Oval straight shifter
buggen
buggen is offline
PostPosted: Sat Apr 07, 2012 10:49 am    Post subject: Oval straight shifter Reply with quote
I am trying to find the correct shifter for an early 55, US delivered semaphore car. I got one that I thought was correct but it was a little bit shorter than the one in my 53 oval. Also my 53 has a short shifter mounting base and the one I got for the 55 came with a tall base. I am starting to think I got a split bug shifter.
Would this be correct for straight shifters?
Split bug- tall base shorter shifter length, total shifter length 32.4 cm
Oval bug -short base slightly longer shifter
thanks for any help
RareAir
RareAir is offline
PostPosted: Sat Apr 07, 2012 2:58 pm    Post subject: Reply with quote
Pre '52 shifters have a small diameter ball at the end which measures roughly 15.7mm
1953-55 shifters have a larger 21.5mm diameter ball on it's end
A Split era shifter won't work properly in your '55 unless a you, or a previous owner, replaced the original shift rod with a Pre '52 shift rod inside the center tunnel.
1947 Type 11a
1954 Type 117
1956 Type 151
1966 Type 151
1966 Type 251
Sent from my iPhone 9S
RareAir
RareAir is offline
PostPosted: Sat Apr 07, 2012 3:04 pm    Post subject: Reply with quote
As for the shifter base dilemma, Yes Pre '52 shifters use a much taller base. 1953-laters Type 1s use a shorter version. Because of this difference, the earlier shifters (with a 15.7mm ball) has the fulcrum pivot placed up higher on the shifter.
1947 Type 11a
1954 Type 117
1956 Type 151
1966 Type 151
1966 Type 251
buggen
buggen is offline
PostPosted: Sat Apr 07, 2012 3:45 pm    Post subject: Reply with quote
Thanks, that is what I was thinking, I got a split shifter. Anyone want to trade a split shifter for a straight oval shifter?
