TheBusDrummer Samba Member
Joined: April 30, 2011 Posts: 18 Location: Oxford, Michigan
Posted: Sat Mar 17, 2012 10:27 am Post subject: Bus stops running |
Can somebody help? Bus stops running every time i put in get gear. Engine sometimes shuts down, other time it acts like it's running out of gas. What would cause this? Bus was tunned up before winter (plugs, cap, wires, rotors, points, oil etc...) _________________ ___________________________________
Cooper
1975 Automatic Transporter
1977 Automatic Westy |
Daisy71Kombi Samba Member
Joined: July 21, 2011 Posts: 85 Location: post falls ID
Posted: Sat Mar 17, 2012 10:35 am Post subject: |
Had the same thing and the VW shop replaced the carburetor ($80 w/ labor) and adjusted the timing. Said it was from sitting so long and it fixed my problem. I was also told not to the let the bus set and once you fire it up to drive and not wait for it to warm up. I usually have problems after it sits for weeks for the first few minutes and then it goes away. _________________ Her name is Daisy. 1971 Kombi camper. Pop up tent. 77K miles. Engine rebuilt recently. Just completed brakes with all new parts! |
1975 Kombi Samba Member
Joined: August 12, 2007 Posts: 2046 Location: Acton, Ontario, Canada
Posted: Sat Mar 17, 2012 11:07 am Post subject: Re: Bus stops running |
| TheBusDrummer wrote: | | Can somebody help? Bus stops running every time i put in get gear. Engine sometimes shuts down, other time it acts like it's running out of gas. What would cause this? Bus was tunned up before winter (plugs, cap, wires, rotors, points, oil etc...) |
FI or carbs. _________________ Brett
"I do not see things as black and white, but everything as very colourful!"
'75 Kombi/Westy (2.0L CV, H-Lifters, '75-'79FI mix, XR700, 003 Auto) project.
03 Jetta TDI, 04 Honda civic, 71 super beetle
Licensed pilot (single engine land VFR)
Rust In Peace: 72 Bug, 73 Bug, 81 Rabbit LS D 2D, 83 Rabbit D 2D, 84 Jetta TD GL, 85 Jetta D, 68 Z28 RS 302, 91 Passat 16v |
whenhoboesfly Samba Member
Joined: April 06, 2008 Posts: 122 Location: Puyallup, Wa
Posted: Sat Mar 17, 2012 11:24 am Post subject: |
| Quote: | | once you fire it up to drive and not wait for it to warm up. |
Why would you not let your oil pressure/temperature build up? _________________ '77 Transporter 2L FI |
Posted: Sat Mar 17, 2012 12:06 pm Post subject: Re: Bus stops running |
| 1975 Kombi wrote: | | TheBusDrummer wrote: | | Can somebody help? Bus stops running every time i put in get gear. Engine sometimes shuts down, other time it acts like it's running out of gas. What would cause this? Bus was tunned up before winter (plugs, cap, wires, rotors, points, oil etc...) |
FI or carbs. |
FI... If I actually get it going and then come to a rest it completly shuts off. _________________ ___________________________________
Cooper
Stuartzickefoose Samba Post Whore
Joined: February 07, 2008 Posts: 5373 Location: Edmonds, WA.
Posted: Sat Mar 17, 2012 12:22 pm Post subject: Re: Bus stops running |
| TheBusDrummer wrote: | | 1975 Kombi wrote: | | TheBusDrummer wrote: | | Can somebody help? Bus stops running every time i put in get gear. Engine sometimes shuts down, other time it acts like it's running out of gas. What would cause this? Bus was tunned up before winter (plugs, cap, wires, rotors, points, oil etc...) |
FI or carbs. |
FI... If I actually get it going and then come to a rest it completly shuts off. |
lets get specific here....which bus, what motor, and a little more history? _________________ MINE - 1978 Westfalia ~ Maisy ~ FI, Hydraulic Valves, Electronic Points, 2.0 (NEED A SET OF HEADS, PM ME IF YOU HAVE A SET)
DAD's - 1972 Westfalia ~ Sticky ~ 1.7(?) 914 motor, allison electronic ignition, electric fuel pump, dual webers w/o choke.
“Don't cry because it's over, smile because it happened.”
“Those who mind don't matter, and those who matter don't mind.” |
Posted: Sat Mar 17, 2012 12:51 pm Post subject: Re: Bus stops running |
Sorry about that, I'm starting to get slightly aggravated at this thing and I'm not thinking straight , Its my 77' westy.. 2000cc.. Automatic, It normally takes a while to get it started and now its just pfft dead, and won't start at all. I found this full of yellow gunk, which I asume is from condensation mixing with oil but why???
