58-60 "Early Big Window" Convertible Registry
Goto page Previous  1, 2, 3 ... 31, 32, 33 ... 41, 42, 43  Next
Stanw3
Stanw3 is offline
PostPosted: Mon Mar 26, 2012 6:11 am    Post subject: Reply with quote
I have a guy looking for me - should hear something by tomorrow. Fingers crossed!
Sanborn7
www.facebook.com/Sanborn7
View user's profile Send private message Send e-mail MSN Messenger Facebook Gallery Classifieds Feedback
bugmandave
bugmandave is offline
PostPosted: Tue Mar 27, 2012 2:27 pm    Post subject: Reply with quote
Stanw3 wrote:
I'm looking at my new window scrapers I got from Chuck and I'm wondering if there are some words of experience/wisdom out there before I go poking holes in them. Smile
Also, I can not find any good pics or info on the window wedges. I'll post a couple of pics here about the quarter window wedges and and hopefully it will help someone else down the line with these.
At the rear wedge, does the hold down flap (under trim) go to the outside of the car or the inside? What does the screw look like that is used to mount it?
On the front wedge: Same question about the flap - which side?
How much and where do you trim the scraper?
Again, what do the screws look like that secure it to the pillar?
On the trunk seal: Am I supposed to just leave a gap at the top corners? I don't see any good way to make this area work???
Thanks for the help!!
there are supposed to be gaskets under the aluminum plates at the top of the quarter also. hood seal on the earlier cars didn't have any gaskets at the corners but you can service install them by drilling the holes for the nipples. there is a pattern in the Bently manual. your second picture is correct, the other door wedge is not. the extended piece goes on the inside so the outside scraper is a continuous piece all the way. the screws are tiny phillips head chrome screws with trim washers. about the size of the screws that hold the top window seals on.
Stanw3
Stanw3 is offline
PostPosted: Tue Mar 27, 2012 6:54 pm    Post subject: Reply with quote
Thanks for the reply Dave!
Sanborn7
Stanw3
Stanw3 is offline
PostPosted: Thu Mar 29, 2012 12:17 pm    Post subject: Reply with quote
Am I supposed to have split the harness here? Thanks!
Sanborn7
bugmandave
PostPosted: Thu Mar 29, 2012 4:43 pm    Post subject: Reply with quote
If that's for the dome light it should come out of that smaller hole by the big harness grommet with a smaller grommet
Braukuche Premium Member
Braukuche is offline
PostPosted: Thu Mar 29, 2012 6:42 pm    Post subject: Reply with quote
Window winding mechanisms, were they painted or just bare metalk as well as the metal bits that make up the sliding stuff on the glass?
Go Reds! Smash state!
My retirement plan:
1958 PG/SG Standard
1959 SO-23 Westfalia
1960 crusty double cab
1960 convertible bug
1962 So-22 Mosaic Westfalia
1963 356 B coupe runner
1963 356 B coupe in pieces
1965 standard sunroof bus
1967 912
lovethatconvertible Premium Member
lovethatconvertible is offline
PostPosted: Thu Mar 29, 2012 8:20 pm    Post subject: Reply with quote
Bare Metal
386kustoms
386kustoms is offline
PostPosted: Sat Mar 31, 2012 5:10 am    Post subject: Reply with quote
man i love how clean these cars are coming out, i cant wait till mine looks like that
PostPosted: Sat Mar 31, 2012 8:49 pm    Post subject: Reply with quote
Let's talk quarter window problems.
I have my window in. When rolled up, it sits dead center. As I roll it down, it begins to slant inward toward the inner side of the channel. It then begins to bind. I must force it down and it sort of clunks and then continues down. As it does to, it begins to recenter itself.
I thought it was the channel, but the frame is not binding in the channel, in fact, it seems the roller (the round piece of the regulator that fits into the channel on the window frame) binds up. I have tried loosening the two bolts and adjusting the mounting bracket for the window frame but to no avail. Any ideas??
