thummmper Samba Member
Joined: November 25, 2009 Posts: 1801 Location: carlsbad, calif.
Posted: Tue Jan 31, 2012 8:16 pm Post subject: |
someone actually put a 255 hp 3.5 v6 in a bug
no ac or power steering- guess not-- wait-- it has 2/40 air conditioning
 _________________ todd
www.losthorizons.com
89 tintop [below]
90 suby tintop
driving a smooth mid engined vanagon again
prisonplanet.com uname thummmper
pw rockefellersucks--watch movies + reports
start with 'strategic relocation'
Posted: Sat Feb 11, 2012 7:13 pm Post subject: |
dave in utah builds these
pretty cool _________________ todd
89 tintop [below]
90 suby tintop
start with 'strategic relocation' |
Posted: Thu Feb 23, 2012 12:04 pm Post subject: |
after all the drama of emergencies and distractions, I finally got back to the right rear trail arm-- seems it needs it's own hub position tool because the vw hubs are slightly canted towards the ground to offset the load modulus of the arm.
re-establishing the right hub position from scratch
and the hovering 735i hub
I stole another brake drum lug face for this one and filed the holes to fit the beamer after I welded the bridge [locating the vw position.]
then it was sparky time
- I got lazy after realizing I lost my 3 special filler pieces, so I bleachered 1/4" key stock in there for the fill welds. it shaped easyand welded just as nicely
89 tintop [below]
90 suby tintop
Posted: Sun Feb 26, 2012 8:04 pm Post subject: |
89 tintop [below]
90 suby tintop
shadetreetim Samba Member
Joined: January 10, 2011 Posts: 947 Location: Riverside, California
Posted: Sun Feb 26, 2012 8:06 pm Post subject: |
Sweet. Next time I'm down there I'd love to check it out in person. _________________ TP
57 GMC 350/350TH
89 Vanagon Wolfsburg 2.1 4SP
12 Tiguan 2.0T 6SP Tiptronic
Don't get bored easily? Check out my build thread. http://www.thesamba.com/vw/forum/viewtopic.php?t=4...;start=120 |
tristessa Samba Member
Joined: April 07, 2004 Posts: 2054 Location: Portland, OR
Posted: Sun Feb 26, 2012 10:21 pm Post subject: |
Progress!
Posted: Tue Feb 28, 2012 9:01 am Post subject: |
are swayaway half shafts made in america? I'm sick of sending my dough far away someone said all of empi's inventory is chinese now..screw that.
I got some 1" wood dowel cut to my prelim lengths for the halfshaft modeling. Running the arms through their travel arcs will define the final length with 1/4 to 1/2" end play. just as soon as the ground dries... _________________ todd
89 tintop [below]
90 suby tintop
Posted: Tue Feb 28, 2012 1:51 pm Post subject: |
| thummmper wrote: | that ad would be
CONVERSION - $10000 (VENTURA)
Date: 2010-09-16, 8:11PM PDT
Reply to: [email protected] [Errors when replying to ads?]
1983 VANAGON WITH A NEWLY REBUILT AND WORKING CHEVROLET V6 MOTOR,
COULD USE A NEW SET OF TIRES AND TRANNY HAS A LOT OF MILES ON IT, ALL
THE GRUNT WORK IS DONE, TOW HITCH, PASSENGER VAN YELLOW. OBO.
STRAIGHT BODY, CARB CERTIFIED,
•it's NOT ok to contact this poster with services or other commercial interests
PostingID: 1958253954 |
I actually saw this van for sale again recently on cl and it needed a trans and had teething problems. wouldnt pass smog, etc. dont remember the price-- this is the cycle for poorly selected conversions.
