Bus stops running
Goto page 1, 2  Next
TheBusDrummer
TheBusDrummer is offline
PostPosted: Sat Mar 17, 2012 10:27 am    Post subject: Bus stops running Reply with quote
Can somebody help? Bus stops running every time i put in get gear. Engine sometimes shuts down, other time it acts like it's running out of gas. What would cause this? Bus was tunned up before winter (plugs, cap, wires, rotors, points, oil etc...)
___________________________________
Cooper
1975 Automatic Transporter
1977 Automatic Westy
Daisy71Kombi
Daisy71Kombi is offline
PostPosted: Sat Mar 17, 2012 10:35 am    Post subject: Reply with quote
Had the same thing and the VW shop replaced the carburetor ($80 w/ labor) and adjusted the timing. Said it was from sitting so long and it fixed my problem. I was also told not to the let the bus set and once you fire it up to drive and not wait for it to warm up. I usually have problems after it sits for weeks for the first few minutes and then it goes away.
Her name is Daisy. 1971 Kombi camper. Pop up tent. 77K miles. Engine rebuilt recently. Just completed brakes with all new parts!
1975 Kombi
1975 Kombi is offline
PostPosted: Sat Mar 17, 2012 11:07 am    Post subject: Re: Bus stops running Reply with quote
FI or carbs.
Brett
"I do not see things as black and white, but everything as very colourful!"
'75 Kombi/Westy (2.0L CV, H-Lifters, '75-'79FI mix, XR700, 003 Auto) project.
03 Jetta TDI, 04 Honda civic, 71 super beetle
Licensed pilot (single engine land VFR)
Rust In Peace: 72 Bug, 73 Bug, 81 Rabbit LS D 2D, 83 Rabbit D 2D, 84 Jetta TD GL, 85 Jetta D, 68 Z28 RS 302, 91 Passat 16v
whenhoboesfly
whenhoboesfly is offline
PostPosted: Sat Mar 17, 2012 11:24 am    Post subject: Reply with quote
Why would you not let your oil pressure/temperature build up?
'77 Transporter 2L FI
TheBusDrummer
PostPosted: Sat Mar 17, 2012 12:06 pm    Post subject: Re: Bus stops running Reply with quote
FI or carbs.
FI... If I actually get it going and then come to a rest it completly shuts off.
Cooper
Stuartzickefoose
Samba Post Whore
Stuartzickefoose is offline
PostPosted: Sat Mar 17, 2012 12:22 pm    Post subject: Re: Bus stops running Reply with quote
FI or carbs.
lets get specific here....which bus, what motor, and a little more history?
MINE - 1978 Westfalia ~ Maisy ~ FI, Hydraulic Valves, Electronic Points, 2.0 (NEED A SET OF HEADS, PM ME IF YOU HAVE A SET)
DAD's - 1972 Westfalia ~ Sticky ~ 1.7(?) 914 motor, allison electronic ignition, electric fuel pump, dual webers w/o choke.
“Don't cry because it's over, smile because it happened.”
“Those who mind don't matter, and those who matter don't mind.”
TheBusDrummer
PostPosted: Sat Mar 17, 2012 12:51 pm    Post subject: Re: Bus stops running Reply with quote
Sorry about that, I'm starting to get slightly aggravated at this thing and I'm not thinking straight , Its my 77' westy.. 2000cc.. Automatic, It normally takes a while to get it started and now its just pfft dead, and won't start at all. I found this full of yellow gunk, which I asume is from condensation mixing with oil but why???
I also found this unconnected and just laying in the engine compartment
Cooper
Stuartzickefoose
Samba Post Whore
PostPosted: Sat Mar 17, 2012 12:52 pm    Post subject: Reply with quote
that second pic is causing a vacuum leak, find out where it goes....look EVERYWHERE...
TheBusDrummer
PostPosted: Sat Mar 17, 2012 12:58 pm    Post subject: Reply with quote
Do you know what the first thing is? my 75 has one but it was caked with dry oil
Cooper
SGKent
SGKent is offline
PostPosted: Sat Mar 17, 2012 12:59 pm    Post subject: Reply with quote
the PCV goes on the top of the breather tower on the case and a hose goes to the S-Boot. The plastic piece with the hose probably goes from the S-Boot to one of several places. Look at the decel valve first.
Stuartzickefoose
Samba Post Whore
PostPosted: Sat Mar 17, 2012 1:06 pm    Post subject: Reply with quote
PCV i think...it vents pressure from the crankcase into the intake...a long trip (drive for at least a hour solid) would make most of that moisture go away. its from sitting. that same moisture collects in your muffler too, so driving it will give it a chance to dry out and quit rusting internally....Wink
TheBusDrummer
PostPosted: Sat Mar 17, 2012 1:07 pm    Post subject: Reply with quote
Thank you both! I found were the tube goes too I think, I'm gonna try to start it in a second
Cooper
Stuartzickefoose
Samba Post Whore
PostPosted: Sat Mar 17, 2012 1:09 pm    Post subject: Reply with quote
.....waiting expectantly...
TheBusDrummer
PostPosted: Sat Mar 17, 2012 1:24 pm    Post subject: Reply with quote
Crying or Very sad no cigar....its cranking though which is a good thing, I just bought a new coil, lets see if has something to do with that...
Cooper
Stuartzickefoose
Samba Post Whore
PostPosted: Sat Mar 17, 2012 1:26 pm    Post subject: Reply with quote
okay, when it doesn't start, spray some gas (or a SMALL amount of started fluid into the intake, and see if it fires....that way we can see if its a fuel issue or a spark issue... if its FI, you may have to do this while cranking to get past the AFM box flap.
then:
test the coil by removing the coil wire and holding it about a 1/8th inch from a ground and looking at the spark as someone cranks, then report to us the color of the spark, if there is one.
TheBusDrummer
PostPosted: Sat Mar 17, 2012 3:27 pm    Post subject: Reply with quote
then:
Its a spark issue... There is no spark at all from the coil. I tried two different coils so I'm not sure what the problem is/
Cooper
Stuartzickefoose
Samba Post Whore
PostPosted: Sat Mar 17, 2012 3:29 pm    Post subject: Reply with quote
then:
is the coil getting 12 volts? check the 15 side, or the + side of the coil with a volt meter with the key on.
TheBusDrummer
PostPosted: Sat Mar 17, 2012 3:39 pm    Post subject: Reply with quote
then:
I don't currently have a voltmeter (I know, I know)... what are the two likely scenarios?
EDIT: Let me clarify that Laughing If it did get twelve volts what would I do, and if it isn't what should I do?
Cooper
SGKent
SGKent is offline
PostPosted: Sat Mar 17, 2012 4:00 pm    Post subject: Reply with quote
does it die just about the same time you let go of the ignition switch from start to run?
TheBusDrummer
PostPosted: Sat Mar 17, 2012 4:08 pm    Post subject: Reply with quote
It doesn't even fire now, it just cranks.
Cooper
Goto page 1, 2  Next
