Help me build my next T3 engine (dell tuning help)
Goto page Previous  1, 2, 3, 4, 5  Next
Forum Index -> Performance - Engines/Transmissions Share: Facebook Twitter
W1K1
W1K1 is offline
PostPosted: Sat Dec 24, 2011 3:16 pm    Post subject: Reply with quote
Silverline
http://www.thesamba.com/vw/archives/manuals/jim_martin_engine_build.php
1973 super
1961 beetle
1965 squareback 1500E
W1K1
W1K1 is offline
PostPosted: Mon Dec 26, 2011 8:30 am    Post subject: Reply with quote
So i have a couple suggestions off the forum on ways to go
One was enlarge the head from 53 to 55cc and run .050" deck for a 8.5:1 with the W100.
Or swap the cam to a W110 (1500-5500rpm) or a web 163 (1300-5500rpm)
Which i could remove shims and tighten the deck for.
Bearing in mind we are running small pdsit carbs , stock oil bath and 1.3/8 exhaust with heat exchangers and the redline is going to be 4500-5000.
This is a daily driver that i want to have some torque to get it's 2200lbs moving and be able to cruise on the highway NOT a 7000rpm screamer in a 1600lb bug (i have one of those Wink )
1973 super
1961 beetle
luckystiff
luckystiff is offline
PostPosted: Mon Dec 26, 2011 12:43 pm    Post subject: Reply with quote
i've been going back and forth on cam choice for the 1955 i'm about to build for my square. Web 163 has been at the top of the list most of this time. 2 others that were suggested to me were the web 86a and 86b running 1.25(both are 1.4-1.5 rocker cams) the 86b with 1.25s has pretty close to the same lift as the 163 with 1.25s. the 86b does have more duration though 300/260 vs 284/249. the 86a is in between the 2 and you may get a closer to desirable lift with 1.33s.
where i'm stuck on my deciding which is when/if i'll get more serious that stock valved fluff and buffed heads. if not then the 163 is full on my choice. if i'm gonna go with a nice set of larger valved ported and polished heads and build a bigger exhaust then maybe the 86b is more along what i want and run 1.25s with the worked stock heads and swao to 1.4-1.5 when i upgrade the heads.
i've truly been back and forth on this for a month or more...ken....
ITMC
Secret Service
[email protected]
john@aircooled.net is offline
PostPosted: Mon Dec 26, 2011 1:44 pm    Post subject: Reply with quote
I'd run a Web 163 on 105LC and don't look back. If you want to get Froggy run some 1.3 rockers with it too.
"Like" our Facebook page at
and get a 5% off code for use on one order for VW Parts ON THE NEW WEBSITE, vwparts.aircooled.net
W1K1
W1K1 is offline
PostPosted: Mon Dec 26, 2011 4:16 pm    Post subject: Reply with quote
Thanks John
I wasn't sure if you were checking in here.
I am pretty sure i want to run the web 163 now from all my reading through the forums.
I am still unsure about the deck being .077" it seems big, if i drop the .010" spacer out it would be down to .067" and 8.4:1 compression.
Or am I pushing it with a heavy car and too ?
I'm guessing my ACN lifters are okay with the change to a web cam.
1973 super
1961 beetle
luckystiff
PostPosted: Mon Dec 26, 2011 4:30 pm    Post subject: Reply with quote
i'm sure john will comfirm or correct his but i think optimal cr for that cam is 8:1 - 8.5:1 range or so. i'm a coupla weeks out from buying my cam lifter due to not getting a bonus i was expecting from work but planned to contact john about my choice of that cam with my set up...ken....
ITMC
Secret Service
W1K1
W1K1 is offline
PostPosted: Sun Feb 12, 2012 8:13 am    Post subject: Reply with quote
so far the engine plan was, but now i am looking at a set of Dellorto 36 or 40's instead of the PDSIT carbs
Which way to go??? 36 or 40's and initial jetting?
30 vent
122 main
180 air
55 idle
DRD L3 heads
90.5 b piston & cyl
5.5 rods
74 stroke
Web 163 cam
1.1/2 quart CB thinline sump
stock PDSIT carbs and oil bath
OTT exhaust and heat exchangers (i drive it all year or till they start salting the roads )
8.59:1 compression
1973 super
1961 beetle
W1K1
W1K1 is offline
PostPosted: Thu Apr 12, 2012 9:18 am    Post subject: Reply with quote
Fired up the 1904 last night, and it's lean popping like crazy, 3 turns out on the idle screws plus another 2 or 3 while it was running and it's still popping.
I had to keep throttling it during the break in to keep the afr around 13 at 3000 rpm, if it settled at all it would pop and read 18 or so afr.
I have a set of 60 idles i can drop in and try, or I'll start drilling my 49 idles till I come up with something it likes.
it definitely sounds different than the 1600 Twisted Evil
The carbs are 36 dells from alfa 1750
30 vent
122 main
190 air
49 idle
1973 super
1961 beetle
ALB
ALB is offline
PostPosted: Thu Apr 12, 2012 9:34 am    Post subject: Reply with quote
Since you have them, drop in the 60 idles and see what it does...