My retirement plan:
1958 PG/SG Standard
1967 912
Stanw3
Stanw3 is offline
PostPosted: Sun Apr 01, 2012 5:15 am    Post subject: Reply with quote
are you sure the channel for the roller doesn't have a kink in it? Sounds like that might be bent from the action????
Sanborn7
PostPosted: Sun Apr 01, 2012 6:49 am    Post subject: Reply with quote
I did take a wrench to it and twisted a little here and there and that seemed to help, so maybe you are on to something. I kept thinking it must be the guide channel that was causing the window to twist like that, but it must be the channel for the roller.
My retirement plan:
1958 PG/SG Standard
1967 912
Stanw3
Stanw3 is offline
PostPosted: Sun Apr 01, 2012 7:59 am    Post subject: Reply with quote
I'd take it back out and get the channel on a bench where you could get a good look at it.
Sanborn7
PostPosted: Sun Apr 01, 2012 11:37 am    Post subject: Reply with quote
I did and what a mess.
The channel that holds the window was catching on the top right hub of the regulator and was slowly getting peeled back and distorting the channel for the roller. I had to remove the regulator, take the window apart inside of the body and then extract the whole mess is pieces like a tooth extraction gone bad. I then had to spend a good hour straightening the mess out, reinstall and adjust so the window is as far away from the regulator as possible. Just a typical day in VW restoration land: two steps forward, one step back...
My retirement plan:
1958 PG/SG Standard
1967 912
Stanw3
Stanw3 is offline
PostPosted: Tue Apr 03, 2012 3:38 pm    Post subject: Reply with quote
Front door wedge - do I have this laid out correctly??
EDIT:: I have the wrong side door seal installed in these photos. Embarassed
The Bentley photo isn't much help.
Sanborn7
jays58s
jays58s is offline
PostPosted: Fri Apr 06, 2012 6:34 pm    Post subject: Reply with quote
58' vert just showed up today... I've never owned a vert, 1st time for everything right? It's fairly straight but needs work.
Responsibility is a heavy responsibility.
PostPosted: Fri Apr 06, 2012 7:03 pm    Post subject: Reply with quote
Awesome, Post some more pic's when you get into it. What's the status on the parts that are missing in the pictures?
jays58s
jays58s is offline
PostPosted: Fri Apr 06, 2012 7:05 pm    Post subject: Reply with quote
Most of it seems to be there but I don't have the energy to go through it right now. lol (a bit hungover still) Laughing I'll post some pics though tomorrow after I go through it.
PostPosted: Fri Apr 06, 2012 7:15 pm    Post subject: Reply with quote
A Bloody Mary will put you back on top of your game Very Happy Post some pic's of the spare tire area, trunk and inside when you get back on it. we love Pictures.
jays58s
jays58s is offline
PostPosted: Fri Apr 06, 2012 7:29 pm    Post subject: Reply with quote
For sure! I'm kinda bummed that they started painting it some funky olive color so I'm going to have to dig a little to find the original color on it. The tank must have been replaced too cause it's black, or someone painted it.
PostPosted: Mon Apr 09, 2012 9:51 am    Post subject: Reply with quote
I am trying to finish up my top installation today and have a question. Chuck is not open on Monday so I can't pester him.
I have my top pretty much tacked up. The only problem is the sides. The sides in teh rear atachto the outer facings, got that on. There is a bead that runs down the facing then terminates toward the rear. There is then the beading that you use to cover the screws attaching the rear bow to the body. What is the juncture of those two beads supposed to look like? I have the chrome strip that covers the seam between the bead and the top on the rear bow, does that cover the junction of the two beads? Also, I am having a heck of a time getting the material to pull low enough in that area to get the two beads to even connect. Any tips there? Picture would be nice if anyone has one handy.
My retirement plan:
1958 PG/SG Standard
1967 912
Page 32 of 43
