Rustoleum almond? Steering column
Goto page 1, 2  Next
johnny chingas
johnny chingas is offline
PostPosted: Fri Mar 30, 2012 7:39 pm    Post subject: Rustoleum almond? Steering column Reply with quote
I was going to ask in the paint and body section but I thought I might get a faster response here! I picked up a can of Rustoleum almond since I have read about how close the color match is with ivory. My ? Is do I primer my (bare metal) steering column with a white Rustoleum primer because they have a grey and some other colors too, and do I give it a light sand after primer before I spray the almond? Thanks fellas
stale air Premium Member
stale air is offline
PostPosted: Fri Mar 30, 2012 8:15 pm    Post subject: Reply with quote
I used almond on all my interior parts also. I did primer everything beforehand, and a light sand with a scotchbrite for me depended on how nice I was able to lay the primer down. Another tip is if you have some issues laying down the color wet sand between the coats. The new tips on the cans are actually have a pretty nice spray pattern to them.
and Brittsan Motors Fresno plate frames
Wanted: Original VW Accessory front hood script
1958 L245 Type 113
1961 L87 Type 117
Soul Built Premium Member
Pimpin' Aint Easy
Soul Built is offline
PostPosted: Fri Mar 30, 2012 8:34 pm    Post subject: Reply with quote
Consider using the Almond Colored Appliance Epoxy Bomb Can. I found it to be more durable than conventional spray paint.
It is priced about the same and can be found at Holmes Depot or Lowes.
RareAir
RareAir is offline
PostPosted: Sat Mar 31, 2012 8:02 am    Post subject: Reply with quote
If it's bare metal, you'll want to apply first. Primer color isn't important, but the Almond will have better coverage over a White primer when compared to a darker colored primers such as Black.
1947 Type 11a
1954 Type 117
1956 Type 151
1966 Type 151
1966 Type 251
Sent from my iPhone 9S
johnny chingas
PostPosted: Sat Mar 31, 2012 8:24 am    Post subject: Reply with quote
Thanks guys
valentinesr
valentinesr is offline
PostPosted: Sat Mar 31, 2012 12:29 pm    Post subject: Reply with quote
Does anyone have pictures??? Johnny.. Post some pics up of your finished product and what you chose.. Por Favor.. Thanks brotha..
Valentine, Ray J Sr.
Montclair, California
thebucket wrote:
I gave my oval a nasty look. Money hungry bitch....
(Delilah) http://www.thesamba.com/vw/forum/viewtopic.php?t=319235
1954 Parts Book (CD PDF) PM TO INQUIRE
PostPosted: Sat Mar 31, 2012 3:27 pm    Post subject: Reply with quote
Here is a pic of my interior. I not only used the almond on my column, shifter, turn signal housing, E-brake handle, etc, but I used it to repaint my Petri horn ring as well. The horn ring I just painted and put on about a month ago, the other stuff I painted about 10 years ago.
1958 L245 Type 113
1961 L87 Type 117
Pimpin' Aint Easy
PostPosted: Sat Mar 31, 2012 3:39 pm    Post subject: Reply with quote
I know it only shows a sliver but my wheel, column, bracket, and turn signal were all done with the epoxy
valentinesr
PostPosted: Sat Mar 31, 2012 9:24 pm    Post subject: Reply with quote
Hey Soul_VW.. How does your wheel hold up?? How long did you let it try before re-install? Is that expoxy pretty durable on wear and tear of the wheel?? Im leaning towards that stuff pretty good right now.. Looks good brotha..
Pimpin' Aint Easy
PostPosted: Sun Apr 01, 2012 6:56 am    Post subject: Reply with quote
OOHRAH Devil Dog....
My Steering Wheel has held up really well. I would say that for best results, make sure you prep well. The epoxy takes longer to dry but it is very strong.
valentinesr
PostPosted: Sun Apr 01, 2012 7:55 am    Post subject: Reply with quote
Im SOLD!! I've prepared my wheel pretty good, and am going to go ahead and buy the expoxy almond when I get home.. I'll defenitely be posting up the finished product.. Should look nice with my NOS Batwing Horn Button.. Hahaha.. Thanks again SoulVW for that input.. Appreciate the support as well.. Thanks brotha
Schwing
Schwing is offline
PostPosted: Sun Apr 01, 2012 8:07 am    Post subject: Reply with quote
I used Almond on my horn button, column, turn signal assembly, grab handle, ebrake, shifter, seat frames, and behind the hubcaps on my wheels. It matched my unrestored steering wheel pretty good and I don't have to have a heart attack if someone scratches/dings it up, just re-do it.
My '57 build:
http://www.thesamba.com/vw/forum/viewtopic.php?t=388895
Schwing
Schwing is offline
PostPosted: Sun Apr 01, 2012 9:00 am    Post subject: Reply with quote
Forgot to mention, I used white primer just like RareAir pointed out.
My '57 build:
belairman
belairman is offline
PostPosted: Sun Apr 01, 2012 10:25 am    Post subject: Reply with quote
The appliance almond epoxy in a can is good,especially if you don't have access to spray equipment to spray a more durable urethane. Use a good quality white primer for good results. Ray. if you need your steering wheel painted, let me know.
Ruben
valentinesr
PostPosted: Sun Apr 01, 2012 10:40 am    Post subject: Reply with quote
Ruben
I need my steering wheel painted.. I was researching a urethane.. but its like a "Mystical Creature" in California.. but this stuff looks good to go.. Whatcha got in mind brotha..
johnny chingas
PostPosted: Sun Apr 01, 2012 11:11 am    Post subject: Reply with quote
Ruben
Is the appliance almond also made by rustoleum? Did You spray your steering wheel with the appliance can? I'm also doing my steering wheel.
belairman
PostPosted: Sun Apr 01, 2012 12:43 pm    Post subject: Reply with quote
I used to work for a company that did steering wheel restoration. I now do that on my own. I do all my wheels in urethanes shot out of a spray gun. I have used the appliance epoxy spray paint for small parts but never have done a steering wheel with it. I have had good success with the paint, as it is more durable than the regular krylon or rustoleum paints.
PostPosted: Sun Apr 01, 2012 2:25 pm    Post subject: Reply with quote
I thought I would just throw out there, that I didnt paint my wheel. Koch restored it for me, and he is actually the one who turned me on to the Krylon Almond. He said it was the best match for the color he uses on his wheels. I have to agree, its a dead match. Cool
1958 L245 Type 113
1961 L87 Type 117
lzamora
lzamora is offline
PostPosted: Wed Apr 04, 2012 8:25 pm    Post subject: Reply with quote
Do you have to use some type of clear over the epoxy almond??
1956 Oval Window Rag
1953 Zwitter Rag
Pimpin' Aint Easy
PostPosted: Wed Apr 04, 2012 9:26 pm    Post subject: Reply with quote
I didnt clear coat mine
Goto page 1, 2  Next
