parked for years
Goto page 1, 2  Next
couchinator75
couchinator75 is offline
PostPosted: Mon Apr 16, 2012 5:20 pm    Post subject: parked for years Reply with quote
Well, I sold one bus and in less than a year I'm looking for the next.
In the four years I owned my previous bus, a 1975 transporter, prices have gone up drastically. (Drastically in the sense that there isn't much out there that isn't pure crap or fully restored and 'worth' a brand new car).
So looking through local ads, ebay, and beyond I've come to the conclusion that maybe, just maybe, I should purchase a bus that needs a little TLC to keep the price down but nothing that involves body work.
So here are some questions and a bit of background on a bus I'm interested in:
Its a 1969 camper thats been sitting for five and a half years. The owner states that it might need a new generator (because the red gen light flickered at night) and of course a new battery.
What process would I need to go through to get it running again?
I know the basics like removing the old gas, oil, and battery but what else should I know before jumping too deep?
Is replacing or repairing (as Muir would prefer) a generator a doable task?
Is there much difference between a generator and an alternator? I ask because I see busdepot has a conversion kit...
Thanks for the help, links etc
VWDruid
VWDruid is offline
PostPosted: Mon Apr 16, 2012 5:41 pm    Post subject: Reply with quote
try new brushes first.
http://www.reluctantmechanic.com/step-by-step/change_generator_brushes.php
70 Westy, 2027cc "dual DRLA 40 m130 i55 wjdoc a165 p33 v30 "w100 straight cut 040 polished heads 1.25 rockers 1.5 A1sidewinder supertrapp muffler trans 091 coil SUM-850500 CDI universal svda Pertronix
http://www.storyofstuff.com/
It's not the straight cut gears It's the T.A.R.D.I.S. engine.
wanted Chameleon Circuit
busdaddy
busdaddy is offline
PostPosted: Mon Apr 16, 2012 6:47 pm    Post subject: Reply with quote
Or clean up the terminals on the starter, headlight switch, ignition switch and fuse box.
Ran when parked huh?, don't go into this project with high expectations, often the bus was parked for a good reason that the PO conveniently forgot to mention, not saying it's doomed but look at it with a very suspicious eye. You'll also want to look inside the cooling tin for the mouse condo that usually accompanies a bus like that.
Wanted, 68-73 westy OG plaid curtains, singles OK.
shiningstar76 Premium Member
Location: NH-> MA-> IL-> ES-> CZ-> NC-> VA-> Savannah, GA
shiningstar76 is offline
PostPosted: Mon Apr 16, 2012 6:49 pm    Post subject: Reply with quote
Finding a bus that doesn't need body work is location dependent. Out here TLC is bodywork.
KK4NTP
New Hampshire Native
78 Subaru Brat-Daily Driver
72 Westy, 1700cc Weber 32/36 DGEV-Down for front end issues
94 Subaru Legacy Wagon EJ22 292,000 miles
hoagy86 wrote:
I have a hardback bentley as well as the idiot John muir.
Wildthings wrote:
It was actually too long by about 3-4 inches and I had to work it quite a bit to force it all in. Much better than too short though
View user's profile Send private message Send e-mail MSN Messenger Facebook Gallery Classifieds Feedback
bwiencek
bwiencek is offline
PostPosted: Mon Apr 16, 2012 7:02 pm    Post subject: Reply with quote
SO true - if it was "that simple" and just "flickered" and there was nothing else wrong then really why was it parked and not started / driven occasionally?
I'd say be ready for doing some other mechanical work... I wouldn't be suprised if it used a little oil, had lower compression, or you might get lucky and it just needs a tune up, valve adjustment and a carb rebuild (with all new fuel lines and filter) to be running tip top... Of course sitting 5 years be prepared to drain and clean out the fuel tank to get the old bad gas out of it - I'd just start by draining it into a bucket and evaluating what comes out - that will give an indication of what's inside...
73 bay window - brought home in boxes - work in process.
previous VW Busses: 69 with crank open sunroof, 70 standard, 71 westfalia camper
ned
ned is offline
PostPosted: Mon Apr 16, 2012 7:39 pm    Post subject: Reply with quote
How much for the ran when parked bus? If it isn`t rusty you are stoked especially if the price is right. The mechanical is the easy part. Be sure to have some fun.
couchinator75
PostPosted: Mon Apr 16, 2012 7:50 pm    Post subject: Reply with quote
the asking price is $3000, looks to be a solid body very little to no rust.
to clarify all i know is that it last ran 5 years ago and all i've seen is pictures, i plan on contacting the seller for more information by phone tomorrow.
how much effort, if the bus hasn't been run in that time, would it take to see if it would actually start up?
