Lowering a Bay
Goto page Previous  1, 2, 3 ... 160, 161, 162 ... 191, 192, 193  Next
a1steaksauce
a1steaksauce is offline
PostPosted: Sat Apr 14, 2012 11:09 pm    Post subject: Reply with quote
Stuartzickefoose wrote:
tub dub. Very Happy
WAY COOL! i want to do this to mine ....someday.....
seeing all these cute little tubs with people tucking 15/14in rims is making me regret my decision to rock some 17's which require some huge tubs for suspension travel Laughing
here's a good shot showing how large of a tub i'm rocking...you can see how it sits in relation to the vin plate:
it literally sat dead level with the rivets holding the plate on. i ended up moving the plate up a few inches before welding the tub in place.
all done.
HighTopBay
HighTopBay is offline
PostPosted: Sun Apr 15, 2012 12:49 pm    Post subject: Reply with quote
Shocked wow them are big. giggity.
well got a little bit done today, work doesnt leave much time for progress.... and since its sunday, I couldn't go anywhere that sells pieces of sheet metal large enough to start welding the tubs in so instead I made cardboard templates. I'm just going to play it by ear for the top piece.
and cutting it close to the door....
Louis DePaolis
67T1
67T1 is offline
PostPosted: Sun Apr 15, 2012 1:30 pm    Post subject: Reply with quote
I've been wanting to get my DC tubbed out bad, but I'll wait a little longer. HighTopBay, always digg your ride. After looking at your pix of your cut compared to A1steaksauce's pix above yours, they look a little narrow. Are you seats going to sit on there alright after your done? Regardless, can't wait to see your end product. Good luck with the progress!
'67 Bug
'71 Bay Double Cab
HighTopBay
PostPosted: Sun Apr 15, 2012 1:58 pm    Post subject: Reply with quote
The actual tub section will go in a little further than the cut out section and then the inner seat rail/mount will be raised with some 3" box tubing that way the inner rail and outer rail will be all the same height. The front/top corners will also be rounded off, not 90* angles. And thanks for the kind words!
Louis DePaolis
67T1
67T1 is offline
PostPosted: Sun Apr 15, 2012 3:52 pm    Post subject: Reply with quote
Nice. Can't wait to see the end product!
'67 Bug
'71 Bay Double Cab
a1steaksauce
PostPosted: Sun Apr 15, 2012 5:12 pm    Post subject: Reply with quote
my tubs are very deceiving....but you're right i did push them way out to get me as much turning radius as i could.
i put a nice fat angle in them to interfere with the doors as little as possble, don't mind the wet primer:
and how much i had to tub my doors to accommodate them:
i can go full lock and my turning radius is fantastic. but again, if i was running smaller rims i wouldn't be having all these issues to work around Laughing
HighTopBay
PostPosted: Sun Apr 15, 2012 5:54 pm    Post subject: Reply with quote
Im thinking i can leave the door alone, narrow enough i think 4" king pin beam and 165 55 14 tires on stock wheels. leaves a little less to worry about lol
Louis DePaolis
a1steaksauce
PostPosted: Sun Apr 15, 2012 6:08 pm    Post subject: Reply with quote
yeah you're good. i've got 205/40R17's to worry about Laughing
1vwdog
1vwdog is offline
PostPosted: Mon Apr 16, 2012 8:22 pm    Post subject: Reply with quote
Is there a lower profile tire that is reinforced sidewall similar to the stock or Hannock? I have a Westy that I lowered and want to find a lower profile tire.
71 Chianti Westy
a1steaksauce
PostPosted: Mon Apr 16, 2012 9:21 pm    Post subject: Reply with quote
poke around on tirerack.com that's where i got mine from. they have a handy feature that allows you to filter tires by weight rating.
if you're a late westy you want a XL 94 load rated tire. will more than handle the GVWR of a westy.
there's plenty of low profile tires in that weight rating as well.
1vwdog
1vwdog is offline
PostPosted: Tue Apr 17, 2012 8:15 am    Post subject: Reply with quote
They don't let you select a bus, type II, van, etc.
71 Chianti Westy
a1steaksauce
PostPosted: Tue Apr 17, 2012 4:46 pm    Post subject: Reply with quote
go by tire size then.
i never look for tires on their site based off the vehicle.
BDubVdub
BDubVdub is offline
PostPosted: Tue Apr 17, 2012 6:51 pm    Post subject: Reply with quote
Here's my 68 and 61 Bug
BDubVdub
BDubVdub is offline
PostPosted: Tue Apr 17, 2012 6:56 pm    Post subject: Reply with quote
I see a TN plate under that mat. Where abouts? Thought Port Richey was in FL?
HighTopBay
PostPosted: Tue Apr 17, 2012 10:09 pm    Post subject: Reply with quote
^ I am in port richey, fl. I just have a random collection of out of state tags that I keep around for emergency metal patches lol. Whats the set-up/specs on the '68? Looks good!
Louis DePaolis
Notvanity
Notvanity is offline
PostPosted: Tue Apr 17, 2012 11:29 pm    Post subject: Reply with quote
http://oldbusgarage.com
BDubVdub
BDubVdub is offline
PostPosted: Wed Apr 18, 2012 5:32 am    Post subject: Reply with quote
Ahhhh...gotcha. The 68 has a 4" narrowed scratch built beam by me and a friend. Rear has 4.5" drop plates and is currently getting notched.
autohaus
autohaus is offline
PostPosted: Wed Apr 18, 2012 1:33 pm    Post subject: Reply with quote
front narrowed beam ball joint by Vintage Autohaus
dropped spindle ball joint by Vintage Autohaus
front tyres 165/50/15
rear adjustable plates by Vintage Autohaus
rear tyres 185/65/15
www.vintageautohaus.com
FRENCHVWMAFIA MEMBER
do not forget, only the mountains do not meet
HighTopBay
PostPosted: Wed Apr 18, 2012 2:26 pm    Post subject: Reply with quote
Here we go!
Frame tacked in place.(The excess metal inside the edges will be trimmed off eventually)
All closed up
I'll grind down the excess weld and finish em up real nice
now to do it one more time on the other side......
Louis DePaolis
BDubVdub
BDubVdub is offline
PostPosted: Wed Apr 18, 2012 3:17 pm    Post subject: Reply with quote
Sick!!!
Page 161 of 193
