full flow drilling, by hand possible? Or press..
Goto page 1, 2, 3  Next
Forum Index -> Performance - Engines/Transmissions Share: Facebook Twitter
ekacpuc
ekacpuc is offline
PostPosted: Thu Mar 15, 2012 7:23 pm    Post subject: full flow drilling, by hand possible? Or press.. Reply with quote
When I drill this sucker out for full flow is it realistic to use a hand drill? Difficult for me to find a drill press to use. Risky? The cause is appart...
Will be using a 9/16" bit.
Greg
baked beetle
baked beetle is offline
PostPosted: Thu Mar 15, 2012 7:31 pm    Post subject: Reply with quote
Do it with a friend, to help try and keep you straight. If you do it by yourself it WILL go in the opposite of what you want Very Happy
These days people like me are hard to find- we don't give a damn what you think, about what we think. - JR
____________________
66' His
57' Theirs
63' Hers
62' Drag Bug - Theirs 13.1 @ 101 mph (GONE)
MURZI
MURZI is offline
PostPosted: Thu Mar 15, 2012 7:45 pm    Post subject: Reply with quote
My preferred "at home method" is to drill a small hole and gradually open it up with bigger bits and then finish with the drum sander part of my dremel. It fits perfect to finish that hole and makes it tidy.... If a big bit grabs.....later case. Nerve racking.
[img]www.hardwarestore.com/pop-print/larger-image.aspx?prodNo=4211[/img]
PENNY LOAFER MAFIA..step up or step back...
1962 Beetle Convertible http://s23.photobucket.com/albums/b374/MURZI/new%2062%20vert/
1968 BAJA http://s23.photobucket.com/albums/b374/MURZI/testmule/
My old Dune Buggy http://s23.photobucket.com/albums/b374/MURZI/
Quit playing...build a 2276 and be done with it.......
ekacpuc
ekacpuc is offline
PostPosted: Thu Mar 15, 2012 8:02 pm    Post subject: Reply with quote
Good idea. I tend to miss the little things.. Prob over thinking it. I'll use a hand drill with a buddy go one size up at a time.
I've never drilled magnesium, is it softer or harder than aluminium? I've worked with ALOT of mild steel and a little aluminium (too soft for me).
Greg
66brm
66brm is offline
PostPosted: Thu Mar 15, 2012 8:03 pm    Post subject: Reply with quote
Softer, go slow, use tapping lube to help
Aust. RHD 66 Type 1
Aust. RHD 57 Type 1 Oval
[email protected] wrote:
Kadrons are horrible excuses for carburetors.
modok wrote:
I am an expert at fitting things in holes, been doing it a long time
MURZI
MURZI is offline
PostPosted: Thu Mar 15, 2012 8:10 pm    Post subject: Reply with quote
It helps to use tape on the bit as a depth gauge as well. And I can not stress how careful you need to be with a large bit and it grabbing a chunk out of the case. The dremel can go real slow.....and you can control the depth.
BugMan114
BugMan114 is offline
PostPosted: Thu Mar 15, 2012 8:13 pm    Post subject: Reply with quote
i wouldn't use an electric hand drill personally. when you get down into the galley that goes to the pump, the drill wants to catch, and the drill stops and can crack the case. magnesium is very soft, and i always use a hand drill (not electric, the hand crank type drill, like the one below):
only takes about 3 minutes if that, going slowly. its that easy to drill. last time i did it in the car, and used a drill bit and vice grips to turn it, lol. even then it only took 15 minutes. it is better to use a reamer, instead of a drill bot to get the taper for a pipe thread tap to work correctly. but what i do is just cock the dril bit sideways a little when drilling, but around in a circle to create a slight tapered bore. done it several times, with great success. if you've never done it before tho, i'd strongly recommed a tapered reamer. You'd have to find it online somewhere tho.
