Help Identify this Engine
Nepenthe88
Nepenthe88 is offline
PostPosted: Sat Mar 17, 2012 7:22 pm    Post subject: Help Identify this Engine Reply with quote
I'm not sure i'm in the right spot, but I figure this should be an easy set of questions for someone here. Anyway... a buddy of mine has an old rail with an old engine in it. I looked up "engine codes" but nothing I found started with E like this block has. If you could help me solve this mystery, I'd be appreciative!
engine code E 19749
old cast distributor
strange looking tin where the heat exchangers are normally?
and finally a pic of the engine as a whole. It has a 28 pict1 on it, which I assume doesn't match....
Final answer? Is it anything interesting / desirable?
The 57 Barnfind Ghia
Red w/Stripes, a '74Super
Subaru EJ22 in the Flatback Bug
All about FOAM in fatchicks
leeezard7
leeezard7 is offline
PostPosted: Sat Mar 17, 2012 8:03 pm    Post subject: Reply with quote
maybe someone with more knowledge than i on the subject will chime in... but it appears by the engine number its possibly a industrial 36hp from june or july of 1956. the carb and 12v alt are wrong tho.
earthquake
earthquake is offline
PostPosted: Sat Mar 17, 2012 9:06 pm    Post subject: Reply with quote
How tight is the fit between the alternator and the generator stand, I did not think you could put a alternator on a 36hp.
Casey
74 CLASS 11 LOOK-A-LIKE
65 pan [I haven't decided what to do with it]
69 DUNE BUGGY
79 INTERNATIONAL SCOUT II
05 SCION XB SERIES RELEASE 2[#437]
Some where in Kenya, A village is missing its Idiot!
"If you put the federal government in charge of the Sahara Desert, there would be a shortage of sand in 5 years"
PostPosted: Sat Mar 17, 2012 10:01 pm    Post subject: Reply with quote
The engine stamping area has clearly been ground down and restamped.
Probably just a random number some engine rebuilder used in the past.
The distributor and heater pieces are standard Beetle 36hp.
The 28 PICT is technically from a later engine but works fine on a 36hp.
How to: Post Photos | Search
Everett Barnes - [email protected] | My VWs | My wanted ads