I also found this unconnected and just laying in the engine compartment
Cooper
Posted: Sat Mar 17, 2012 12:52 pm Post subject: |
that second pic is causing a vacuum leak, find out where it goes....look EVERYWHERE... _________________ MINE - 1978 Westfalia ~ Maisy ~ FI, Hydraulic Valves, Electronic Points, 2.0 (NEED A SET OF HEADS, PM ME IF YOU HAVE A SET)
Posted: Sat Mar 17, 2012 12:58 pm Post subject: |
| Stuartzickefoose wrote: | | that second pic is causing a vacuum leak, find out where it goes....look EVERYWHERE... |
Do you know what the first thing is? my 75 has one but it was caked with dry oil _________________ ___________________________________
Cooper
SGKent Samba Member
Joined: October 30, 2007 Posts: 17520 Location: State Capitol CA (Sacramento)
Posted: Sat Mar 17, 2012 12:59 pm Post subject: |
the PCV goes on the top of the breather tower on the case and a hose goes to the S-Boot. The plastic piece with the hose probably goes from the S-Boot to one of several places. Look at the decel valve first. _________________ Steve aka Merlin the Wrench
formerly Steve's Racing and Engine Blueprinting. Wrenching since 1967.
bdamico on GF wrote | Quote: | | "When I was your age I'd plan out all sorts of stuff for the future and almost none of them came true. Just wonder if it's worth trying to be a crystal ball. " |
Posted: Sat Mar 17, 2012 1:06 pm Post subject: |
| TheBusDrummer wrote: | | Stuartzickefoose wrote: | | that second pic is causing a vacuum leak, find out where it goes....look EVERYWHERE... |
Do you know what the first thing is? my 75 has one but it was caked with dry oil |
PCV i think...it vents pressure from the crankcase into the intake...a long trip (drive for at least a hour solid) would make most of that moisture go away. its from sitting. that same moisture collects in your muffler too, so driving it will give it a chance to dry out and quit rusting internally.... _________________ MINE - 1978 Westfalia ~ Maisy ~ FI, Hydraulic Valves, Electronic Points, 2.0 (NEED A SET OF HEADS, PM ME IF YOU HAVE A SET)
Posted: Sat Mar 17, 2012 1:07 pm Post subject: |
Thank you both! I found were the tube goes too I think, I'm gonna try to start it in a second _________________ ___________________________________
Cooper
Posted: Sat Mar 17, 2012 1:09 pm Post subject: |
.....waiting expectantly... _________________ MINE - 1978 Westfalia ~ Maisy ~ FI, Hydraulic Valves, Electronic Points, 2.0 (NEED A SET OF HEADS, PM ME IF YOU HAVE A SET)
Posted: Sat Mar 17, 2012 1:24 pm Post subject: |
no cigar....its cranking though which is a good thing, I just bought a new coil, lets see if has something to do with that... _________________ ___________________________________
Cooper
Posted: Sat Mar 17, 2012 1:26 pm Post subject: |
okay, when it doesn't start, spray some gas (or a SMALL amount of started fluid into the intake, and see if it fires....that way we can see if its a fuel issue or a spark issue... if its FI, you may have to do this while cranking to get past the AFM box flap.
then:
test the coil by removing the coil wire and holding it about a 1/8th inch from a ground and looking at the spark as someone cranks, then report to us the color of the spark, if there is one. _________________ MINE - 1978 Westfalia ~ Maisy ~ FI, Hydraulic Valves, Electronic Points, 2.0 (NEED A SET OF HEADS, PM ME IF YOU HAVE A SET)
Posted: Sat Mar 17, 2012 3:27 pm Post subject: |
| Stuartzickefoose wrote: | okay, when it doesn't start, spray some gas (or a SMALL amount of started fluid into the intake, and see if it fires....that way we can see if its a fuel issue or a spark issue... if its FI, you may have to do this while cranking to get past the AFM box flap.
then:
test the coil by removing the coil wire and holding it about a 1/8th inch from a ground and looking at the spark as someone cranks, then report to us the color of the spark, if there is one. |
Its a spark issue... There is no spark at all from the coil. I tried two different coils so I'm not sure what the problem is/ _________________ ___________________________________
Cooper
Posted: Sat Mar 17, 2012 3:29 pm Post subject: |
| TheBusDrummer wrote: | | Stuartzickefoose wrote: | okay, when it doesn't start, spray some gas (or a SMALL amount of started fluid into the intake, and see if it fires....that way we can see if its a fuel issue or a spark issue... if its FI, you may have to do this while cranking to get past the AFM box flap.
then:
Its a spark issue... There is no spark at all from the coil. I tried two different coils so I'm not sure what the problem is/ |
is the coil getting 12 volts? check the 15 side, or the + side of the coil with a volt meter with the key on. _________________ MINE - 1978 Westfalia ~ Maisy ~ FI, Hydraulic Valves, Electronic Points, 2.0 (NEED A SET OF HEADS, PM ME IF YOU HAVE A SET)
Posted: Sat Mar 17, 2012 3:39 pm Post subject: |
| Stuartzickefoose wrote: | | TheBusDrummer wrote: | | Stuartzickefoose wrote: | okay, when it doesn't start, spray some gas (or a SMALL amount of started fluid into the intake, and see if it fires....that way we can see if its a fuel issue or a spark issue... if its FI, you may have to do this while cranking to get past the AFM box flap.
then:
is the coil getting 12 volts? check the 15 side, or the + side of the coil with a volt meter with the key on. |
I don't currently have a voltmeter (I know, I know)... what are the two likely scenarios?
EDIT: Let me clarify that If it did get twelve volts what would I do, and if it isn't what should I do? _________________ ___________________________________
Cooper
SGKent Samba Member
Posted: Sat Mar 17, 2012 4:00 pm Post subject: |
does it die just about the same time you let go of the ignition switch from start to run? _________________ Steve aka Merlin the Wrench
Posted: Sat Mar 17, 2012 4:08 pm Post subject: |
| SGKent wrote: | | does it die just about the same time you let go of the ignition switch from start to run? |
It doesn't even fire now, it just cranks. _________________ ___________________________________
Cooper
