enjoyther1de Samba Member
Joined: December 19, 2010 Posts: 268 Location: chino,ca
Posted: Tue Mar 13, 2012 7:47 pm Post subject: |
Thanks sal. I'm thinking about leaving the og/earl schieb/ patina paint on the body? I'm sure that the car is not even 40% done/where i want it. But it is an obsession! I am thinking about buying stock in moore parts.. I really like the fit and finish of the tweed spindles, went on very nice! I am going to take the tie rods with me to work and stuff the sway bar into them. I was thinking just drill holes in the tie rods and plug weld? I have not searched yet, any body done this? If you have, how's it done? _________________ http://www.grassvalleyrec.com/HBB2/Brad_0001.wmv
A government that is big enough to give you everything you want is also strong enough to take everything you have. - Thomas Jefferson |
dcamomanx Samba Member
Posted: Wed Mar 14, 2012 5:50 am Post subject: |
The stock swaybar fits snugly into the inside if the tie rod. I did not weld them in. Just remember to cut them short enough so that there is still enough room for the tie rod ends to be threaded in all the way. The other thing I ended up doing was placing a 1inch pipe over the outside of the tie rod. This one I did weld to the tie rod. That way you reinforce the tie rods from both the inside and out.
I hope that helps
You project is coming along great
Doran |
dirtkeeper Samba Member
Joined: February 19, 2008 Posts: 1888 Location: Left of everywhere
Posted: Wed Mar 14, 2012 7:18 am Post subject: |
| dcamomanx wrote: | The stock swaybar fits snugly into the inside if the tie rod. I did not weld them in. Just remember to cut them short enough so that there is still enough room for the tie rod ends to be threaded in all the way. The other thing I ended up doing was placing a 1inch pipe over the outside of the tie rod. This one I did weld to the tie rod. That way you reinforce the tie rods from both the inside and out.
I hope that helps
Doran |
I did the sway bar trick in my tie rods and the first time around i made the inner bar about 2" short and it bent right there. Next time i did it after setting the alignment and left less than 1/2" and havent had a problem since. i no outer pipe on mine |
Posted: Wed Mar 14, 2012 6:52 pm Post subject: |
Would it hurt anything if i did drill a few holes and plug welded? _________________ http://www.grassvalleyrec.com/HBB2/Brad_0001.wmv
Posted: Sun Mar 18, 2012 1:56 pm Post subject: |
Slipped the sway bars into the tie rods today.. Easy and cheap insurance.. _________________ http://www.grassvalleyrec.com/HBB2/Brad_0001.wmv
Posted: Sun Mar 25, 2012 6:40 pm Post subject: |
Got the pan repaired, and put the body back on. While i had the body off i made some retainers to keep the pivot bolt in place. Stole the design from HBB's baja.
Posted: Mon Apr 16, 2012 10:54 pm Post subject: |
seats.. _________________ http://www.grassvalleyrec.com/HBB2/Brad_0001.wmv
Posted: Thu Apr 26, 2012 9:12 pm Post subject: |
Finaallyy took the car out to barstow for a little shakedown.. What better way to see whats what than cruisin through the rocky trails of barstow..
Got a flat tire, already had cracks in the sidewalls soo... All in all not too shabby! Gotta notch the spring plates too, The sound gets a little annoying! _________________ http://www.grassvalleyrec.com/HBB2/Brad_0001.wmv
auslander Samba Member
Joined: January 07, 2003 Posts: 1746 Location: Heart Of Dixie
Posted: Fri Apr 27, 2012 5:19 am Post subject: |
Awesome, glad to see it finally hitting the trails. At least you didnt run over a railroad spike  _________________ Wandering
66 POS Bus
69 Class 11 Beetle
!!! F**k Cancer !!!
Time's Tide will Smother You
"You can't throw a rock in Long Beach without hitting a tweaker" Steve Tucci |