1974 Super Beetle: Custom resto in progress
1972 Super Beetle: Daily Driver
1971 Std. Beetle w/ 1929 Mercedes Benz Gazelle kit
1960 Baja Bug
1969 Baja Bug
Sand Rail- Homemade
Sand Rail- FUBAR
Aircooled Airheads
Why the hell do they call it a gland nut. its obviously a big fat bolt!!!
the2ndcashboy
the2ndcashboy is offline
PostPosted: Thu Mar 15, 2012 8:17 pm    Post subject: Reply with quote
I've never drilled a VW case, but I drill holes in various kinds of metal for a living (aircraft structures mech) and typically softer material= higher speed and lighter pressure. Harder material= slower speed and heavier pressure. If I was drilling mag I would use high RPM (2500+ until 1/4" or so, then 2000+ up to 1/2") and very light pressure. Just let the drill do the work. If you've got a 1/4 hole and are stepping it up to 3/8, and the bit takes a big bite, it will pull itself right into the hole and into the other side of the oil galley, possibly cracking it in the process. Hence drilling with high speed and low pressure. The drill takes smaller "bites" and can't pull itself into the material.
Edit: All this is assuming you have a good air drill with a spindle that runs true. If you're working with an old wobbly 18v Dewalt, you're on your own.....
SRP1 wrote:
You see....... He talks in code and translation requires a priest, geologist, astronomer, biophysicist, and Indiana Jones.
modok wrote:
If anything comes out perfect it just means your measuring tools are substandard.
BugMan114
PostPosted: Thu Mar 15, 2012 8:28 pm    Post subject: Reply with quote
its not a question of the metal, its the galley that intersects it. as you start drilling. look at this pic:
you can see how about 1/2'' down the hole, the wall dissapears, because the gallery for the oil pump outlet is there. once you drill past this point (which you have to or else the tap won't fit), the drill bit starts catching this edge. if you try to go fast, the only thing that will happen is the drill bit will catch, and either snap the drill bit in half, crack the case (there's not a lot of material there, and its easy to crack), or the drill will break your hand as it jerks and twists around. this isn't an issue with a drill press, but with a hand drill, it is.
1960 Baja Bug
1969 Baja Bug
Sand Rail- Homemade
Sand Rail- FUBAR
Aircooled Airheads
ekacpuc
ekacpuc is offline
PostPosted: Thu Mar 15, 2012 8:39 pm    Post subject: Reply with quote
Hmm... Maybe this isn't worth it to have a filter... I could just change the oil alot.
Thought full flow would be nice for two reasons, 1 for a filter and 2 to put a external oil cooler in the cab during winter time for heat (still use stock cooler too).
Greg
ekacpuc
ekacpuc is offline
PostPosted: Thu Mar 15, 2012 9:03 pm    Post subject: Reply with quote
So... Why are you guys using the angled fitting then the barb? Why not just use a barb? My bug is up in my parents' yard so I can't remember if something is in the way.
Greg
MURZI
MURZI is offline
PostPosted: Thu Mar 15, 2012 9:06 pm    Post subject: Reply with quote
The crank pulley tin gets in the way...it has to be angled.
mxracer
mxracer is offline
PostPosted: Fri Mar 16, 2012 5:16 am    Post subject: Reply with quote
Don't be afraid of this....
Just be careful when you get down to the galley, don't put pressure on the drill like you are drilling a 1/2 in hole in a bull dozer blade or something and you'll be fine.
I use a cordless drill with the correct sized bit for my fittings, then ream with a pipe reamer and tap the hole...done
Magnesium is similar to aluminum when working with it, it doesn't auto-magically catch on fire, doesn't crack when you look at it, and it won't fall apart if you touch it. Smile It is a little more prone to crack but again if you use a little common sense and finesse you'll be fine.
yamaducci
yamaducci is offline
PostPosted: Fri Mar 16, 2012 6:36 am    Post subject: Reply with quote
It's easy to just use a regular variable speed drill . I have a couple pics in my gallery of tapping the case. Not a ton of detail....
The main thing is to start off with a pilot hole if you are coming in from the side. If youare going straight in then you can go with the final size. Use some kind of cutting oil, motor oil or wd40 and go in a couple threads then back off then a couple more. Clean the threads off the tap if it gets too difficult and test the nipple a couple times until you know when to stop.