SGKent
SGKent is offline
PostPosted: Mon Apr 16, 2012 9:25 pm    Post subject: Reply with quote
depends - if the cylinders are rusty inside from moisture in the air then it might include a teardown. It will certainly require new tires and probably at least new wheel cylinders as they will be rusty inside.
wasps, spiders and mice have to be dealt with. We had one here that had a pair of snakes that moved in.
Steve aka Merlin the Wrench
formerly Steve's Racing and Engine Blueprinting. Wrenching since 1967.
bdamico on GF wrote
"When I was your age I'd plan out all sorts of stuff for the future and almost none of them came true. Just wonder if it's worth trying to be a crystal ball. "
ned
ned is offline
PostPosted: Mon Apr 16, 2012 10:29 pm    Post subject: Reply with quote
3k seems a bit steep to me.
It better be real nice for a non running bus.
bwiencek
bwiencek is offline
PostPosted: Tue Apr 17, 2012 5:09 am    Post subject: Reply with quote
When you go to inspect it - try and turn the crank pulley by hand and see if it is able to rotate at least 1/4 turn - that will tell you that the piston rings haven't rusted to the cylinders. I wouldn't try and start it if your plan is to hope not to have to rebuild the engine - I'd wait and do some work before trying that...
$3k if the body is in super shape and the interior is in great shape is probably a decent price as the mechanicals are cheap compared to bodywork/rust repair...
To start it here's a quick list of what I'd do:
- Drain fuel tank
- replace lines/filter while you're in there.
- super basic cleaning of the carb (just to flush out dried up fuel). You might even get away without a rebuild kit to start it if you're careful/lucky.
- clean and adjust the points or just replace them
- pull plugs, pour about 2oz oil into the cylinders and let sit - if it is stuck, or had to be broken free to turn, or feels "rough" when turning then fill the cylinders with oil as much as you can (just be warned since it's a boxer engine - if the valve is open it's going to go out that port - intake or exhaust so don't go crazy - if it's super stuck - pull the valvecover and loosen the valves to close them completely on all cylinders and let it soak in oil.)
- check level of trans fluid, check condition of brake fluid and flush if necessary (test strips are cheap or if it looks dirty - flush it), inspect brake lines and hoses.
Let the oil sit a day or so, then do an oil change, and then turn the engine over by hand a couple rotations, then have someone crank the engine over without plugs in it to pump out most of the oil (have rags over the plug holes as it can make a mess.) Clean up the oil, install cleaned or new plugs, prime the carb and fire it up!
Once it's running check the operation of the brakes, check the condition of the tires, make sure there aren't any leaks, and try and take it for a drive up and down the street slowly. Get the engine warmed up and then go back home and re-inspect everything and give it a good once-over before heading out at higher speeds.
Mal evolent
Mal evolent is offline
PostPosted: Tue Apr 17, 2012 5:41 am    Post subject: Reply with quote
if it has't run in 5 years I would simply buy all new rubber and plan on rebuilding the engine.
73 Beetle, Ghia front brakes, Type 3 rear brakes, 1776, Solex 34 Pict-3, Bosch SVDA, '97 Mustang seats
[77 Westy M plate decoded]
Baja Bugs for Volkswagen Virgins: Index
mikewire
mikewire is offline
PostPosted: Tue Apr 17, 2012 7:56 am    Post subject: Reply with quote
I'm in agreement with bwiencek here.
Usually cars are not parked without reason, but there are exceptions. My '80 Rabbit pickup was parked for 10+ years. I drug it out, put some steelies on it, and did the same thing as bwiencek described, plus cleaned out the CIS fuel system (but you won't have that headache).
Anyway, my little truck fired up and ran fine and blew out the cobwebs. Other than a valve adjustment it runs great.
I would offer the guy 1K and see where that goes. He's going to balk at the price, but you have got to point out it's sat for years, and it's a mystery machine to you, and you are taking a risk that it won't be a waste of your hard earned 1K.
Besides, you are going to easily put 1K-2K back into it to get it running and driving properly.
Plus, it's not made of gold. It's an old VW someone has parked and forgotten about Confused He won't have any other offers come in, so if there's no deal, wait it out for a month and try again.
1972 9 Passenger Deluxe Non-Walkthrough | 2003 Audi A4 Avant 1.8TQT REVO Stage 2 | 2000 VR6 Jetta Bright Green Pearl | 1980 Lago Caddy JH 1.8 CIS
My 1972 Deluxe build thread
www.bigskyeuro.com
couchinator75
PostPosted: Tue Apr 17, 2012 6:57 pm    Post subject: Reply with quote
bwiencek thanks for the quick run through on getting it started
Now is it worth it to get the bus running or almost running and not buy it?
Or should one wait and hope that the hand cranking, questioning, and other inspections give enough info?
I agree, mikewire, from the conversation I had with the seller today offering 1k to 2k seems like a good route to go. Not sure where the seller got their price but also not sure if she'd budge either. At least she was honest with what needs to be done; ranging from small to big, like locks to a stolen exhaust Confused .
