Wayne26 Samba Member
Joined: November 18, 2010 Posts: 284 Location: Houghton Lake MI
Posted: Wed Apr 04, 2012 7:27 am Post subject: stumped on brake issues |
Hello
I'm having a wierd issue with the brakes on my buggy. at first everything was old and the brakes were sticking badly and randomly locking solid.
I replaced all wheel cylinders still had issues.
I replaced the master cylinder still had issues.
I replaced all rubber and steel lines still have issues.
everything is new now but randomly the brake system pressures itself up. It can be just sitting in the garage for days and all the pedal freeplay will be gone, brake lights on, brakes locked solid. I have to break a bleeder loose and it squirts fluid like someone is pushing the pedal hard and I can hear the brakes release.
after I do the bleeder it's usually fine for the day. it's a stock brake setup kingpin/swingaxle.
any ideas? |
joescoolcustoms Samba Member
Posted: Wed Apr 04, 2012 7:36 am Post subject: |
The only idea that comes to mind, make sure the push rod has play so it is not slightly holding the MC piston in the cylinder covering the fluid resivoir port. _________________ Bad News Racing 2018 NORRA 1000 3rd in Class
manxdavid Samba Member
Joined: November 24, 2003 Posts: 1841 Location: David Jones, Anglesey, North Wales, UK. Manxclub #678.
Posted: Wed Apr 04, 2012 8:11 am Post subject: |
joescoolcustoms wrote: |
The only idea that comes to mind, make sure the push rod has play so it is not slightly holding the MC piston in the cylinder covering the fluid resivoir port. |
X2...sometimes they can feel as if they have free play when it's just not enough. 1mm at the pushrod can equate the quite a lot at the pedal. |
Dale M. Samba Member
Joined: April 12, 2006 Posts: 20366 Location: Just a tiny bit west of Yosemite Valley
Posted: Wed Apr 04, 2012 8:33 am Post subject: |
Got to go with the above two suggestions... Had same issue at one point. A little twirl of the adjustment and all is well....
Posted: Wed Apr 04, 2012 8:45 am Post subject: |
thanks for the replies. I had set the freeplay but will check it again. |
bigtonkakid Samba Member
Joined: April 23, 2007 Posts: 250 Location: USA HOME OF THE FREE BECAUSE OF THE BRAVE
Posted: Wed Apr 04, 2012 8:14 pm Post subject: |
I had a master cylinder that was new but the piston inside was sticking. I also had the wrong year push rod it, the adjusting nut would catch the hole sometime here is a link to some info
http://www.thesamba.com/vw/forum/viewtopic.php?t=438127 _________________ YES, I drove a hardtop Buggy!!! |