On a lifelong mission to prove (much to my wife's dismay) that Immaturity is Forever!!
Slalombuggy- Now I understand my trust issues...
W1K1
W1K1 is offline
PostPosted: Sat Apr 14, 2012 8:39 am    Post subject: Reply with quote
Swapped in the 60's it was rich but i figured i could get the timing checked at least and get it to idle. But then it started running rough and wouldn't respond to the throttle so i figure we fouled the plugs.
I'll pull the plugs and see where to go from there.
It was still popping through the idles on all 4 until i turned up the mixture but then it ran like a bag 'o crap.
1973 super
1961 beetle
krusher
krusher is offline
PostPosted: Sat Apr 14, 2012 10:51 am    Post subject: Reply with quote
49 idles, sounds like alfa1750 was getting serious, I though he would have just given you 50's Confused
(06:31:07) RoachGhia: "i drink dick way too fast"
(06:54:29) BoomsVW: "i always feel free down there"
W1K1
W1K1 is offline
PostPosted: Sat Apr 14, 2012 11:20 am    Post subject: Reply with quote
He gave me what John recommended for the combo, which was a 49
1973 super
1961 beetle
krusher
krusher is offline
PostPosted: Sat Apr 14, 2012 11:25 am    Post subject: Reply with quote
my bus idles 13ish, then goes to 17 on the idles then back to 13 on the mains.
I think you need some john tuning help Wink
W1K1
W1K1 is offline
PostPosted: Sat Apr 14, 2012 3:02 pm    Post subject: Reply with quote
Yup the plugs were black with the 60's
back to the 49's and i reamed them till they fit the 50 on the jet gauges which seems like it was a lot. 5 turns out on the mixture screws now and it idles, still popping out the drivers side so I'm going to pull the carb and check the gasket and the plugs while i'm in there.
on a side note.... the 1/4" drive 12" wobbler extension is just the ticket to getting the nuts off the manifolds with little effort. i'll post a pic later for the T3 guys.
1973 super
1961 beetle
W1K1
W1K1 is offline
PostPosted: Sat Apr 14, 2012 5:05 pm    Post subject: Reply with quote
This was the 50 idle , looks lean still 52?
And for the type 3 guys, easy access with the 12" wobbler extension and the 3/8" head nuts.
1973 super
1961 beetle
W1K1
W1K1 is offline
PostPosted: Sun Apr 15, 2012 2:42 pm    Post subject: Reply with quote
took a couple videos to show what's going on.
floats are set 6mm and 12mm
fuel pressure 3-3.5 psi, stock pump
019 set at 7btdc at idle
I am getting fuel dripping from the aux venturi when it's idling, so it seems to be loading up and then popping and spitting
you can see the drip in this video
and the popping/spitting in this video, if the revs are held up for a while it will backfire out the carb and pop/spit
I'm not new to dells, we have 2 sets of 45's in the beetles, but this I haven't run in to before
HELP i want to drive this so I can seat the rings.
and it's my daily driver once it's running again
1973 super
1961 beetle
66brm
66brm is offline
PostPosted: Sun Apr 15, 2012 6:38 pm    Post subject: Reply with quote
For the first video, you may need to lower your float setting
For the second, my 40IDF's do the same thing when the engine is not up to running temp yet, is the engine up to temp?
Aust. RHD 66 Type 1
Aust. RHD 57 Type 1 Oval
[email protected] wrote:
Kadrons are horrible excuses for carburetors.
modok wrote:
I am an expert at fitting things in holes, been doing it a long time
modok
modok is offline
PostPosted: Sun Apr 15, 2012 7:05 pm    Post subject: Reply with quote
6-7mm float height and 55 idle is what I'd expect normal to be
Seat the rings first and play with the jets later
W1K1
W1K1 is offline
PostPosted: Sun Apr 15, 2012 7:33 pm    Post subject: Reply with quote
It won't run without barking, spitting and backfiring so until i get the extra fuel to stop dribbling from the auxilary venturi i'm kind of stuck.
If i rev it after it dribbles for a while it either backfires out the exhaust or a backfire out the carb. I don't want a fire under the decklid while out driving around
I have 52 idles at this point.
So going lower than 6 mm for the floats is okay?
That is the only thing i could think of to fix the dribble
And no it wasn't warmed up yet
1973 super
1961 beetle
DarthWeber
DarthWeber is offline
PostPosted: Sun Apr 15, 2012 7:48 pm    Post subject: Reply with quote
You probably checked this already but are all your air bypass screws closed off? Have you checked for vacuum leaks around the manifolds?
Mitey62 wrote:
Swapped the Compufire for a Bosch blue and some points I had sitting around, started 1st crank. Took her out for a drive, pulls harder, more RPM, and runs smoother. I think I'll be sticking with points from now on.
RockCrusher wrote:
JB weld the case halves....that'll keep the fretting to a minimum. Laughing
Reply to topic    Forum Index -> Performance - Engines/Transmissions All times are Mountain Standard Time/Pacific Daylight Savings Time
Page 2 of 5
