az66ghia Samba Member
Posted: Sat Nov 05, 2005 4:19 pm Post subject: Speedometers making noise |
| ill be driving and all of a sudden the speedometer starts making this loud screetching noise and it will continue till the car slows to almost a stop. does anyone know of what is happening or how to fix it. thanks. |
Bart Dunn Samba Consiglieri
Joined: May 09, 2004 Posts: 2457 Location: Sea level (Mid Pacific)
Posted: Sat Nov 05, 2005 4:35 pm Post subject: |
New speedometer? BFY, Wolfsburg West, etc. sell rebuilt ones. There's magnets or bearings in there that go bad. Happened to me once in my Beetle. Other than that, maybe dump a quart of Prestone antifreeze in there, no, make that Quaker State. _________________ Not enough car seats fit into my:
'58 Beetle convertible
'58 Beetle sedan |
JeffL Samba Member
Posted: Sat Nov 05, 2005 6:11 pm Post subject: |
I picked up a NOS trip speedo for a 63 Beetle. After about 1,000 miles it started to make the same noise.
I took the speedo apart (not easy but take your time) and lubricated the bushing where the cable comes into the speedo. It was fine after that. Send it out to get it reconditioned. |
Doc's70KG Samba Member
Posted: Sat Nov 05, 2005 6:43 pm Post subject: |
| I had a similar problem a couple of months ago. The speedo would occasionally freak out (needle jumping all over the place, rattle/screeching noise). It was intermittent, and I tried shooting some lock lubricant stuff into the cable housing on the theory that the speedo cable was binding up somewhere, but to no avail. In the end, the problem just went away of its own accord, so I'm guessing whatever was binding up worked itself free on its own. Not sure if this helps or not, but you may want to take a wait-and-see approach for a while and maybe save some $$$ on a rebuilt speedo. |
BirdLives Samba Member
Joined: August 20, 2005 Posts: 329 Location: NorCal East Bay
Posted: Sun Nov 06, 2005 2:58 am Post subject: |
I had that problem, just tightened the cable were it attaches to the back of the speedo, fixed it for me.
I remember someone suggesting on another thread to disconnect the cable there and grease it. |
jh72i Samba Member
Posted: Sun Nov 06, 2005 3:46 am Post subject: |
I had the same problem. Got a new (well, old) speedo and it did the same thing. Of course, tried the cable first and it seemed to be fine. What worked for me (so far) was some plumbers tape (don't know what its called but its very very thin white tape that they use to ensure a leak free connection in thread) when the cable connects into the back of the speedo. Just seemed to tighten the connection enough to stop the noise.
Now, this is not a solution and could even be doing more damage in the long run I really don't know. But its worth a try before considering buying a new speedo.
Good luck. |
Rusted Rockers Samba Member
Joined: August 04, 2004 Posts: 903 Location: tennessee
Posted: Sun Nov 06, 2005 7:09 pm Post subject: |
| lube works for me....check also the cable could be dry too.... |
Posted: Tue Nov 15, 2005 8:37 pm Post subject: |
| well i just tightened the speedo cable and all was fine thanks for all your help. |
Buggeroff Argumentative Bastard
Joined: October 16, 2004 Posts: 1163 Location: Lake of the Ozarks, Missouri
Posted: Wed Nov 16, 2005 11:39 am Post subject: |
| jh72i wrote: |
Good luck. |
PTFE tape. PolyTetraFluroEthylene.
Shouldn't do any harm, it is used to create a water tight seal on plumbing joints.
Chris. _________________ "Chris of the Ozarks"
Headlinerless 57 Ghia
Thread deleter extrordinaire. |
v8swap Samba Member
Posted: Tue Mar 13, 2012 4:00 pm Post subject: |
I Also had this problem. spedo was squealing and the needle jumping around. I disconected the cable from the back of the spedo and gave it a blast of graphite powder (in the spedo and the cable). Worked for me. I don't know if one should do this if it's been lubed previously with WD40 or similar you might have a caked up mess.  |
v8swap Samba Member
Posted: Sun Mar 25, 2012 2:01 pm Post subject: Speedo noise |
Just a up date on my previous post on useing graphite powder. Worked great for a few days.....now my speedo died.  |
