New guys buggy project!
Goto page Previous  1, 2, 3 ... 5, 6, 7 ... 13, 14, 15  Next
Forum Index -> Kit Car/Fiberglass Buggy Share: Facebook Twitter
theredbarn
theredbarn is offline
PostPosted: Thu Apr 12, 2012 11:31 am    Post subject: Reply with quote
Another useful product to use - before "bondo" - are microbaloons. you mix them with resin to a consistency of peanut butter (AKA "dookie" in boat building lingo) and use that to level the surface. It sands easy and it's the same resin so the bonding is better than "bondo".
jspbtown
jspbtown is offline
PostPosted: Thu Apr 12, 2012 12:36 pm    Post subject: Reply with quote
That repair looks great. Your not going to have any issues with it.
herbsflat4
herbsflat4 is offline
PostPosted: Thu Apr 12, 2012 7:07 pm    Post subject: YEA! Reply with quote
pallen wrote:
Roller!
O man this thing looks good! Well done. You are really making some progress.
pallen
pallen is offline
PostPosted: Sat Apr 14, 2012 8:38 pm    Post subject: Reply with quote
So close.. kinda...
pallen
pallen is offline
PostPosted: Sun Apr 15, 2012 6:36 pm    Post subject: Reply with quote
Id like to punch the guy that cut the dash off!
Screwed it together with strips of plywood on the back side...
First coat of fg, going to pull the screws and do the back side next, then one more final over the top.
joescoolcustoms Premium Member
joescoolcustoms is offline
PostPosted: Mon Apr 16, 2012 5:36 am    Post subject: Reply with quote
And the PO's that cut half the rear out for a $ 12.00 EMPI chrome 3 day rust Air Cleaner. Or the PO's that cut a hole in the middle of the ridge line of a hood big enough to stick their stupid head through. Or the PO's that hack out the rear package trey and body mount area so they can adjust the clutch cable.
Your build is looking nice, keep on, you will be driving it before you know it.
The early bird might get the worm, but the second mouse gets the cheese.
Looks like it was painted with a live chicken,polished with a brick and buffed with a pine cone
Member of Wagenfolks
http://images.thesamba.com/vw/gallery/pix/870707.jpg
http://www.thesamba.com/vw/forum/viewtopic.php?t=479740
ChadCook
ChadCook is offline
PostPosted: Mon Apr 16, 2012 6:11 am    Post subject: Reply with quote
Don't forget the guy who hacked the rear deck to get to the top engine bolts.
pallen
pallen is offline
PostPosted: Wed Apr 18, 2012 9:49 am    Post subject: Reply with quote
Put a new shift rod coupler and installed an adjuster so I can get it tuned in!
and got my dashed gauges figured out....
pallen
pallen is offline
PostPosted: Wed Apr 18, 2012 7:13 pm    Post subject: Reply with quote
Steering support, will also weld on a switch plate under the gauges area.
PostPosted: Wed Apr 18, 2012 7:35 pm    Post subject: Reply with quote
I like the gauge placement and choices. The steering column support looks to be good and strong. I made mine close to that design and the wheel did not move around/flex when driving it hard in the turns.
pallen
pallen is offline
PostPosted: Thu Apr 19, 2012 6:06 pm    Post subject: Reply with quote
Shoulder belt mounts...
pallen
pallen is offline
PostPosted: Sun Apr 22, 2012 5:15 pm    Post subject: Reply with quote
Pedal stop made...
Are these bad?? ha
Also got the brakes bleed and working, e brake working. Coated the gas tank and wired up a temp ignition and starter switch, should be able to start it up and cruise down the driveway next weekend!
pallen
pallen is offline
PostPosted: Mon Apr 23, 2012 3:26 pm    Post subject: Reply with quote
If you noticed I got RJS buggy belts, I ordered them online from a distributor but they are like 20 mins from my house. After getting them I ran into a problem, my seats are so low to the pan and close to my belt mounts that the lap belt was too long! So I went by the company after work Friday and they were super friendley and said they could shorten them no problem. Picked them up today expecting to pay something and she just handed them to me and said no charge! So a little shout out to a great local company that makes great products!
These are where they shorted them, they were originally twice as long.
Heres why I really like these, 3 point belts with simple car style latches.
Anyways got my rear lights in, just need to do some FG work to get them in...
pallen
pallen is offline
PostPosted: Wed Apr 25, 2012 6:35 pm    Post subject: Reply with quote
Drove it down the driveway!
pallen
pallen is offline
PostPosted: Fri Apr 27, 2012 7:09 am    Post subject: Reply with quote
Got my oil temp sender mounted, I wanted to use the VDO sender but after emailing auto meter found that the two would not be compatiable so I found an adapter to be able to use it in..
And more fiber glass work....
pallen
pallen is offline
PostPosted: Fri May 04, 2012 6:26 am    Post subject: Reply with quote
Well I'm getting closer and closer. Have the buggy insured and waiting on registration to come back...
Have been playing with the engine to get it tuned in and lots of FG work. From never touching FG just about a month ago I'm now on my 3rd gallon of resin.....
Im also wainting on some gold rage I ordered to finish up the body work over the repairs.
gr8cobbler
gr8cobbler is offline
PostPosted: Fri May 04, 2012 9:23 am    Post subject: Reply with quote
Pallen, are you using those lights to heat your work? Speed setting etc? I've considered doing that myself, does it work well? I know those lights can cook you if you are in close proximity to them for too long.
Gary
Being a cheap old fart is just a front for my actual lack of money. Smile
pallen
pallen is offline
PostPosted: Fri May 04, 2012 9:45 am    Post subject: Reply with quote
Yeah I use them to speed up the curing a bit, not always but that day was pretty chilly out. Also if I want somthing not to run as easily, like that big patch that was vertical. I typically just turn them on untill its not tacky anymore. Seems to work pretty welll, those lights put out quite some heat. It says on the resin instructions you can do to help speed it up but also says too much heat can cause it to crack from curing to fast. I haven't had any crack yet.
pallen
pallen is offline
PostPosted: Sat May 05, 2012 8:52 pm    Post subject: Reply with quote
Switch Panel
Wiper Switch will be going in the opening on the right, should be here Monday.
pallen
pallen is offline
PostPosted: Thu May 10, 2012 6:01 am    Post subject: Reply with quote
Tail lights...
Windshield...
I got the brake and turn signals temp wired up, its tagged and insured so I need to get some mirrors then I can take it for its first cruse!
Reply to topic    Forum Index -> Kit Car/Fiberglass Buggy All times are Mountain Standard Time/Pacific Daylight Savings Time
Page 6 of 15