-John Cox
My 2498 Turbo Re-Build Thread: http://www.thesamba.com/vw/forum/viewtopic.php?p=5578697#5578697
Cox Racing Engines
Class 5-1600's; Stock 1600 to 2498cc Type 1's. Custom Built for you in Maryland
66 Shorty
66 Shorty is offline
PostPosted: Fri Mar 16, 2012 6:50 am    Post subject: Reply with quote
HERE'S a good article about full flowing a case, it might help!
~X-Man~
'66 Custom Shortened Bus (on the back burner)
'60's Spatz Buggy body on '74 Chassis (Budget Build)
'04 Bug (Womans daily)
'00 Blazer (My daily)
yamaducci
PostPosted: Fri Mar 16, 2012 7:20 am    Post subject: Reply with quote
That article is great. Except one thing, After I thought I lost my Snap-On/Bluepoint Dent puller I purchased the one pictured out of desperation.
When I slammed the weight back to pull the plugs, the non-welded handle spread open with my hand between it and the weight. Take a look and you will see what I am saying.
It's a real unsafe design so be careful or weld the loop handle closed.
I found the better dent puller and now can do a case in a few minutes. Good tools pay off and are more safe.
-John Cox
Cox Racing Engines
66 Shorty
PostPosted: Fri Mar 16, 2012 7:24 am    Post subject: Reply with quote
I agree that IS a garbage puller! I have a good (OLD) one here to do the job... I was just showing the guy an article I found that seems pretty helpfull! It also helps that I work at a machine shop & have access to the Bridgeports as well as drill presses if neededd... But, I find I can do pretty much anything needed to be done on a Bridgeport that can be done on a drill press. Wink Plus, the right tools! We have the tappered reamers & correct taps with the proper cutting fluid for Aluminum/magnesium... Cool
~X-Man~
Dangermouse
Dangermouse is offline
PostPosted: Fri Mar 16, 2012 12:15 pm    Post subject: Reply with quote
If you don't have or have access to a slide hammer or dent puller for removing the plugs; here's an alternative...
Centre punch the plug and drill it...
Tap for an M6 bolt...
and thread one into the plug through a washer and socket...
and pull the plug by tightening the bolt against the socket..., out she pops smooth as you please.
Another piece of great advice I got was to use an interrupted tap -
This cuts through magnesium like butter.
and a reamer takes some of the stress of the case and is recommended
I did mine by hand with a variable speed power drill; just go easy with it. But at the larger size bit it will catch, jam and belt you one in the process so while a higher drill speed might be appropriate for softer metal, I'd say take it slow to minimise damage to the case and to yourself...
Feel the fear and do it anyway Cool
Do not follow me, for I may not lead. Do not lead me, for I may not follow. Do not walk beside me either; actually just bugger off and stand over there will you.
earthquake
earthquake is offline
PostPosted: Fri Mar 16, 2012 12:26 pm    Post subject: Reply with quote
Here's a good place to get a taper reamer for the tap, it makes it eiser to tap a tapered pipe thread and puts less stress on the case.
http://drillsandcutters.com/reamers_tapepipe_spf.aspx
Casey
74 CLASS 11 LOOK-A-LIKE
65 pan [I haven't decided what to do with it]
69 DUNE BUGGY
79 INTERNATIONAL SCOUT II
05 SCION XB SERIES RELEASE 2[#437]
Some where in Kenya, A village is missing its Idiot!
"If you put the federal government in charge of the Sahara Desert, there would be a shortage of sand in 5 years"
kreemoweet
kreemoweet is offline
PostPosted: Fri Mar 16, 2012 1:52 pm    Post subject: Reply with quote
I did this by hand, found it impossible to control bit grabbing in case, no matter how slow or light pressure, very nearly ruined
my brand new case! I strongly second the suggestion above to use a hand brace, rather than a powered drill motor. You can
also cut/grind down the nose of your 3/8 tap, otherwise you will have to drill your tap hole deeper than really necessary.
'67 bug: seized by the authorities
Reply to topic    Forum Index -> Performance - Engines/Transmissions All times are Mountain Standard Time/Pacific Daylight Savings Time
