Stanw3 Samba Member
Joined: September 26, 2003 Posts: 1078 Location: Albuquerque, NM
Posted: Mon Mar 26, 2012 6:11 am Post subject: |
I have a guy looking for me - should hear something by tomorrow. Fingers crossed! _________________ Sanborn7
www.facebook.com/Sanborn7 |
bugmandave Samba Member
Joined: December 30, 2005 Posts: 284 Location: Illinois
Posted: Tue Mar 27, 2012 2:27 pm Post subject: |
| Stanw3 wrote: | I'm looking at my new window scrapers I got from Chuck and I'm wondering if there are some words of experience/wisdom out there before I go poking holes in them.
Also, I can not find any good pics or info on the window wedges. I'll post a couple of pics here about the quarter window wedges and and hopefully it will help someone else down the line with these.
At the rear wedge, does the hold down flap (under trim) go to the outside of the car or the inside? What does the screw look like that is used to mount it?
On the front wedge: Same question about the flap - which side?
How much and where do you trim the scraper?
Again, what do the screws look like that secure it to the pillar?
On the trunk seal: Am I supposed to just leave a gap at the top corners? I don't see any good way to make this area work???
Thanks for the help!!
there are supposed to be gaskets under the aluminum plates at the top of the quarter also. hood seal on the earlier cars didn't have any gaskets at the corners but you can service install them by drilling the holes for the nipples. there is a pattern in the Bently manual. your second picture is correct, the other door wedge is not. the extended piece goes on the inside so the outside scraper is a continuous piece all the way. the screws are tiny phillips head chrome screws with trim washers. about the size of the screws that hold the top window seals on. |
Stanw3 Samba Member
Stanw3 Samba Member
Posted: Thu Mar 29, 2012 4:43 pm Post subject: |
| If that's for the dome light it should come out of that smaller hole by the big harness grommet with a smaller grommet |
Braukuche  Samba Member
Posted: Thu Mar 29, 2012 6:42 pm Post subject: |
Window winding mechanisms, were they painted or just bare metalk as well as the metal bits that make up the sliding stuff on the glass? _________________ Go Reds! Smash state!
My retirement plan:
1958 PG/SG Standard
1959 SO-23 Westfalia
1960 crusty double cab
1960 convertible bug
1962 So-22 Mosaic Westfalia
1963 356 B coupe runner
1963 356 B coupe in pieces
1965 standard sunroof bus
1967 912 |
lovethatconvertible  Samba Member
Joined: August 22, 2008 Posts: 934 Location: Las Vegas N. V.
Posted: Thu Mar 29, 2012 8:20 pm Post subject: |
| Braukuche wrote: | | Window winding mechanisms, were they painted or just bare metalk as well as the metal bits that make up the sliding stuff on the glass? |
Bare Metal |
386kustoms Samba Member
Posted: Sat Mar 31, 2012 5:10 am Post subject: |
| man i love how clean these cars are coming out, i cant wait till mine looks like that |
Posted: Sat Mar 31, 2012 8:49 pm Post subject: |
Let's talk quarter window problems.
I have my window in. When rolled up, it sits dead center. As I roll it down, it begins to slant inward toward the inner side of the channel. It then begins to bind. I must force it down and it sort of clunks and then continues down. As it does to, it begins to recenter itself.
I thought it was the channel, but the frame is not binding in the channel, in fact, it seems the roller (the round piece of the regulator that fits into the channel on the window frame) binds up. I have tried loosening the two bolts and adjusting the mounting bracket for the window frame but to no avail. Any ideas?? _________________ Go Reds! Smash state!
