Lowering the engine on ATV jack points
Goto page 1, 2  Next
porschpow
porschpow is offline
PostPosted: Tue Apr 03, 2012 5:57 am    Post subject: Lowering the engine on ATV jack points Reply with quote
I will be using an ATV jack with a 14 x 14 inch and 3-4 inch thick board on top. I don't want to damage the case so is there any ideo where exactly I can safely resst the case when I lower it?
-1973 Volkswagen Bus Westy (Weekender)
1.8 liter from 1.7(original)
-2011 Subaru Outback
-1986 Honda Magna
danfromsyr
danfromsyr is offline
PostPosted: Tue Apr 03, 2012 6:42 am    Post subject: Reply with quote
I tend to use an old tire w/o the rim.
but anything like a board would be fine.. you just don't want to go dragging & manhandling it on a bare floor with it's bare case.. though many have done that in the past.
if you have a harbor frieght, they have cheap furniture dollys that are very handy to keep it moveable in the garage.
VW Club of Central New York SPRING VW GTG
Upstate NY 2013 VWCCNY events
NY State VW Camping 2013 season events
porschpow
PostPosted: Tue Apr 03, 2012 6:47 am    Post subject: Reply with quote
Yes, I seen those dollys. However I will only be lowering it as I would like to successfully put the gas tank back in wihtout bending anythign out of shape.that is all. So i was inquiring to see as to if it would be ok to just lower it in the board going across the top bars of the atv jack
-1986 Honda Magna
SGKent
SGKent is offline
PostPosted: Tue Apr 03, 2012 7:56 am    Post subject: Reply with quote
you can leave it on the atv jack if you want. Here are examples of how our engine was stored when off the bus.
Steve aka Merlin the Wrench
formerly Steve's Racing and Engine Blueprinting. Wrenching since 1967.
bdamico on GF wrote
"When I was your age I'd plan out all sorts of stuff for the future and almost none of them came true. Just wonder if it's worth trying to be a crystal ball. "
drober23
drober23 is offline
PostPosted: Tue Apr 03, 2012 9:19 am    Post subject: Reply with quote
That sure is purdy there Steve!
To the OP, I just put a 2' section of 2x10 (or whatever is handy) on top of the jack and let the engine sit on that.
DJ
'75 Westfalia, '79 Deluxe, and some others...
(more busses than sense)
In a time of chimpanzees I was a monkey
aeromech
aeromech is offline
PostPosted: Tue Apr 03, 2012 11:57 am    Post subject: Reply with quote
Top notch Steve
Airbus A319,320,321
DC9/MD80
BAe146
Fokker F28/F100
VW type 1 1962,63,65,69,72
VW Type 2 1971 (2 ea.) 1978
VW Jetta
VW Passat
Amskeptic
Amskeptic is offline
PostPosted: Tue Apr 03, 2012 2:44 pm    Post subject: Reply with quote
You can perch it on trash cans too. It is only 268 lbs or thereabouts
Colin
There are four "pads" cast in the fins on the crankcase, any board that spans all four, and you are good to go.
www.itinerant-air-cooled.com
Helping You Keep It Alive For Ten Years Now
porschpow
PostPosted: Thu Apr 05, 2012 5:48 am    Post subject: Reply with quote
Very cool pics. I will have to look closely for these "pads" Thanks guys. Ought to be interesting lowering thie engine (and trans too i guess)
-1986 Honda Magna
SixStringMadMan
SixStringMadMan is offline
PostPosted: Wed Apr 18, 2012 7:15 am    Post subject: Reply with quote
Did you have any luck lowering your engine? I am trying to get my firewall back in after replacing the vapor lines and not having any luck so far, super tight fit. Wondering how easy it is to lower the engine say 2" just to get the firewall back in...
1978 Kombi
http://www.vw-mplate.com/mplate-10020.htm
aeromech
aeromech is offline
PostPosted: Wed Apr 18, 2012 7:24 am    Post subject: Reply with quote
You should be able to do this. There are two bolts that hold the transmission bell housing to the ceiling that will need to come out and then the rear hangar on the engine. You should be able to remove the bolts that attach the hanger to the frame of the bus. Once that's done I think you should be able to lower the engine and transmission a bit. Be careful not to go too far. I doubt you'd even need to disconnect any wires or the throttle cable.
