andrewtheplumber Samba Member
Joined: March 10, 2008 Posts: 157 Location: Goodlettsville, TN
Posted: Tue Mar 27, 2012 11:53 pm Post subject: Installing Camper on Transporter |
I did a search and did not see this answered although it I am sure been addressed. I have a great 78 Transporter, thinking about a tin top camper conversion but if I run across a camper top, is that a doable conversion? Thank you. _________________ Andy
Goodlettsville, TN
78 Transporter (Fred the Bus)
70 Karmann Ghia
81 Scirocco
85 Wolfsburg Cabriolet |
Collie Samba Member
Joined: April 03, 2006 Posts: 1100 Location: Virginia
Posted: Wed Mar 28, 2012 6:28 am Post subject: |
To do it properly, you will need the roof (not just the fibreglass part) off a late model donor to be welded on. Are you up to that?
Its been done, its here somewhere for sure, keep searching...  _________________ Collie
Bay Window Sunroof Tech Article
Champagne Edition Photo Gallery |
grandpa pete Samba Member
Joined: July 06, 2008 Posts: 1320 Location: St. Petersburg, FL
Posted: Wed Mar 28, 2012 9:38 am Post subject: |
Icut the top off a tintop and dropped it over a westie "hole"....you will need to get the entire "hole " and supports...doable but not for the "faint of heart" _________________ 69 tintop camper 1600 DP |
airkooledchris Samba Member
Joined: January 25, 2005 Posts: 1703 Location: Eureka, CA
Posted: Wed Mar 28, 2012 10:33 am Post subject: |
If you currently have a regular passenger bus and want to put a pop top on it, you can do it but don't go with a Westfalia top. The Westy top was built to fit on a bus that came from the factory with certain brackets/braces/etc to support it already in place. Swapping over a whole roof just for that isn't something most would even think about.
Try instead to get a top from a Riviera that would otherwise be scrapped. Those were imported to the US with the regular passenger roof, so swapping those over are a much easier (in comparison to the Westy top) conversion to make. _________________ Join the IAC Facebook group here! |
Manfreds78bay Samba Member
Joined: February 27, 2009 Posts: 330 Location: Chicago
Posted: Wed Mar 28, 2012 1:46 pm Post subject: |
Don't do it. Just put the camper stuff in. Tin top campers are cool...hacked up busses are not.
Plenty of pop-top campers to be hand...go buy one and save yourself from the project that ate your bank account. |
Kirk  Samba Member
Joined: December 05, 2003 Posts: 4764 Location: North Texas
Posted: Wed Mar 28, 2012 5:18 pm Post subject: |
| Manfreds78bay wrote: | Don't do it. Just put the camper stuff in. Tin top campers are cool...hacked up busses are not.
Ditto that. Or sell the transporter and buy a pop top. _________________ Oppenhiem
Bear |
pb24ss Samba Member
Joined: June 30, 2005 Posts: 1562 Location: sitting around the fire with the bluegrass band - colorado
Posted: Wed Mar 28, 2012 5:21 pm Post subject: |
search the interwebs for greg potts westfakia. he's got an excellent write up on how he did this swap. _________________ 78 P22 Westy |
GeorgeO. Samba Member
Joined: October 08, 2010 Posts: 526 Location: Menifee, CA
Posted: Wed Mar 28, 2012 5:36 pm Post subject: Re: Installing Camper on Transporter |
| andrewtheplumber wrote: | | I did a search and did not see this answered although it I am sure been addressed. I have a great 78 Transporter, thinking about a tin top camper conversion but if I run across a camper top, is that a doable conversion? Thank you. |
I bought my camper for 700 bucks on Craigslist. There are plenty of Westfalia's out there that you can have a fresh start with and it will come out cheaper than pulling off the tin top in place of a pop top.
csclassics Samba Member
Joined: August 17, 2006 Posts: 261 Location: North Wales, PA
Posted: Thu Mar 29, 2012 7:25 pm Post subject: |
| 700 bucks!!!! WOW!!! good deal! |
Posted: Thu Mar 29, 2012 8:52 pm Post subject: 700 bucks WOW! |
| csclassics wrote: | | 700 bucks!!!! WOW!!! good deal! |
When I first came up to it, the PO used it for storage and I did not know the internal condition was like. Well it was missing the two front seats, a thief broke into the gas lock and took all the gas and left the lock inside the tank. Another thief took the motor and cut part of the harness. But other than that the body is straight some surface rust on underside and on the rear windows, nothing I can't take care of. I put an upright in it but the mechanic did such a lousy job on it, I pulled the motor and replaced the original tin on the motor to make sure I don't over heat. I replaced the canvas, front seats and I will upholsterer Z-Bed and rear mattress with new foam and covers.
This is my canvas tool.
Posted: Fri Mar 30, 2012 7:29 am Post subject: |
| alot of work, but it looks real nice! I haven't had a bus in about ten years and am looking to buy another one. I'm amazed and how the prices of bay window campers have gone up. thought about buying a bus and doing a top conversion, but I'm finishing up welding a 56 ragtop clip into my 66 Beetle and don't think I really want to tackle another big project like that yet. Sooooo to get back to the question.... YES it can be done, but its ALOT OF WORK and pricey too. |
Posted: Sat Mar 31, 2012 10:22 am Post subject: Baywindow Buses |
| You can still find them out there but the problem is getting worse with the economy. People are snatching up these buses up and parting them out. Perfectly good buses chopped up for rust buckets and as soon as that supply runs dry, you will see Bays, especially 68-71 command a higher price. The thing is to snatch up a couple of these buses and put them in storage if you have the resources. They will command a good price when the supply runs out. |
Posted: Mon Apr 16, 2012 9:39 pm Post subject: |
I think a tin top will do, thanks everyone. Also I can keep a kayak rack up there. _________________ Andy
Goodlettsville, TN
70 Karmann Ghia
81 Scirocco
stuco Samba Member
Posted: Mon Apr 16, 2012 11:27 pm Post subject: |
| Yeah, you are probably better off just making it a tin top camper in this case. They have their advantages too. |
RatCamper Samba Member
Joined: November 13, 2008 Posts: 3307 Location: Australia
Posted: Tue Apr 17, 2012 4:20 am Post subject: |
Keep it a tin top. If you are determined remember Camper =/= Westfalia. Lots of options. _________________ Vehicle: 1975 Special order delivery walkthrough panel based pop-top camper (LCA / Sunliner). Motor: Nippon 1.8L Single port Wasserboxer, Transmission: 3 rib 002. |