From what I gathered she shipped the car out to MN after using it out in CA. Never drove it here because she uses the bus system. Didn't even start it up and drive it around.
Any other advice? Its nice to have the VW fever again even though it costs more than we like to admit.
busdaddy
busdaddy is offline
PostPosted: Tue Apr 17, 2012 7:46 pm    Post subject: Reply with quote
I wouldn't get it running for her but I would hand turn the engine through at least 8 full strokes and pull each sparkplug to look for one that's odd or oily, I'd also eye up the oil on the end of dipstick and inside of the filler cap carefully. Assume it's got bad brakes as well.
$3K may not be a bad deal for a nearly rust free complete, non running camper with faded OG paint and all of it's equipment but it's real high for a mystery bus, see if she'll negotiate. Consider it a non running, non stopping project and deal on it as such so you don't get burned.
morymob
morymob is offline
PostPosted: Wed Apr 18, 2012 5:06 am    Post subject: Reply with quote
Best u pay attention to advice here, never get one running etc before owned. If u r lucky to get eng to go a 360 turn great. Brake sys , hope the steel lines are still usuable as ALL other parts will have to be replaced. Rust-? mice living inside, near impossible to remove stink.Most of all= don't go listing any of the pluses to the owner as this just usually comes back to bite u in the ass, u are trying to buy 'as is', just my 2-cts of buying vw's over the years to be re-furbed etc.
70autostick
70autostick is offline
PostPosted: Wed Apr 18, 2012 6:56 am    Post subject: Reply with quote
Im in the same boat, just bought a 71 bay yesterday thats been sitting for about 5 years.
It was left at a repair shop after they rebuilt the brakes when she wouldnt start. 4 years later, my neighbor bought it from the shop for parts. He hooked up a battery, replaced the points, and hooked up the coil wire and she fired up. No smoke or strange sounds. And wouldnt you know it, the title was in the glovebox, already signed by the po. Very Happy
Then i came along a year later, yesterday, with 850 bones, and decided to give her a new life.
I plan on replacing the battery, oil, fuel lines and tires, and driving her home, which is roughly half a mile. Wink
Daily driven 1972 beetle, no more 70autostick
couchinator75
PostPosted: Wed Apr 18, 2012 6:20 pm    Post subject: Reply with quote
thanks busdaddy
hopefully if i get a chance to look at it things turn out like 70autosticks experience...
GeorgeL
GeorgeL is offline
PostPosted: Wed Apr 18, 2012 10:33 pm    Post subject: Reply with quote
The other thing about "parked 5 years" vehicles is what they were parked on. Parking on dirt makes for a rusty underside unless the dirt is in Arizona.
I'd consider "parked 5 years" to be "blown engine." You might get lucky, but it's not likely.
tweakhx
tweakhx is offline
PostPosted: Thu Apr 19, 2012 3:30 am    Post subject: Reply with quote
Boy this makes me wonder about my new project. I found a 71 westy out in a field that has been sitting for at least 26 years. The body is in pretty good shape and it seems to have the original accessories and what not. Although the front interior has been weathered due to a broken windshield.
I bought it for $350. Hoping for the best!
bwiencek
bwiencek is offline
PostPosted: Thu Apr 19, 2012 6:05 am    Post subject: Reply with quote
Geez - 5 years and it's hopeless Shocked - at that rate half the stuff I bought would have gone to the crusher...
Here's a couple of motivating posts to get over the 5-year 'sitting'...
I just bought a '68 mustang last fall that sat over 8 years, wasn't started in that time (guy started to restore in the mid 90's - got it 90% then was driving occasionally, parked it to do the interior - got 90% through then decides he wants saddle instead of stock black and after he ran it out of gas starting it every month never put fuel in it or drove it...). I revived it for under $200 in parts (battery, oil, brake fluid, etc.) enough to drive it on a 2k mile road trip home - only problems I ran into -had to file the points once and threw the cheap parts store replacement belt and had to put on the at least 10 year old one which did better than the new junk belt... And I did it all on the 10++ year old tires none the less (which had probably 95% tread but were way old)
Back in the 80's I bought a '69 dodge school bus at a local mnicipality auction that was being used for storage for paint for the prior 6-7 years and with only an oil change and lube drove that one with 20 college kids ~900 miles each way to mardi gras with only heater hose issues (they were rotted and one of the 4 heater cores blew too...). Did a couple of trips to padre island (at least 12-1300 miles each way) and tons of closer 1-400 mile trips - all on the same engine/trans/tires that it came with out of the storage lot...
I've got more stories of "junk" I've bought and drove but don't let the nay sayer's write it off just because it sat for 5 years... it may not be perfect but it's probably not junk!
Goto page 1, 2  Next
