Weber 44 IDF's
quadsource
quadsource is offline
PostPosted: Fri Apr 06, 2012 5:06 pm    Post subject: Weber 44 IDF's Reply with quote
I rebuilt them both. Upon tunning and re-tunning I noticed one of the mixture screws does nothing when I adjust it. It's above cylinder #2. I also noticed the exhaust pipe on that cylinder is not as hot as the rest. I get a little POP from that velocity stack.
Good compression
New plugs
Wires
Rotor
Cap
I went through the carb twice.
Air passage or something I'm missing?
Thanks....
Dale M.
Dale M. is offline
PostPosted: Fri Apr 06, 2012 6:32 pm    Post subject: Reply with quote
Dirty passage of clogged idle jet.... Pull it out and look at it ...AGAIN...
Dale
“Fear The Government That Wants To Take Your Guns" - Thomas Jefferson.
KopfenJager
KopfenJager is offline
PostPosted: Fri Apr 06, 2012 11:16 pm    Post subject: Reply with quote
plugged idle jet. 99.9% of the time if a carb problem appears, its a idle jet.
