couple with blue light left. Email me if interested. |
Stripped66 Samba Member
Joined: May 31, 2005 Posts: 3470 Location: Charleston, SC
Posted: Wed Mar 14, 2012 5:52 am Post subject: |
Total Seal makes conventional rings. Unless you were specifically told you were receiving a gapless top-ring (which those are not), you may very well have received conventional Total Seal rings.
Misadvertised or misunderstood? Go back and check the ad or talk to the seller. Otherwise, run 'em. _________________
66brm wrote: |
Bodacious wrote: |
Why not just make a custom set of wires with a Y splice in them. Then you could just run one distributor. |
I don't think electrickery works that way |
mark tucker Samba Member
Posted: Wed Mar 14, 2012 7:49 am Post subject: |
top ring will apear as stock, the 2nd will be a 2 peice ring assy, if you have gapless.
they do however have a gapless top ring also.but I doubt they have them for vw. |
Posted: Wed Mar 14, 2012 9:24 am Post subject: Re: piston ring help |
Total Seal is a brand, not a style. What most people think are "Total Seal Rings" are actually "Gapless Rings". Childs & Albert used to make a gapless ring too, I don't know if they still do.
But Total Seal also makes conventional ring sets. Read the description closely, some people are tricky.
There are "Z-Gap" rings where the end isn't straight, making the ring slot a non-straight path. Then there is the more common dual ring on one ring land, eliminating the gap entirely. _________________ It's just advice, do whatever you want with it!
"Like" our Facebook page at
and get a 5% off code for use on one order for VW Parts ON OUR PARTS STORE WEBSITE, vwparts.aircooled.net |
Posted: Wed Mar 14, 2012 9:35 am Post subject: Re: piston ring help |
[email protected] wrote: |
Or honest. Conventional Total Seal rings are one of only two types of rings to push an acVW door-slammer into the 7's in the 1/4 mile. I don't know how many sellers/vendors realize that might be a good selling point.
But you're right; the majority of folks read "Total Seal" and think "gapless ring", instead of differentiating what product they are actually receiving. TS conventional rings are great rings. _________________
66brm wrote: |
Bodacious wrote: |
Posted: Wed Mar 14, 2012 10:17 am Post subject: |
So the seller swears they are total seal top rings that are harder than normal rings,funny thing is that he asked me if I had the "special tool"to install total seals when I said no he was going to hook me up and have them ready to just install well I'm glad I can never leave well enough alone!also he was aware that this was going on a Turbo motor makes me feel[url] http://m.youtube.com/watch?v=gh5xu35bAxA[/url] |
Posted: Wed Mar 14, 2012 11:22 am Post subject: |
gprudenciop wrote: |
also he was aware that this was going on a Turbo motor... |
Then be thankful he made the right choice for you. _________________
66brm wrote: |
Bodacious wrote: |
Posted: Wed Mar 14, 2012 12:24 pm Post subject: |
Stripped66 wrote: |
Then be thankful he made the right choice for you. |
So do you think I should run these? |
Posted: Wed Mar 14, 2012 12:58 pm Post subject: |
Stripped66 wrote: |
Yes. The Eric Calabrese uses Total Seal conventional rings in the Red Baron...they are good enough to run 7's in the 1/4 mile; and, I figure they are good enough to run in my own engine. I would not want to run a gapless top ring on a turbo engine, and the benefits of gapless rings on our acVW engines is equivocal at best.
Run 'em. _________________
66brm wrote: |
Bodacious wrote: |
Posted: Wed Mar 14, 2012 1:39 pm Post subject: |
I understand what your saying stripped but these are going back to the seller!its not that he was looking out but that he knew what I wanted there was no confusion on the direction I was heading and I was very specific on what I wanted!also the special tool needed to install these in the cylinders?even if I have made a mistake with not running these and he was trying to help me it has put doubt in my mind and I will never by from them again!by the way this is a well known shop in Cali. |
Posted: Wed Mar 14, 2012 1:55 pm Post subject: |
You asked what it was, and if you should run them. It's a conventional top ring, and yes you should run it.
If you paid an extra $90+ for just the gapless top-ring and didn't receive it, then I understand your complaint. I would also reconsider running a conventional top-ring on your turbo engine when you shop for new rings.
If you didn't pay anything extra for what you received, then it is what it is, a conventional ring-set (which, BTW, runs about $70 for the conventional top, 2nd, and oil ring set from Total Seal).
Good luck with getting this all worked out! _________________
66brm wrote: |
Bodacious wrote: |
Posted: Wed Mar 14, 2012 2:07 pm Post subject: |
Yes stripped 95dlr extra!again thanks for your insight!as the saying goes don't do good things that look bad and also do bad things that look good!thanks |
modok Samba Member
Joined: October 30, 2009 Posts: 26785 Location: Colorado Springs
Posted: Wed Mar 14, 2012 5:04 pm Post subject: |
Those do not appear to be total seal brand rings, the oil ring looks different.
Perhaps a mixed set made from leftovers? hygradin rings and selling off the dregs |
Posted: Wed Mar 14, 2012 5:22 pm Post subject: |
modok wrote: |
Those do not appear to be total seal brand rings, the oil ring looks different. |
Total Seal doesn't make an oil ring for the VW...they repackage another brand's oil ring (IIRC, Grant?). You're correct that those oil rings do not appear to be the same style TS has used in the past (at least from what I've seen/received from TS), but since they don't make it themselves, only TS could confirm whether they switched to a different supplier. _________________
66brm wrote: |
Bodacious wrote: |
modok Samba Member
Posted: Wed Mar 14, 2012 5:32 pm Post subject: |
That is true, maybe the different sizes look different, vw being such odd sizes
If you can get a part number for what those rings are supposed to be, that would be helpful, or don't bother. Get your money back and buy some proper rings, like the classic race ones, (ductile iron moly faced ring!) |
Posted: Wed Mar 14, 2012 7:19 pm Post subject: |
perhaps you just paid for the top turbo ring/No2 steel ring package. inquire and request the gapless 2nd to go with it.and the steel ring s tend to not last real long& hard on the cylinders if thats what you have .they do have a few different right types, thus the price diff in a street ring&race ring, then there is the speciality ring for different app.I might be talking out somebodys ass but I would think they offer those for vw as they do for real race motors. i was a total seal dealer many moons ago, have instaled hundrads of them with out a single issue(exception of 1 ring breakage upon instaling on piston&they had one to me the next day NC)I have used 3 sets of C&A zero gaps, & did not like them.they were in for about a month then went back to total seal gapless. |
Posted: Wed Mar 14, 2012 8:00 pm Post subject: |
I don't like chrome faced rings, they take FOREVER to break in (if they ever do). Grants suck. Deves are the best by far. Hastings are also excellent. I used to use Total Seals, but found prepping the cylinder properly was more important than using a gapless ring, so I stopped using them. I would use a gapless 2nd ring on a turbo engine though. _________________ It's just advice, do whatever you want with it!
Posted: Thu Mar 15, 2012 9:37 am Post subject: |
Thanks for your insight into this problem!john do you carry total seal brand? I also edited the topic since there is some good info on TS. |
