Overheating in 50 degree weather?
Page: 1, 2, 3  Next
crvc
crvc is offline
PostPosted: Wed Mar 14, 2012 9:48 am    Post subject: Overheating in 50 degree weather? Reply with quote
I have a '67 bug. All engine bay seals are in. There are no unneccesary holes in any of the engine tin. Necessary holes all have tight grommets. This bug could float, like the old VW ads showed.
The bug also has no vents in the engine lid. I posted a while ago about the bug dying on the first long drive of the year. You guys had suggestions but the consensus was vapor lock. Since then I've replaced the fuel pump, made sure the thermostat and flaps are all working, replaced the cloth and metal fuel line with German quality items.
Although it's a '67 bug the engine is a circa '73 DP 1640cc with a custom cam. So it produces a lot more heat than a standard bug but with no real venting to dissipate it. Am I doomed to use hinge standoffs? They look dorky as hell, like something a kid would do.
None of the other options seem any better. I don't want to cut up the lid. I don't want to remove the bay seals or tin. In Louisiana in August I never had my bug overheat and now I'm wondering if it was because I had left a lot of the seals and tinware off.
Any suggestions?
crvc
GB2S
GB2S is offline
PostPosted: Wed Mar 14, 2012 9:54 am    Post subject: Reply with quote
Do a complete tuneup, timing, valve & point gap.
Geoff
1963 Ragtop
crvc
crvc is offline
PostPosted: Wed Mar 14, 2012 10:06 am    Post subject: Reply with quote
Geoff
Did all that the day before the long drive.
crvc
Max Welton
Max Welton is offline
PostPosted: Wed Mar 14, 2012 10:44 am    Post subject: Reply with quote
I recommended a diagnostic step to show if you do or don't have a vapor lock problem.
Right after the engine stops, squirt some cold water on the pump and the fuel line. This will cause any vaporized fuel in the pump or line to cool and return to a liquid state that can be pumped.
If that helps, it was vapor lock.
Max
1967 Type-3 Fastback
crvc
crvc is offline
PostPosted: Wed Mar 14, 2012 11:12 am    Post subject: Reply with quote
Max
I left the engine idling for an hour or so but it didn't get hot enough to induce vapor lock. I had planned, on my next long drive, to bring a couple gallon jugs of water but haven't had the guts to try any long drives yet.
My wife is making a three hour drive to civilization (Salt Lake City) this weekend and will pick up a pair of standoffs.
crvc
Max Welton
PostPosted: Wed Mar 14, 2012 11:20 am    Post subject: Reply with quote
You already know that if it quits, all you have to do is wait a while, right? So just go for a drive. Wink
Max
GB2S
GB2S is offline
PostPosted: Wed Mar 14, 2012 11:52 am    Post subject: Reply with quote
Do you have a way to check Oil pressure, Oil temp. What is the status of the oil pressure relief valve. The thermostat might be working but are the fins operating properly. Have you drive with the heat on? (air flow)
Geoff
1963 Ragtop
AlteWagen
Troll
AlteWagen is offline
PostPosted: Wed Mar 14, 2012 1:07 pm    Post subject: Reply with quote
A 1641 should not generate any more heat than a 1500 unless tuned incorrectly or has super high compression.
The only problem I see is if you really are overheating the paper thin cylinder walls of the 87mm slip in p&c, they are probably toast and will need replacement. The only thinner cylinders that were made were the 88mm slip ins which warped so bad that they stopped production.
I would do a compression test to see how badly they are damaged
pantone149
pantone149 is offline
PostPosted: Wed Mar 14, 2012 1:17 pm    Post subject: Reply with quote
Save your money. Don't buy stand-offs. Do a tennis ball stand-off and see if it matters.
Max Welton
PostPosted: Wed Mar 14, 2012 3:01 pm    Post subject: Reply with quote
One drinking water bottle is enough. Even a little squirt-bottle so you can just hit what you are aiming at.
I now have visions of you dumping a couple of gallons on your engine and drowning the ignition system. Laughing
Max
vwsteve
vwsteve is offline
PostPosted: Wed Mar 14, 2012 5:39 pm    Post subject: Reply with quote
The dog house shroud needs more air. I have a 1200 converted to doghouse and it will run hot without stand offs or tennnis ball. With the tennis ball, it stays cool.
Eric&Barb
Eric&Barb is online now
PostPosted: Wed Mar 14, 2012 6:27 pm    Post subject: Reply with quote
Make sure the engine insulation on the front fire wall is not loose and getting sucked over the cooling fan opening.
Which fan shroud are you using?
What size cooling fan do you have?? Inside measurement between the discs that make up the fan body.
What cruising RPM are you running?
Do post images of the engine in question.
In Stereo, Where Available!
VOLKSWAGNUT
Fastest VW Belt Changer
Location: Flippin' a Belt........ .... Off-n-On ... NC USA
VOLKSWAGNUT is offline
PostPosted: Wed Mar 14, 2012 6:46 pm    Post subject: Reply with quote
I'd use the tennis ball way before stand offs.
With a bumper on the car you hardly even notice the lid cracked open with it.
You say its running hot.
How do you know? What actual measurements have you made, and if so what temps is the engine oil, and heads.
Are you assuming vapor lock means its overheating? Thats assuming wrong.
How is the fuel line routed?
Are you using a metal tube on the engine?
Are you using the proper fuel pump insulator?
aka Ken {o\!/o}
Rebuilt to drive not decorate
Usually and often edited
Max Welton
PostPosted: Wed Mar 14, 2012 7:33 pm    Post subject: Reply with quote
How about we get everybody caught up?
http://www.thesamba.com/vw/forum/viewtopic.php?t=502303
Max
usrname
usrname is offline
PostPosted: Wed Mar 14, 2012 7:51 pm    Post subject: Reply with quote
Did you time the engine to total advance?
Bugugly
Bugugly is offline
PostPosted: Wed Mar 14, 2012 7:53 pm    Post subject: Reply with quote
Have you tried a dipstick sensor? Maybe it's not really that hot. If you have a sensor the oil light comes on when it gets hot. I swear by one..
http://www.savemybug.com
"When it rains...
It Pours"
Hammarlund
Hammarlund is offline
PostPosted: Thu Mar 15, 2012 9:59 am    Post subject: Reply with quote
Yow! The OP's last post on the thread referenced by Max:
I noticed the oil level is going up on the dipstick...
I hope the OP checked his oil to make sure it didn't smell like gasoline!
crvc
crvc is offline
PostPosted: Thu Mar 15, 2012 11:28 am    Post subject: Reply with quote
[quote="Hammarlund"]Yow! The OP's last post on the thread referenced by Max:
I hope the OP checked his oil to make sure it didn't smell like gasoline![/quote
Years ago I had a bug that kept filling the crankcase with gas. The root cause was not enough gaskets on the fuel pump. Ultimately I took the engine apart thinking the gas must have damaged the bearings. What I found was the cleanest innards I've ever seen on a motor. Plus the bearings looked fine. So for now I don't mind that this motor might be adding gas to the crankcase. I just don't drive it much while I wait for the new fuel pump vacuum guage to come in the mail.
crvc
Culito
11010101
Culito is offline
PostPosted: Thu Mar 15, 2012 4:46 pm    Post subject: Reply with quote
crvc
How's that happen? Confused
Copyright CJ Industries, Inc.
'64 standard w/2.0L type 4
'62 bug
johnnypan wrote:
Max Welton
PostPosted: Thu Mar 15, 2012 6:07 pm    Post subject: Reply with quote
What is a "fuel pump vacuum gauge"?
Max
Page: 1, 2, 3  Next
