1970 bus with 1975 1800 cc bus motor
harleysprocket
harleysprocket is offline
PostPosted: Sun Apr 22, 2012 12:05 pm    Post subject: 1970 bus with 1975 1800 cc bus motor Reply with quote
Hello I just bought a 1970 vw bus with no motor. I have a 1800 motor engine code ED that came out of a 1975 bus which has been converted to carbs. My question is will this 1800 motor work in a 1970 bus
old DKP driver
old DKP driver is offline
PostPosted: Sun Apr 22, 2012 4:53 pm    Post subject: 70 with 1.8 Reply with quote
A couple different ways to do it.Since the bell housing on the 70 will
not accomodate the 210mm flywheel and you need to change the
mustache bar and fab the mounts for it too.
But it is doable but why do it when you can have as much power
from an upright engine?
Maybe you should post this in the Bay Window forum.
also do some searching here for conversion parts.
1971-1979 have ears on the bell housing for extra support of the
weight. so,more $$$ for the transmission too.
V.W.owner since 1967
Jennepher Premium Member
Jennepher is offline
PostPosted: Sun Apr 22, 2012 5:03 pm    Post subject: Reply with quote
Moved to the Bay Window forum from General/Chat.
TheSamba.com on Facebook | Donate to TheSamba.com
If your post begins "I know this is against the rules but..." just stop typing.
Wildthings
Wildthings is offline
PostPosted: Sun Apr 22, 2012 5:21 pm    Post subject: Re: 1970 bus with 1975 1800 cc bus motor Reply with quote
It's going to take a bit of work to get that job done. Either a lot cutting and chopping or going to a DTM fan shroud.
I agree with others build yourself a 1776 (or other) Type 1 engine and get on the road.
busdaddy
busdaddy is offline
PostPosted: Sun Apr 22, 2012 5:21 pm    Post subject: Reply with quote
Even more $ for the DTM cooling kit unless you are prepared to irreversibly hack the body metal surrounding the engine, I agree with Old DKP, a well built type 1 can do nearly everything the ED can but do with easy bolt in installation.
Wanted, 68-73 westy OG plaid curtains, singles OK.
