Dont look if youre a purist!!! Volksrod build
Goto page Previous  1, 2, 3, 4, 5, 6  Next
BeetleBobby
BeetleBobby is offline
PostPosted: Fri Apr 06, 2012 5:59 pm    Post subject: Reply with quote
GREAT WORKMANSHIP Exclamation Exclamation Very Happy Very Happy Very Happy
Can't wait for the next phase.
1974 SB Sedan (original unrestored)
Bob
super72beetle
super72beetle is offline
PostPosted: Fri Apr 06, 2012 7:01 pm    Post subject: Reply with quote
your car is awesome keep up the good work
poomwah
poomwah is offline
PostPosted: Sat Apr 07, 2012 10:51 am    Post subject: Reply with quote
Could you give us some pics and info anout how you extended your steering please
Rocco- my build thread
http://www.thesamba.com/vw/forum/viewtopic.php?t=479675
b1pig
b1pig is offline
PostPosted: Sat Apr 07, 2012 11:20 am    Post subject: Reply with quote
i have to agree that i like that look. the whole thing looks clean as well.
my car has enough rust and crappy "repairs" done that i don't think i can afford to restore my super. was thinking a sort of baja look... but the lack of any front fenders had me considering a similar move to what you have here. it certainly is thought provoking to say the least.
i'm looking forward to see the paint work.
DROPPEDATBIRTH
DROPPEDATBIRTH is offline
PostPosted: Sat Apr 07, 2012 1:45 pm    Post subject: Reply with quote
Great work man, waiting on pictures of the painted product.
Click to view image
blue72!
blue72! is offline
PostPosted: Sat Apr 07, 2012 3:47 pm    Post subject: Reply with quote
Looks to me like your taking something that would have been scrapped and turning it into an amazing car. Great looking volksrod and very tasteful (so far)! You've got some great skills. I, like others, are waiting to see what else you do.
enfamy
enfamy is offline
PostPosted: Sat Apr 07, 2012 6:00 pm    Post subject: Reply with quote
love it. what are the plans for where the running boards used to go
modelmakerinc
modelmakerinc is offline
PostPosted: Mon Apr 09, 2012 3:35 pm    Post subject: Reply with quote
thanks guys nice to hear the kind words, To answer a couple of questions:
The speaker housings under the dash are simple sheet metal cut bent and fitted into the corners, welded, filled and painted, the carpet will need to be adjusted around them.
The steering is a couple of steps. you need two u-joints and a long piece of splined shaft like these on pages 312/313.(http://www.empius.com/vwcatalog/2011/312.html http://www.empius.com/vwcatalog/2011/313.html)
My 70 had 5/8" shaft. measure yours, before purchasing parts. Take the splined female part off the steering box and undo the "rubber coupler" Cut the steering column just above the the crash tube, section that looks like mesh. This will leave it as a hollow tube. Drill a couple holes through the tube a inch or so above the cut, Cut a segment of the splined shaft, the splines will be used with one new u-joint, the other side gets slid up the steering column, and plug welded through the holes and a weld along the end of the tube. this finishes the steering column side.
The other u-joint gets one side cut off and welded to the female coupling which was on the steering box. These parts need to be aligned through the centerline of the coupler and u-joint. other wise it will look funcky when it is being turned. and not really work properly.
the remaining segment of the purchased shaft gets cut to fit between the u joints and then welded to the u-joints. this makes a new segment which is removable. the spline on the steering column and a spline on the steering box are fastened with the clamping bolt with the correct spline count. remember to phase the u-joints in the same oreintation.
the area where the running boards were gets a neat treatment but it will have to wait till I get to it to show you.
poomwah
poomwah is offline
PostPosted: Mon Apr 09, 2012 6:29 pm    Post subject: Reply with quote
Thanks modelmaker. That cleared things up and confused me at the same time, lol
poomwah
poomwah is offline
PostPosted: Mon Apr 23, 2012 12:27 pm    Post subject: Reply with quote
Any more progress?
modelmakerinc
PostPosted: Sun May 06, 2012 5:25 pm    Post subject: Reply with quote
well, just a small update. car is primed and blocked just needs a little touches before paint so it can come home.
Image may have been reduced in size. Click image to view fullscreen.Image may have been reduced in size. Click image to view fullscreen.
mattintheboxx
mattintheboxx is offline
PostPosted: Tue May 15, 2012 9:27 am    Post subject: Reply with quote
Any new up dates??? I' m excited to see how it looks Very Happy
modelmakerinc
PostPosted: Fri May 25, 2012 7:51 pm    Post subject: Reply with quote
its coming home tomorrow. here is a couple teaser pics
super72beetle
PostPosted: Fri May 25, 2012 7:53 pm    Post subject: Reply with quote
looking good.
Wideopen
Wideopen is offline
PostPosted: Fri May 25, 2012 8:20 pm    Post subject: Reply with quote
So far, great job. I looks like it will turn out very nice!
I am not much of a purist so what ever suits you! I have learned some folks will not understand the reason or desire to mod a product(car, firearm or whatever) Do what you want it is yours, that is what I think!
Can't wait to see the end result!
Tompkins
Tompkins is offline
PostPosted: Fri May 25, 2012 9:41 pm    Post subject: Reply with quote
Man what are those rims you are running? I want exactly those! And what is the width of the back ones?
allsidius
allsidius is offline
PostPosted: Sat May 26, 2012 12:20 am    Post subject: Reply with quote
With those rear wheels it should really pack a punch! Hope you won't be running that single carb 1600 for long.. Are you sure the engine will be able to pull them loose from the street if parked on a hot day? Smile
1973 1303S w sunroof
1978 1303 convertible (sold)
1966 1300 RIP
green73
green73 is offline
PostPosted: Sat May 26, 2012 4:05 am    Post subject: Reply with quote
I want your car man! Thats gona be very cool. I would bring the front down a little bit if it were mine Cool
~Tim~
Own now. 1973 bright green standard Beetle daliy driver Green Bug
Owned. 1977 yellow AMC Gremlin
1974 Lincoln Continental mark IV
1986 4X4 Nissan pickup
modelmakerinc
PostPosted: Sat May 26, 2012 5:48 pm    Post subject: Reply with quote
home from paint. It isn't flawless but its perfect. the color is awesome, my custom mix of charcoal even has a ever so slight tinge of green.
modelmakerinc
PostPosted: Sat May 26, 2012 5:51 pm    Post subject: Reply with quote
The front will come down a little more with a 145-15 tire on a 3-1/2" centerline, the rear are 15x 10 w/ 295-50-15 coopers.
Page 2 of 6
