smokey503 Samba Member
Joined: October 01, 2010 Posts: 713 Location: Ridgefield Washington
Posted: Tue Apr 03, 2012 11:42 am Post subject: What to check before turning the key for the first time? |
I have been building a 1974 Super for a little while now.
I am looking, and have searched for a Check List on what to look for before turning the key the first time? Really don't want a fire, or my project to go Poof.
If there is a link, or anywhere someone can point me to or even help me, I am just a little nervous to turn the key. I have zero help from anyone so will have a few fire extinguishers ready. Hope they are not needed.
What I have replaced so far:
Brakes, everything there is new. Finally Bled them.
Fuel lines replaced
Re packed the front and rear wheel bearings
Wiring looks stock and in good shape.
Installed motor and dual Kadron's last night
Just nervous as a criminal in court trying to turn the key.
Any help is always appreciated. _________________ If a car travels the speed of light, would the headlights work? |
Cusser Samba Member
Joined: October 02, 2006 Posts: 31361 Location: Hot Arizona
Posted: Tue Apr 03, 2012 12:14 pm Post subject: |
If it's a brand new engine, or has sat for a very long time, pull the coil wire (so it won't start) and crank the engine to build up sufficient oil pressure. Then replace that, and start it up.
Go slow until you've fully checked out the brakes - but you knew that already. _________________ 1970 VW (owned since 1972) and 1971 VW Convertible (owned since 1976), second owner of each. The '71 now has the 1835 engine, swapped from the '70. Second owner of each. 1988 Mazda B2200 truck, 1998 Frontier, 2014 Yukon, 2004 Frontier King Cab. All manual transmission except for the Yukon. http://www.thesamba.com/vw/forum/album_page.php?pic_id=335294 http://www.thesamba.com/vw/forum/album_page.php?pic_id=335297 |
mondshine Samba Member
Joined: October 27, 2006 Posts: 2769 Location: The World's Motor Capital
Posted: Tue Apr 03, 2012 12:15 pm Post subject: |
Is the engine new, or previously run?
If it were me, I would push the car out of the garage and have a helper standing by with a fire extinguisher just in case. No helper? Hop out and run back there asap to look for fuel leaks.
I would disconnect the green wire from the coil and crank the engine until the oil pressure light goes out; then re-connect.
You might consider filling the carburetor bowls with a little gas (with a tiny funnel through the float bowl vents) so the engine has fuel to run until the fuel pump starts pumping.
Take a final look and let 'er rip. Don't earn your log in name, Smokey!
Good luck, Mondshine
hobbybob517 Samba Member
Joined: June 02, 2011 Posts: 1194 Location: Netherlands
Posted: Tue Apr 03, 2012 12:19 pm Post subject: |
Also check if it's in neutral, ask my friend why you should always make sure it's not in reverse when your helper is checking for leaks. _________________ THE BUILD http://www.thesamba.com/vw/forum/viewtopic.php
SBD wrote: |
3 million rpm? Well there's your problem! No wonder it blew up! |
RA 70 Samba Member
Joined: May 16, 2009 Posts: 1092 Location: Sacramento
Posted: Tue Apr 03, 2012 12:22 pm Post subject: |
Make sure it has oil in the engine and tranny |
68IHscout Samba Member
Joined: March 10, 2010 Posts: 3122 Location: santa ana ca
Posted: Tue Apr 03, 2012 12:25 pm Post subject: |
As posted , take coil wire off , crank a few times check lines for any leaks ,...doble check everything |
Posted: Tue Apr 03, 2012 1:38 pm Post subject: |
This is why I love this site!!!
I would of never thought of taking the coil wire off before trying to start it.
I am using the engine out of my wrecked 72 Super. Replaced the fuel pump with a alternator type, which left my head scratching.
On my old Generator type fuel pump, the push rod was shorter than the one I got with my Alternator fuel pump.
The Generator fuel pump rod was a little rounded off at the pointy end, which had me going back to the parts store. They measured it and they did give me the correct Push rod to begin with.
So what would make my Generator push rod shorter in time from being used?
I am pretty sure the Alternator push rod is supposed to be shorter than the Generator style. Please correct me if I am wrong. _________________ If a car travels the speed of light, would the headlights work? |
