ffastr6 Samba Member
Posted: Sun Apr 22, 2012 6:05 pm Post subject: Lowered Spring Plates |
Just purchased a pair of JerFab 3" lowered spring plates and was wondering if I would have to eliminate my snubbers to install them? |
DarthWeber Samba Member
Joined: November 24, 2007 Posts: 7543 Location: Whittier,CA
Posted: Sun Apr 22, 2012 6:33 pm Post subject: |
Eliminating your snubbers completely is the very last thing you want to do. You should always have some type of rubber stop for the suspension to bottom out on. Metal bottoming on metal, especially in a turn, will give your car a very good chance of spinning out. If those spring plates were designed to be used without snubbers then they were designed wrong. _________________
Mitey62 wrote: |
Swapped the Compufire for a Bosch blue and some points I had sitting around, started 1st crank. Took her out for a drive, pulls harder, more RPM, and runs smoother. I think I'll be sticking with points from now on. |
RockCrusher wrote: |
JB weld the case halves....that'll keep the fretting to a minimum. |
modok Samba Member
Joined: October 30, 2009 Posts: 26787 Location: Colorado Springs
Posted: Sun Apr 22, 2012 6:40 pm Post subject: |
yes, to lower it three inches you will be on the bump stops, so you can either have no travel or take them off |
Ace Samba Member
Posted: Sun Apr 22, 2012 7:42 pm Post subject: |
I think pre 60 cars had no rubber snubber. Your shock will bottom out first, theoretically. |