the engine is too large and too much for the transaxle. you could buy 3 engines for what reinforcing the trans would cost. it depressed me so I didnt copy it. _________________ todd
89 tintop [below]
90 suby tintop
Posted: Fri Mar 02, 2012 10:21 pm Post subject: |
89 tintop [below]
90 suby tintop
r39o Samba Polizei
rubbachicken Samba Member
Joined: October 05, 2004 Posts: 1534 Location: nesting in socal
Posted: Sat Mar 03, 2012 8:12 am Post subject: |
very cool, i am liking your work, can you post better pictures of the modified trailing arms, i'd like to see the backside of the brake rotor, how the joints look _________________ lucy our westy
lucy's BIG adventure
lucy is 1985, with 2.1 Digifant, 4 speed manual
nesting in socal |
Zeitgeist 13 Samba Member
Joined: March 05, 2009 Posts: 2083 Location: Cascadia
Posted: Sat Mar 03, 2012 12:04 pm Post subject: |
Hi Todd, does the fact that you welded in the BMW hubs complicate your efforts to fabricate new axles? _________________ --Casey
'89 Bluestar
"Omnia Extares" |
Posted: Sat Mar 03, 2012 9:25 pm Post subject: |
the cup is tighter in there, but i still have a 1/4" space all around-
the boots have to be tapered and still might touch the spring pad gusset
we'll see
the right side is the weak link in this combination. setting the e/t back 1.5" adds to the clearance issue. I will probably install travel limit straps on the shock bolts with a waist tie to shorten up the stroke an inch--maybe.
this powertrain was intended to be 7" off the groundin the sedan and I am 8", which contributes too. I am glad I had those drive flanges made or this would be a deal breaker. I'd probably have to move the e/t forward and to the left a bit to give it more length, but it will be alright.
I only post this stuff because I have never seen anyone measure for custom half shafts before [photos]. as usual, you all are along for the right of discovery.
I pussed out and ordered taiwanese empi shafts in a kit 18.24" and another pair at 15-5/8" for the right.
It will be 800.00 but the sway-a-ways with stock lobros and boots with only one mismatched pair was 1100.00 bucks and sway-a-way is d.o.a. with service. they don't return phone calls.
they will have to be cut down- four lobro cv's with loose offroad settings for this angular oddity. they will rattle a little in turns- taper boots and plates-- but I went back to the jy for bmw cv bolts because I cant find the original sets to save me--frustrating- thats what happens with large distractions.
as it stands now, the right axle is 14" and the left is 18". _________________ todd
89 tintop [below]
90 suby tintop
Posted: Sun Mar 04, 2012 12:39 pm Post subject: |
Thanks for the explanation. Looks like you're getting really close to launch day. _________________ --Casey
'89 Bluestar
"Omnia Extares" |
Posted: Fri Mar 16, 2012 9:37 pm Post subject: |
the stick excersize was for ballpark dimensions and were just the priliminary first part. since I posted all the other posts about not seeing anyone else do this, I have since found the syncro guys doing this in depth. I salute them for the intel-
I took my old bmw sedan halfshafts apart
the bmw lobros arent good for this app-- they dont telescope enough.
and cut sections out of their centers for the mockup- left side at full droop
and at ride height-- a 5/16" difference [ telescoped them out for the other photo]
and the right side at ride height
and at full droop
see the engine/trans offset aft [1.5"]
I just bought another donor car to haul my mom in and eventually steal the e/t out of. it's a 97 dodge intrepid sport with paddle shifter......45k miles!!! 2800.00 bucks where kelly blue said 4200.00. great goodyear tires and a pristine interior. I just got fuel rail o-rings for it coming tomorrow and the top end gaskets-[v covers, etc] nice power. the trans has tall gearing-- second gear tops out at 80. ac is super cold, etc.
89 tintop [below]
90 suby tintop
Posted: Sun Mar 25, 2012 10:26 pm Post subject: |
Semi-unrelated, but, since the photos are elsewhere, then what the hell--this is the son of vanagon lhs-- the previa lhs. scaled viability study drawings using the same powertrain as the vlhs--here goes
and the related chassis and e/t stuff- the right side of the drawing is the rear of the van
much more room than the vanagon between the stringers at 43" as opposed to 23". the ho 3.5 with aluminum block and precats in the manifolds will fit here--and the coachworks are nicely different too _________________ todd
89 tintop [below]
90 suby tintop
Posted: Fri Mar 30, 2012 10:54 pm Post subject: |
What is it??
89 tintop [below]
90 suby tintop
r39o Samba Polizei
Posted: Sat Mar 31, 2012 11:55 am Post subject: |
Taking a wild-ass guess, I'd say that's a crank sensor mount for Megasquirt-N-EDIS in a Duesenberg...?
Posted: Sat Mar 31, 2012 9:46 pm Post subject: |
it took me 5 days to decide on this design
luckily the ac bezel unscrews from the ceiling
and tacking was short to keep the heat down off the plastic
89 tintop [below]
90 suby tintop
