wizcleland Samba Member
Posted: Mon Apr 16, 2012 2:18 pm Post subject: Will the rockers fit? |
Hey Samba!
I have a new set of the CB 1:1.25 rockers (have the kit - http://cbperformance.com/catalog.asp?ProductID=92). Right now stock arms are in.
Question is -
Will these bolt right in? Trying to get an answer from CB but no help. I'm willing to try but what should I watch for?
Any idea if you HAVE to machine for these or theres a chance to fit?
Also, do they impact the pushrod length and would need to change?
Unfortunetly, dont know what kind of heads are on the motor but they are ported.
Cam is a 100
Cylinders are 88.5 or 90s.
As always, Any help would be appreciated! _________________ Life in Mexico, surrounded by Beetles daily....and able to stop at the parts store on the way home for anything, any day ahhhhhh |
slalombuggy Samba Member
Joined: July 17, 2010 Posts: 3792 Location: Canada 306
Posted: Mon Apr 16, 2012 2:41 pm Post subject: |
Check you rocker arm geometry and make the changes needed whether it be shimming the rockers or longer pushrods. The should fit without any kind of machining being needed.
brad _________________ BB Buggy 121.253mph @ Bonneville 2012
http://www.youtube.com/watch?v=57hMyJmIU10
Raisin cookies that look like chocolate chip cookies are the main reason I have trust issues |
mark tucker Samba Member
Joined: April 08, 2009 Posts: 8646 Location: SHALIMAR ,FLORIDA
Posted: Mon Apr 16, 2012 5:58 pm Post subject: |
| might need to shorted the push rods a bit, but you will have to stick it all togeather to find out.and check for pushrod interfearance in the cup&the tube. |
neil68 Samba Member
Posted: Mon Apr 16, 2012 7:15 pm Post subject: CB 1.25's |
I've run 1.25's with the Engle 100 camshaft and you only need to shim the rocker stands slightly, and you can still use the stock 11" pushrods. _________________ Neil.
"Real men run drums."
Der Kleiner Rennwagens
68 Beetle 2332 cc
12.8 seconds @ 104 mph
http://www.youtube.com/watch?v=FF2gCti3dro |
Posted: Tue Apr 17, 2012 5:23 am Post subject: |
Thanks guys, appreciated.
I'm going to give it a try in a couple of weeks and I'll let you know how it goes!
Cheers! _________________ Life in Mexico, surrounded by Beetles daily....and able to stop at the parts store on the way home for anything, any day ahhhhhh |
Posted: Tue Apr 17, 2012 9:15 am Post subject: |
| I cant find slightly on my mics?is that mm slightly or what? |
dsrtfox Samba Member
Posted: Tue Apr 17, 2012 9:19 am Post subject: |
| Just a scosh... |
Posted: Tue Apr 17, 2012 9:30 am Post subject: |
| so it is metric.thanks. |
Sharig1979 Samba Member
Joined: December 20, 2008 Posts: 271 Location: Grand Rapids, Michigan
Posted: Tue Apr 17, 2012 12:38 pm Post subject: |
My go to answer from here on out is righty tighty lefty loosey and see what happens.
The aircooled VW ratio rocker is what a cam swap is to V8 guys. _________________ 1969 Beetle, turbo 1915
~118 mph on the salt at WoS 2012, 7k in 3rd, can't wait to figure out how to drive that engine on that stuff.
1972 914/4, 1.7
1991 GTI 1.8 8v, 4speed |