Airbus A319,320,321
DC9/MD80
BAe146
Fokker F28/F100
VW Jetta
VW Passat
porschpow
PostPosted: Wed Apr 18, 2012 7:27 am    Post subject: Reply with quote
Yes, this is exactly what I was gonna do. Just take off the rear hanger bar and the top two bolts above the bell housing, just to lower it a few inches
-1986 Honda Magna
aeromech
aeromech is offline
PostPosted: Wed Apr 18, 2012 7:32 am    Post subject: Reply with quote
I don't think you need to remove the bar. Just unbolt the ends from the frame of the bus. Leave the hanger in place and the engine should lower straight down.
Airbus A319,320,321
DC9/MD80
BAe146
Fokker F28/F100
VW Jetta
VW Passat
porschpow
PostPosted: Wed Apr 18, 2012 7:36 am    Post subject: Reply with quote
Im sorry. That is what I meant. 2 Bolts each side right?
-1986 Honda Magna
aeromech
aeromech is offline
PostPosted: Wed Apr 18, 2012 7:40 am    Post subject: Reply with quote
I'm not sure. Just take them all out.
Airbus A319,320,321
DC9/MD80
BAe146
Fokker F28/F100
VW Jetta
VW Passat
porschpow
PostPosted: Wed Apr 18, 2012 7:49 am    Post subject: Reply with quote
Ok, but I can leave the bar atached to the motor right?
How the heck can you reach up there to take the bolts out from the bell housing
-1986 Honda Magna
aeromech
aeromech is offline
PostPosted: Wed Apr 18, 2012 7:59 am    Post subject: Reply with quote
Yeah, leave the bar on the engine. To get to the upper bell housing bolts you'll need to probably use a 3/8 air ratchet and about a 6 inch extension coming up and over the transmission from the drivers side. It helps to have long arms and you just about have to hug the transmission to reach the passeneger side bolt but you can do it. Be sure to support the engine from below with a floor jack while doing this.
Airbus A319,320,321
DC9/MD80
BAe146
Fokker F28/F100
VW Jetta
VW Passat
VDubTech
VDubTech is offline
PostPosted: Wed Apr 18, 2012 2:21 pm    Post subject: Reply with quote
Not at all necessary and it would only get in the way. Remove the two bolts over the transmission first, THEN the hanger bar. The engine will hang there all day long without the two bolts over the tranny installed. Raise it a little bit with the floor jack and then pull the 4 bolts out of the hanger bar and lower it down.
First Trip in the RustyBus:
http://www.thesamba.com/vw/forum/viewtopic.php?t=279077&highlight=
borninabus wrote:
a measurement of your rod would be extremely useful.
notchboy wrote:
my dad wasnt a belittling cock when he tought me how to wrench on cars.
One photo = good for reference.
10 photos = douchebaggery
drober23
drober23 is offline
PostPosted: Wed Apr 18, 2012 4:57 pm    Post subject: Reply with quote
Don't even need long arms. I'm pretty short, and don't have any trouble getting those bolts above the transmission Smile
I don't usually see them, but once I get the socket on them they aren't so bad. Fine pitch on those bolts, so LOTS of turning to get them all the way out (and back in).
Enjoy!
P.S. Don't drop the engine more than a few inches unless you disconnect the shift rod and front trans connection. Dropping the engine a lot would put too much stress on the nose cone.
DJ
porschpow
PostPosted: Thu Apr 19, 2012 5:34 am    Post subject: Reply with quote
I believe i only need an inch or two to get the tank over the metal tin that borders the firewall
-1986 Honda Magna
grandpa pete
grandpa pete is offline
PostPosted: Thu Apr 19, 2012 10:04 am    Post subject: Reply with quote
if anyone is thinking about changing a type 1 with one of theese jacks I highly recommend it . Recently two OLD guys got together in Phoenix and used one of theese to pull a bug engine out to replace a bad transmission.We were both surprised at how well it worked. The spacing between the two black rubber pads allowed just enough room for the taco plate and the engine rested on the pads...p.s. the lock mechanism on the jack gets in the way ...tie it off before you start
69 tintop camper 1600 DP
Goto page 1, 2  Next