My retirement plan:
1958 PG/SG Standard
1967 912 |
Stanw3 Samba Member
Posted: Sun Apr 01, 2012 5:15 am Post subject: |
are you sure the channel for the roller doesn't have a kink in it? Sounds like that might be bent from the action???? _________________ Sanborn7
Posted: Sun Apr 01, 2012 6:49 am Post subject: |
| Stanw3 wrote: | | are you sure the channel for the roller doesn't have a kink in it? Sounds like that might be bent from the action???? |
I did take a wrench to it and twisted a little here and there and that seemed to help, so maybe you are on to something. I kept thinking it must be the guide channel that was causing the window to twist like that, but it must be the channel for the roller. _________________ Go Reds! Smash state!
My retirement plan:
1958 PG/SG Standard
1967 912 |
Stanw3 Samba Member
Posted: Sun Apr 01, 2012 7:59 am Post subject: |
I'd take it back out and get the channel on a bench where you could get a good look at it. _________________ Sanborn7
Posted: Sun Apr 01, 2012 11:37 am Post subject: |
| Stanw3 wrote: | | I'd take it back out and get the channel on a bench where you could get a good look at it. |
I did and what a mess.
The channel that holds the window was catching on the top right hub of the regulator and was slowly getting peeled back and distorting the channel for the roller. I had to remove the regulator, take the window apart inside of the body and then extract the whole mess is pieces like a tooth extraction gone bad. I then had to spend a good hour straightening the mess out, reinstall and adjust so the window is as far away from the regulator as possible. Just a typical day in VW restoration land: two steps forward, one step back... _________________ Go Reds! Smash state!
My retirement plan:
1958 PG/SG Standard
1967 912 |
Stanw3 Samba Member
Posted: Tue Apr 03, 2012 3:38 pm Post subject: |
Front door wedge - do I have this laid out correctly??
EDIT:: I have the wrong side door seal installed in these photos.
The Bentley photo isn't much help.
jays58s Samba Member
Posted: Fri Apr 06, 2012 6:34 pm Post subject: |
58' vert just showed up today... I've never owned a vert, 1st time for everything right? It's fairly straight but needs work.
 _________________ Responsibility is a heavy responsibility. |
Posted: Fri Apr 06, 2012 7:03 pm Post subject: |
| Awesome, Post some more pic's when you get into it. What's the status on the parts that are missing in the pictures? |
Posted: Fri Apr 06, 2012 7:05 pm Post subject: |
| lovethatconvertible wrote: | | Awesome, Post some more pic's when you get into it. What's the status on the parts that are missing in the pictures? |
Most of it seems to be there but I don't have the energy to go through it right now. lol (a bit hungover still) I'll post some pics though tomorrow after I go through it. _________________ Responsibility is a heavy responsibility. |
Posted: Fri Apr 06, 2012 7:15 pm Post subject: |
A Bloody Mary will put you back on top of your game Post some pic's of the spare tire area, trunk and inside when you get back on it. we love Pictures. |
Posted: Fri Apr 06, 2012 7:29 pm Post subject: |
| lovethatconvertible wrote: | A Bloody Mary will put you back on top of your game Post some pic's of the spare tire area, trunk and inside when you get back on it. we love Pictures. |
For sure! I'm kinda bummed that they started painting it some funky olive color so I'm going to have to dig a little to find the original color on it. The tank must have been replaced too cause it's black, or someone painted it. _________________ Responsibility is a heavy responsibility. |
Posted: Mon Apr 09, 2012 9:51 am Post subject: |
I am trying to finish up my top installation today and have a question. Chuck is not open on Monday so I can't pester him.
I have my top pretty much tacked up. The only problem is the sides. The sides in teh rear atachto the outer facings, got that on. There is a bead that runs down the facing then terminates toward the rear. There is then the beading that you use to cover the screws attaching the rear bow to the body. What is the juncture of those two beads supposed to look like? I have the chrome strip that covers the seam between the bead and the top on the rear bow, does that cover the junction of the two beads? Also, I am having a heck of a time getting the material to pull low enough in that area to get the two beads to even connect. Any tips there? Picture would be nice if anyone has one handy. _________________ Go Reds! Smash state!
My retirement plan:
1958 PG/SG Standard
1967 912 |
